    Unable to install the VOXL SDK
    • S
      SMRazaRizvi
      I am trying to install the VOXL SDK on my Sentinel drone.
      Using the install.sh script inside the VOXL SDK download completes the flashing of the system image successfully but fails to install the voxl-suite by spitting out the following error.
      Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en
      Get:3 file:/data/voxl-suite-offline-packages ./ Packages
      Ign:3 file:/data/voxl-suite-offline-packages ./ Packages
      Err:3 file:/data/voxl-suite-offline-packages ./ Packages
        File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
      Reading package lists... Done
      N: Download is performed unsandboxed as root as file '/data/voxl-suite-offline-packages/./InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
      E: Failed to fetch file:/data/voxl-suite-offline-packages/./Packages  File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
      E: Some index files failed to download. They have been ignored, or old ones used instead.
      [INFO] Installing packages on target
      Building dependency tree
      E: Unable to locate package voxl-suite
      ERROR failed to install voxl-suite
      SUCCESS:cat: /tmp/success: No such file or directory
      My guess is that there's something wrong with the apt sources listing inside /etc/apt/, as I see the same errors when I do sudo apt update inside the sentinel drone.
      Can anyone please let me know how to solve this?
      Or how can I retrieve the factory apt source files?
      • S
        SMRazaRizvi @SMRazaRizvi
        @SMRazaRizvi
        UPDATE
        I solved this issue by adding the following line inside the offline-install.sh at line 92
        adb shell "cd $PKG_DIR/ && gunzip Packages.gz"
        but then I am facing the following error while installing the voxl-suite
        executing: voxl-esc setup_sentinel_v1
        enabling bridge
        bridge enabled
        [INFO] Scanning for ESC...
        Couldn't configure flight_controller sensor
        Error calling voxl_uart_init
        [ERROR] Unknown board detected:
        disabling bridge
        bridge disabled
        EXITING VOXL-ESC WITH ERROR
        FAILED TO EXECUTE: voxl-esc setup_sentinel_v1
        And then eventually
                 FAILED TO EXECUTE the following steps:
              Encountered Problems Configuring MPA Services :-/
                Some Services may not start up on next reboot
        checking /data/px4/param/parameters_gyro.cal
        checking /data/px4/param/parameters_acc.cal
        checking /data/px4/param/parameters_mag.cal
        checking /data/px4/param/parameters_level.cal
        Calibration File Status:
        Present /data/modalai/voxl-imu-server.cal
        Present /data/modalai/opencv_tracking_intrinsics.yml
        Present /data/modalai/opencv_stereo_front_intrinsics.yml
        Present /data/modalai/opencv_stereo_front_extrinsics.yml
        Present /data/modalai/opencv_stereo_rear_intrinsics.yml
        Present /data/modalai/opencv_stereo_rear_extrinsics.yml
        Missing /data/px4/param/parameters_gyro.cal
        Missing /data/px4/param/parameters_acc.cal
        Missing /data/px4/param/parameters_mag.cal
        Missing /data/px4/param/parameters_level.cal
        Detected Missing Calibration Files
        please run the required cals
        https://docs.modalai.com/calibration/
                        PLEASE POWER CYCLE YOUR VOXL
        This does ends up with the installation of VOXL SDK, and I can even access the camera server, but there are issues with MPA and I am unable to connect to QGC.
        Help please.
          tom admin @SMRazaRizvi
          @SMRazaRizvi I'm guessing your file system is corrupt in some way. I would do the following to fully wipe / re-flash your system:
          cd voxl2_SDK_1.0.0
          cd system-image
          ./flash-system-image.sh -f
          cd ..
          cd voxl-suite
          ./offline-install.sh
          • S
            SMRazaRizvi @tom
            @tom Thanks. This worked in successfully installing the voxl-suite
            Still, I'm facing further issues.
            For some reason, all the services were Disabled and Not Running when I checked through voxl-inspect-services. Is this normal?
            I manually enabled and started some, as shown below, but I am unable to start the voxl-vision-hub and the voxl-qvio-server services. How can I bring them up?
            • S
              @SMRazaRizvi
              UPDATE
              voxl-configure-mpa solved this particular issue.
              Following these instructions.
