    How to load parameters
    Sentinel
    1837
    • Paul CarffP
      Paul Carff
      I want to fly the sentinel indoors in my warehouse. I figure I need to change some params in QGC, not sure how to do that using the GitLab data:
      https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master
      Is there a procedure for house to use these param files? Will this over write only the params in the file?
        Eric Katzfey ModalAI Team @Paul Carff
        @Paul-Carff Yes, you would use the load from file option. Only the parameters in the file will be touched. All other parameters will remain the same. PX4 has defaults for all of the parameters built into the actual software image. When you start modifying parameters (changing them from their default values) PX4 will store those new values in the file /data/px4/param/parameters. So, for example, if you calibrate the magnetometer, the calibration parameters will be put into that file. You can always start from scratch by deleting that file and restarting PX4.
        • Paul CarffP
          Paul Carff
          Thanks for the confirmation.
          • Paul CarffP
            Paul Carff
            Where is the best place to learn about all of the parameters and their meaning/use?
              @Paul-Carff https://docs.px4.io/main/en/advanced_config/parameter_reference.html
              • Paul CarffP
                Paul Carff
                @Eric-Katzfey Perfect - thank you
                Paul CarffP 1 Reply Last reply Reply Quote 0
                • Paul CarffP
                  Paul Carff @Paul Carff
                  @Paul-Carff
                  Which params v do I use :
                  Here is what I am currently running:
                    @Paul-Carff Use the v1.12 parameters
                    • Paul CarffP
                      Paul Carff
                      @Eric-Katzfey Thank you.
                      • Paul CarffP
                        @Paul-Carff I have upgraded to voxl2_sdk1.0.0 onto my Sentinel.
                        I believe this SDK uses px4 version is 1.14 Should I be using the v1.14 params now?
                          @Paul-Carff Yep, use 1.14 parameters for SDK 1.0.0.
                          • Paul CarffP
                            Paul Carff @Eric Katzfey
