    VOXL2 px4 ESC config with QGroundControl
    768
    • B
      Benjamin Ruks
      I am currently having issues following the docs for using the VOXL ESC with PX4.
      QGroundControl is not showing the "Actuators" tab but a "Motors" tab instead and i am not able to assign motor position and actuator outputs. Therefore i am not able to arm my vehicle or spin the motors with the given sliders.
      Also I am missing the mentioned MODAL_IO parameters. The Documentation states, that on older voxl-px4 versions (i am currently using 1.12.31) instead of "MODAL_IO" the paramters are named "UART_ESC". Here ist the output of my parameter list:
      voxl2:~$ px4-param show | grep UART
      x   UART_ESC_BAUD [596,1580] : 250000
      x + UART_ESC_CONFIG [597,1581] : 1
      x   UART_ESC_MODE [598,1582] : 0
      x   UART_ESC_MOTOR1 [599,1583] : 3
      x   UART_ESC_MOTOR2 [600,1584] : 2
      x   UART_ESC_MOTOR3 [601,1585] : 4
      x   UART_ESC_MOTOR4 [602,1586] : 1
      x   UART_ESC_RPM_MAX [603,1587] : 15000
      x   UART_ESC_RPM_MIN [604,1588] : 5500
      x   UART_ESC_T_COSP [605,1589] : 0.9900
      x   UART_ESC_T_DEAD [606,1590] : 20
      x   UART_ESC_T_EXPO [607,1591] : 35
      x   UART_ESC_T_MINF [608,1592] : 0.1500
      x   UART_ESC_T_PERC [609,1593] : 90
      x   UART_ESC_VLOG [610,1595] : 0
      I am using the VOXL ESC 4-in-1 Digital I/O UART in combination with a VOXL2 Board.
      I can spin the motors with the following command
      px4-qshell modalai_esc -i 1 -r 1000 rpm
      but not with the sliders in QGroundControl.
      What am I missing? Are you recommending to update the package?
      E 1 Reply Last reply 5 Jun 2023, 16:05 Reply Quote 0
      • E
        Eric Katzfey ModalAI Team @Benjamin Ruks
        @Benjamin-Ruks You will either have to wait for our next release that resolves those issues (1.14.0 based PX4) or build PX4 from our development branch yourself.
        B 1 Reply Last reply 22 Jun 2023, 08:36 Reply Quote 0
        • B
          Benjamin Ruks @Eric Katzfey
          @Eric-Katzfey Thank you for your quick reply. I flashed the latest platform release and also build and installed PX4-1.14. Now everything works fine for the ESC and Motor Part.
          However, I think I may have missed some crucial setup steps, since the GPS Module is not working anymore (The LED does not even light up). Any quick suggestions on what I could have missed? (Worked fine before the flashing)
          E 1 Reply Last reply 22 Jun 2023, 15:29 Reply Quote 0
          • E
            @Benjamin-Ruks What GPS unit are you using? Is this one of our drones or a custom drone?
            B 1 Reply Last reply 22 Jun 2023, 16:44 Reply Quote 0
            • B
              @Eric-Katzfey I am using "VOXL 2 GPS / Magnetometer / RC / Bind Module w/ Receiver" Bundle (MDK-M0094-2-02)
              E 1 Reply Last reply 22 Jun 2023, 17:09 Reply Quote 0
              • E
                @Benjamin-Ruks Do you know if the magnetometer is working? The RC?
                B 1 Reply Last reply 23 Jun 2023, 06:35 Reply Quote 0
                • B
                  @Eric-Katzfey The Receiver is working fine. QGroundControl tells me that no magnetometer is attached (also no gps module). So I had to turn both of in order to be able to arm the drone. As I mentioned above I flashed the newes System image and since than there is no life signal from the gps/mag module.
                  By reading this post I noticed that the file /etc/modalai/voxl-px4.config does not exist on my VOXL2. Maybe that's the reason? Also I tried px4-qshell gps start but nothing changed.
                  E 2 Replies Last reply 23 Jun 2023, 14:44 Reply Quote 0
                  • E
                    @Benjamin-Ruks The documentation is being updated for the new release. The new start script for px4 is /usr/bin/voxl-px4-start.
                    • E
                      @Benjamin-Ruks Can you attach the output of the command journalctl -b -u voxl-px4 to show all of the output from the startup of voxl-px4?
                      B 1 Reply Last reply 30 Jun 2023, 11:59 Reply Quote 0
                      • B
                        @Eric-Katzfey said in VOXL2 px4 ESC config with QGroundControl:
                        -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2023-06-30 11:55:33 UTC. --
                        Jun 22 16:31:59 m0054 systemd[1]: Starting px4...
                        Jun 22 16:32:01 m0054 systemd[1]: Started px4.
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: [INFO] /etc/modalai/voxl-px4.conf not found, using defaults
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: Found DSP signature file
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: *************************
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: GPS=NONE
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: RC=SPEKTRUM
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: OSD=DISABLE
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: DAEMON_MODE=DISABLE
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: SENSOR_CAL=ACTUAL
                        Jun 22 16:32:01 m0054 voxl-px4[1694]: EXTRA STEPS:
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: INFO  [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: INFO  [px4] assuming working directory is rootfs, no symlinks needed.
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: INFO  [muorb] Got muorb init command
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: Got topic data before configuration complete
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: *************************
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: GPS: NONE
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: RC: SPEKTRUM
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: OSD: DISABLE
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: EXTRA STEPS:
                        Jun 22 16:32:02 m0054 voxl-px4[1694]: Running on M0054
                        Jun 22 16:32:03 m0054 voxl-px4[1694]: INFO  [param] selected parameter default file /data/px4/param/parameters
                        Jun 22 16:32:04 m0054 voxl-px4[1694]: INFO  [parameters] BSON document size 1574 bytes, decoded 1574 bytes (INT32:38, FLOAT:41)
                        Jun 22 16:32:05 m0054 voxl-px4[1694]: Starting IMU driver with no rotation
                        Jun 22 16:32:05 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'icm42688p start -s'
                        Jun 22 16:32:05 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 10807584, local time: 10810584
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 11842132, local time: 11842794
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: muorb aggregator thread running
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] muorb protobuf initalize method succeeded
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread test_MUORB
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] muorb test passed
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: ______  __   __    ___
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: | ___ \ \ \ / /   /   |
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: | |_/ /  \ V /   / /| |
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: |  __/   /   \  / /_| |
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: | |     / /^\ \ \___  |
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: \_|     \/   \/     |_/
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: px4 starting.
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic log_message
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [parameters] Starting param sync THREAD
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Starting param sync THREAD
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: before starting the qshell_entry task
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread qshell
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell entry.....
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Init app map initialized
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: after starting the qshell_entry task
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic parameter_update
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [logger] logger started (mode=all)
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: icm42688p start -s
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'icm42688p'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = '-s'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_accel
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_gyro
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: ICM42688P::probe successful!
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: on SPI bus 1
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: >>> ICM42688P this: 3176a170
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: icm42688p start -s
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic qshell_retval
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Register interrupt b21d2fd8 e620e69c 3176a170
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic imu_server
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'icp101xx'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = '-I'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg3 = '-b'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg4 = '5'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: icp101xx #0 on I2C bus 5
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:  address 0x63
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: modal_io staINFO  [qshell] Send cmd: 'modal_io start'
                        Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 11942515, local time: 11944227
                        Jun 22 16:32:07 m0054 voxl-px4[1694]: Starting Spektrum RC
                        Jun 22 16:32:07 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'spektrum_rc start'
                        Jun 22 16:32:07 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 12975221, local time: 12976016
                        Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
                        Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14012890, local time: 14013491
                        Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'sensors start'
                        Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14131660, local time: 14133694
                        Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'ekf2 start'
                        Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14424847, local time: 14427135
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_pos_control start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14566613, local time: 14567757
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: rt
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'modal_io'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_outputs
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: modal_io start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Opened UART ESC device
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic esc_status
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_baro
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097647
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'voxlpm'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = '-X'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg3 = '-b'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg4 = '2'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Set i2c address 0x6a, fd 1
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Set i2c address 0x44, fd 1
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic battery_status
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:  (external)
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:  address 0x44
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic power_monitor
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: sensors start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'sensors'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_selection
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensors_status_imu
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_acceleration
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_angular_velocity
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_combined
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_air_data
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_gps_position
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_imu
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_imu_status
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: sensors start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: ekf2 start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'ekf2'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensors_status_baro
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_attitude
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_local_position
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_event_flags
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_innovation_variances
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_innovations
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_sensor_bias
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_states
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_status_flags
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: ekf2 start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic ekf2_timestamps
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_odometry
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic takeoff_status
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_att_contINFO  [qshell] Send cmd: 'mc_att_control start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14621967, local time: 14624142
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_rate_control start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14736644, local time: 14738248
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14786154, local time: 14787537
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14829945, local time: 14831904
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'land_detector start multicopter'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14883595, local time: 14885803
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'manual_control start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14945246, local time: 14948051
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'control_allocator start'
                        Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15219636, local time: 15220809
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'rc_update start'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15478931, local time: 15481033
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'commander start'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15718620, local time: 15720616
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: rol start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_att_control start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic rate_ctrl_status
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic autotune_attitude_control_status
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'land_detector'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = 'multicopter'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_land_detected
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: manual_control start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'manual_control'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: manual_control start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic manual_control_setpoint
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: control_allocator start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'control_allocator'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic control_allocator_status
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_motors
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_servos
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_servos_trim
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: control_allocator start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: rc_update start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'rc_update'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: rc_update start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: commander start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'commander'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread commander
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097643
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic led_control
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic tune_control
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: commander start
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic event
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic health_report
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic failsafe_flags
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_armed
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_control_mode
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_status
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic failure_detector_status
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_local_posINFO  [qshell] Send cmd: 'commander mode manual'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15753909, local time: 15755266
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'param_set_selector start'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15788509, local time: 15790356
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'flight_mode_manager start'
                        Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15961043, local time: 15962774
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: ition_setpoint
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: commander mode manual
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'commander'
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'mode'
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = 'manual'
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_command
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: commander mode manual
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_command_ack
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: param_set_selector start
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'param_set_selector'
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: param_set_selector start
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_controls_status_0
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic transponder_report
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] partner IP: 127.0.0.1
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic timesync_status
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic mavlink_log
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: ERROR [muorb] SLPI: Preflight Fail: low battery
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic home_position
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [px4] Startup script returned successfully
                        Jun 22 16:32:12 m0054 voxl-px4[1694]: [48.0K blob data]
                        E 1 Reply Last reply 30 Jun 2023, 16:52 Reply Quote 0
                        • E
                          @Benjamin-Ruks This shows that GPS has been selected as NONE so it won't try to set up the LED, magnetometer, or GPS. That will have to be changed to HOLYBRO. You can directly modify the file /etc/modalai/voxl-px4.conf to change that value.
