  2. VOXL Dev Drones
  3. Sentinel
  4. How to load parameters
Scheduled Pinned Locked Moved Sentinel
12 Posts 2 Posters 2.1k Views 1 Watching
  • Paul CarffP Offline
    Paul CarffP Offline
    Paul Carff
    wrote on last edited by Paul Carff
    I want to fly the sentinel indoors in my warehouse. I figure I need to change some params in QGC, not sure how to do that using the GitLab data:
    https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/tree/master
    Is there a procedure for house to use these param files? Will this over write only the params in the file?
    • Paul CarffP Paul Carff
      Eric KatzfeyE Online
      @Paul-Carff Yes, you would use the load from file option. Only the parameters in the file will be touched. All other parameters will remain the same. PX4 has defaults for all of the parameters built into the actual software image. When you start modifying parameters (changing them from their default values) PX4 will store those new values in the file /data/px4/param/parameters. So, for example, if you calibrate the magnetometer, the calibration parameters will be put into that file. You can always start from scratch by deleting that file and restarting PX4.
        Paul CarffP Offline
        Paul Carff
        Thanks for the confirmation.
          Paul CarffP Offline
          Paul Carff
          Where is the best place to learn about all of the parameters and their meaning/use?
            @Paul-Carff https://docs.px4.io/main/en/advanced_config/parameter_reference.html
              Paul CarffP Offline
              Paul Carff
              @Eric-Katzfey Perfect - thank you
              Paul CarffP 1 Reply Last reply
                Paul CarffP Offline
                Paul CarffP Offline
                Paul Carff
                @Paul-Carff
                Which params v do I use :
                Here is what I am currently running:
                  @Paul-Carff
                  @Paul-Carff Use the v1.12 parameters
                    Paul CarffP Offline
                    Paul Carff
                    @Eric-Katzfey Thank you.
                      Paul CarffP Offline
                      Paul CarffP Offline
                      Paul Carff
                      @Paul-Carff I have upgraded to voxl2_sdk1.0.0 onto my Sentinel.
                      I believe this SDK uses px4 version is 1.14 Should I be using the v1.14 params now?
                        @Paul-Carff Yep, use 1.14 parameters for SDK 1.0.0.
                          Paul CarffP Offline
                          Paul CarffP Offline
                          Paul Carff
