    Issue Getting uart Connection on VOXL2 to PixHawk4 on 5G Hat
    740
    • J
      John Nomikos 0
      Good afternoon,
      I have been trying to get a serial connection from the J9 socket of a 5G hat to a PixHawk 4. However, there does not seem to be any data going through ttyHS2.
      I triple checked to make sure my physical connection is correct and the wires are in the correct area. They look correct to me.
      I have the JST from the J9 socket connected to TELEM2 of the PixHawk 4. The baudrate is set to 921600.
      The way I am testing this is by using mavlink-router. I run this command:
      mavlink-routerd /dev/ttyHS2:921600 -e {my ip}:14550 -v
      It has worked before when connecting to the usb port on the hat via an FTDI cable, but we're trying to get it working with the serial port.
      I also decided to follow this to see if I could get anything from sending stuff to the port. I saw nothing. But I could be completely wrong that this is a valid way of testing the connection:
      (In one terminal):
      cat -v < /dev/ttyHS2
      (In another terminal):
      echo -ne '\033[2J' > /dev/ttyHS2
      I did not see anything on the first terminal.
      Also, I tried using voxl-mavlink-server to test this. I am on a beta platform (system-image: 1.5.5-M0054-14.1a-perf), so options are a little bit different than what I'm used to.
      I had this set as my configuration file:
              "primary_static_gcs_ip":        "192.168.8.10",
              "secondary_static_gcs_ip":      "192.168.8.11",
              "onboard_port_to_autopilot":    14556,
              "onboard_port_from_autopilot":  14557,
              "gcs_port_to_autopilot":        14558,
              "gcs_port_from_autopilot":      14559,
              "en_external_uart_ap":  false,
              "autopilot_uart_bus":   2,
              "autopilot_uart_baudrate":      921600,
              "en_external_ap_timesync":      1,
              "en_external_ap_heartbeat":     1,
              "udp_mtu":      0,
              "gcs_timeout_s":        4.5
      I believe "autipilot_uart_bus" was what I had to set to 2 to get it to go through ttyHS2. I could not see any data passing through though.
      I am curious what the problem could be. Any help would be much appreciated.
      W 1 Reply Last reply 29 Jun 2023, 22:22 Reply Quote 0
      • W
        wilkinsaf ModalAI Team @John Nomikos 0
        For context, the UART/USB addon board is working (https://docs.modalai.com/voxl2-usb3-uart-add-on-user-guide/)
        and we are using cables provided by ModalAI. So, it appears that it is just the 5G modem carrier board that is not letting this through
        W 1 Reply Last reply 29 Jun 2023, 22:25 Reply Quote 0
        • W
          wilkinsaf ModalAI Team @wilkinsaf
          for context as well, here are the serial devices by-id page. All of them are from Quectel.
          Dont think that matters, but just trying to add context.
          Also, the 5G carrier board is operational. We see the wwan0 interface
          W 1 Reply Last reply 29 Jun 2023, 22:36 Reply Quote 0
          • W
            https://forum.modalai.com/topic/2141/external-autopilot-not-getting-serial-communication-with-m0090-board/8?_=1688077180364
            I think this might be the issue
            T 1 Reply Last reply 30 Jun 2023, 03:19 Reply Quote 0
            • T
              tom admin @wilkinsaf
              @wilkinsaf That must be the VOXL1 flavor
              W 2 Replies Last reply 30 Jun 2023, 04:33 Reply Quote 1
              • W
                wilkinsaf ModalAI Team @tom
                • W
                  @tom Damn.... welp... that would explain what's going on.
                  Back to the ModalAI store. Thanks for confirmation Tom
                  W 1 Reply Last reply 6 Jul 2023, 17:33 Reply Quote 1
                  • W
                    Can confirm ordering and installing a new one fixed our issue
                    T 1 Reply Last reply 6 Jul 2023, 18:03 Reply Quote 1
                    • T
                      @wilkinsaf Thanks for the feedback
                      1 out of 9
