    Failed to resolve DNS
    1110
    • wilkinsafW
      wilkinsaf ModalAI Team
      Getting a lot of DNS errors when using the Quectel 5G hat
      here is one from tailscale
      - not logged in, last login error=fetch control key: Get "https://controlplane.tailscale.com/key?v=63": failed to resolve "controlplane.tailscale.com": no DNS fallback candidates remain for "controlplane.tailscale.com"
      I believe this is more of a Ubuntu issue than a modalai issue, but I thought I would track my progress here incase anyone else has issues
      • wilkinsafW
        seems like it is coming from resolvconf program
        wilkinsafW 1 Reply Last reply Reply Quote 0
        • wilkinsafW
          wilkinsaf ModalAI Team @wilkinsaf
          busybox udhcpc client might be the culprit
          https://unix.stackexchange.com/questions/174349/what-overwrites-etc-resolv-conf-on-every-boot
            tom admin @wilkinsaf
            @wilkinsaf I've had to use this script for some of the modem workflows in the past:
            https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/blob/master/scripts/enable-dns.sh
            • wilkinsafW
              wilkinsaf ModalAI Team @tom
              @tom Gotcha, thanks! I was trying to figure out how to do it straight from the get go instead of a patch, but this is probably fine.
              Did you end up throwing it in a service file? wondering if I should create a script to wait for a ping to succeed and then activate the dns
                @wilkinsaf Oh actually it does get called in the VOXL1 + quectel workflow it seems: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/blob/master/scripts/voxl-modem-start#L200
                but not the VOXL2 flow
                • wilkinsafW
                  @tom here is a question...for voxl2 what should i set my modem to be if it is through quectel? Do i set it to "v2"?
                    @wilkinsaf It should be set to "quectel", you can use voxl-configure-modem to setup the config file
                    • wilkinsafW
                      @tom out of curiosity what is v2 for? is that the sierra wireless hat?
                        @wilkinsaf Yup, this guy: https://www.modalai.com/products/voxl-lte?variant=39300535681075
