  3. VOXL2 has two network interfaces for microhard modem
9 Posts 3 Posters 2.4k Views 2 Watching
  • Daniel RyuD Offline
    Daniel RyuD Offline
    Daniel Ryu
    wrote on last edited by Daniel Ryu
    I am flashing some newly purchased VOXL2 development kits when I ran into this issue when using a microhard. When voxl-configure-modem is run, it creates two interfaces that connect to the microhard: eth0 and usb0. The IPs that are set on both interfaces are random, and are not consistent between reboots of the voxl2 board. Additionally, when both are active, any connections to QGC from the board through the microhard is greatly slowed down. I would like to permanently set the ip address of one of the interfaces to be something that I can control, like how voxl-configure-modem used to do, as well as permanently delete the other interface since it is not required.
    Things I have tried:
    Editing /etc/network/interfaces and removing an interface. This does not prevent both interfaces from reappearing upon reboot
    ifconfig eth0 down. eth0 sets itself back to "up" automatically within a few minutes, even without reboot.
    ifconfig usb0 down. usb0 stays down when this command is run, but returns as up again upon the voxl2 board's reboot
    ip addr del dev eth0. It returns the error: Screenshot 2023-01-11 at 3.02.25 PM.png
    sudo iw dev eth0 del. It returns the error e788843f-0662-4837-9b4d-14256f892d45-image.png
    Here is what VOXL2 Version I'm running:
    I did already try running apt-get update && apt-get upgrade
        You must be using an older version of the Microhard add-on that had the LAN7500 Ethernet to USB chip installed.
        It seems you could check if eth0 was there and run ifconfig usb0 down in a startup service if eth0 is present?
        Daniel RyuD 1 Reply Last reply
        • Chad SweetC Chad Sweet
          Daniel RyuD Offline
          Daniel RyuD Offline
          Daniel Ryu
          @Chad-Sweet I think that would work. Do you know if the same type of Microhard add-on would have exhibit the same symptoms with a VOXL1?
            No, I do not know. VOXL 2 is a much newer kernel and OS and it may not behave identically
              Daniel RyuD Offline
              Daniel RyuD Offline
              Daniel Ryu
              @Chad-Sweet Got it, thanks!
                Daniel RyuD Offline
                Daniel Ryu
                General QOL update: I automated a script using cron to ifconfig usb0 down and change the eth0 ip address to what I wanted using ifconfig eth0 <ip>. This only works if the script is run using sudo
                M 1 Reply Last reply
                • Daniel RyuD Daniel Ryu
                  M Offline
                  M Offline
                  Mastermind
                  @Daniel-Ryu I have a VOX2 with a microhard modem, but I only get a USB0 and no ETH0. Putting USB0 down and trying to bring up ETH0 doesn't work as the system does not detect it. Just curious if this was your issue as well?
                  • M Mastermind
                    Daniel RyuD Offline
                    Daniel RyuD Offline
                    Daniel Ryu
                    @Mastermind USB0 is the interface the VOXL2 + newer Microhard add-on boards use for communication, so eth0 may not show up if you're used to using that from VOXL1
