  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. GPS Not OK with VOXL2 PX4
18 Posts 5 Posters 3.5k Views 2 Watching
  • kp ngK Offline
    kp ngK Offline
    kp ng
    Hi.
    I am unable to get set up the GPS unit which came with the VOXL2 flight deck I purchased.
    muorb SLPI: UBX CFG-GNSS message ACK failed
    muorb SLPI: status: NOT OK, port:6, baudrate: 0
    Would appreciate some help.
    • kp ngK kp ng
      Hi.
      @kp-ng What GPS unit are you trying to use? Try going in to the file /etc/modalai/voxl-px4.config and changing the command qshell gps start -d 7 -b 115200 to qshell gps start and see if that solves the issue.
      • kp ngK Offline
        kp ngK Offline
        kp ng
        The GPS module says M8N.
        I bought it a couple of months ago under the VOXL2 flight deck.
        I have tried "qshell gps start". No it doesnt resolve the issue.
        • kp ngK kp ng
          @kp-ng Can you send a picture of the setup? Did you have to create a custom cable to attach the GPS unit to the VOXL2?
          kp ngK 1 Reply Last reply
            kp ngK Offline
            kp ngK Offline
            kp ng
            unnamed.jpg |
            Eric KatzfeyE VinnyV 2 Replies Last reply
            • kp ngK kp ng
              unnamed.jpg |
              @kp-ng Okay, thanks for that. Looks pretty much like the standard setup for GPS / Mag / LED. Is the magnetometer working correctly? And the LED on the top of the unit?
              • kp ngK kp ng
                unnamed.jpg |
                Hi @kp-ng
                Eric has you covered with all SW.
                A small tip: From what I see in your picture, please understand that if you have WiFi and GPS antennas next to that very large power supply and no space between them, your radio link performance will be terrible.
                There is a good chance you will not pick up any satellites, and your WiFi link will disconnect often.
                For optimal performance, try to mimic the spatial separation that you would expect to see on one of our drone platforms.
                kp ngK J 2 Replies Last reply
                • VinnyV Vinny
                  Hi @kp-ng
                  kp ngK Offline
                  kp ngK Offline
                  kp ng
                  Thanks. I doubt it is the hardware that is not working. The GPS fix indicator on the module is blinking blue.
                  How do I check that the VOXL2 is talking to the GPS module correctly?
                  Is there a command to see the GPS location readings on VOXL2?
                    kp ngK Offline
                    kp ngK Offline
                    kp ng
                    @Eric-Katzfey Yes. The magnetometer is working correctly. QGC display indicator suggests so.
                    The LED also blinking GPS lock
                    • kp ngK kp ng
                      kp ngK Offline
                      kp ngK Offline
                      kp ng
                      I get an error message
                      "[muorb] SLPI: UBX CFG-GNSS message ACK failed".
                      • kp ngK kp ng
                        @kp-ng That's interesting. That indicates that the driver was able to successfully send a few configuration messages to the GPS unit and receive valid acknowledgements in return. Does it always print that exact same message or is it sometimes different? My guess is that the cable or connector has a defect of some sort and that makes the serial communication link over the UART unreliable. That same cable has the i2c bus used for the LED and magnetometer drivers and that appears to be working okay. Can you jiggle the cable or try to press it in with your hand while starting px4 and see if that changes the behavior? Regardless, it seems like we will need to send you a replacement GPS (Hoping, of course, that it is a problem with the GPS unit and not the connector).
                        Eric KatzfeyE kp ngK 2 Replies Last reply
                          @Eric-Katzfey I would also try Vinnies suggestion and spread all of the components out just to make sure that there isn't some interference that is causing the errors on the serial lines.
                            kp ngK Offline
                            kp ngK Offline
                            kp ng
                            @Eric-Katzfey Thanks Eric, Vinn.
                            Here are the detailed debug info.
                            Send cmd: 'gps start'
                            cannot reset all parameters on client side
                            px4io read failed
                            px4io io_reg_get(0,0,1): data error -5
                            IO not installed
                            Detection attempt failed
                            Failed to execute command px4io detect
                            command failed
                            • kp ngK kp ng
                              px4io read failed
                              IO not installed
                              command failed
                              @kp-ng That is not a full listing of all of the output. And what about the error message you had posted previously. I asked if you saw the same error every time. Do you? Or does it change to different ones? Did you do the other things suggested?
                                kp ngK Offline
                                kp ngK Offline
                                kp ng
                                Hi Eric.
                                Yes the same error messages occur each time.
                                Have tried pressing on the connector as well. Doesn't help.
                                Have spaced the power supply, wifi, gps antenna apart also.
                                Below are the logs
                                voxl2:/$ voxl-px4
                                Found DSP signature file
                                INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
                                INFO [px4] assuming working directory is rootfs, no symlinks needed.
                                | ___ \ \ \ / / / |
                                | |/ / \ V / / /| |
                                | __/ / \ / /
                                | | / /^\ \ ___ |
                                _| / / |_/
                                px4 starting.
                                INFO [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
                                Running on M0054
                                INFO [muorb] SLPI: Creating qurt thread hpwork
                                INFO [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 82
                                INFO [muorb] SLPI: Creating qurt thread lpwork
                                INFO [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 81
                                INFO [muorb] SLPI: Creating qurt thread wkr_hrt
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 80
                                INFO [muorb] SLPI: Creating qurt thread client_sync_thread
                                INFO [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 79
                                INFO [muorb] SLPI: Creating qurt thread wq_manager
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 78
                                INFO [muorb] SLPI: Creating qurt thread qshell
                                INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 77
                                INFO [qshell] Send cmd: 'icm42688p start -s'
                                INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                                INFO [muorb] SLPI: qshell gotten: icm42688p start -s
                                INFO [muorb] SLPI: Creating qurt thread wq_SPI1
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
                                INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                                INFO [uorb] Advertising remote topic sensor_accel
                                INFO [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                                INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
                                INFO [uorb] Advertising remote topic sensor_gyro
                                INFO [uorb] Advertising remote topic imu_server
                                INFO [muorb] SLPI: on SPI bus 1
                                INFO [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
                                INFO [muorb] SLPI:
                                INFO [muorb] SLPI: Ok executing command: icm42688p start -s
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 41957598, current timestamp 41957599
                                INFO [uorb] Advertising remote topic qshell_retval
                                INFO [qshell] qshell return value timestamp: 41957598, local time: 41959528
                                INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                                ERROR [muorb] SLPI: Cannot reset all parameters on client side
                                INFO [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                                INFO [muorb] SLPI: Advertising remote topic parameter_update
                                INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
                                INFO [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                                INFO [logger] logger started (mode=all)
                                Starting Holybro magnetometer
                                INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                                INFO [muorb] SLPI: Creating qurt thread wq_I2C1
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 75
                                INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                                INFO [muorb] SLPI: ist8310 #0 on I2C bus 1 (external)
                                INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44022129, current timestamp 44022130
                                INFO [qshell] qshell return value timestamp: 44022129, local time: 44028451
                                Starting Holybro LED driver
                                INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                                INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                                INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                                INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1 (external)
                                INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44071605, current timestamp 44071606
                                INFO [qshell] qshell return value timestamp: 44071605, local time: 44073373
                                INFO [qshell] Send cmd: 'icp10100 start -I -b 5'
                                INFO [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
                                INFO [muorb] SLPI: Creating qurt thread wq_I2C5
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 74
                                INFO [muorb] SLPI: *** I2C Device ID 0x9c6329 10249001
                                INFO [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
                                INFO [muorb] SLPI: icp10100 #0 on I2C bus 5
                                INFO [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44119538, current timestamp 44119540
                                INFO [qshell] qshell return value timestamp: 44119538, local time: 44120763
                                INFO [uorb] Advertising remote topic sensor_mag
                                INFO [qshell] Send cmd: 'modalai_esc start'
                                INFO [muorb] SLPI: qshell gotten: modalai_esc start
                                INFO [muorb] SLPI: Creating qurt thread wq_hp_default
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
                                INFO [uorb] Advertising remote topic test_motor
                                INFO [uorb] Advertising remote topic sensor_baro
                                INFO [muorb] SLPI: Ok executing command: modalai_esc start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44170549, current timestamp 44170550
                                INFO [muorb] SLPI: Opened UART ESC device
                                INFO [qshell] qshell return value timestamp: 44170549, local time: 44172188
                                INFO [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
                                INFO [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
                                INFO [muorb] SLPI: Creating qurt thread wq_rate_ctrl
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 71
                                INFO [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44239985, current timestamp 44239986
                                INFO [qshell] qshell return value timestamp: 44239985, local time: 44241616
                                INFO [uorb] Advertising remote topic actuator_outputs
                                INFO [uorb] Advertising remote topic multirotor_motor_limits
                                INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
                                INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                                INFO [muorb] SLPI: Creating qurt thread wq_I2C2
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4169
                                INFO [muorb] SLPI: *** I2C Device ID 0x784411 7881745
                                INFO [uorb] Advertising remote topic battery_status
                                INFO [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
                                INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44301919, current timestamp 44301920
                                INFO [qshell] qshell return value timestamp: 44301919, local time: 44302736
                                INFO [uorb] Advertising remote topic power_monitor
                                Starting Holybro GPS
                                INFO [qshell] Send cmd: 'gps start'
                                INFO [muorb] SLPI: qshell gotten: gps start
                                INFO [muorb] SLPI: Creating qurt thread gps
                                INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 70
                                INFO [muorb] SLPI: Ok executing command: gps start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44356373, current timestamp 44356374
                                INFO [qshell] qshell return value timestamp: 44356373, local time: 44357420
                                INFO [uorb] Advertising remote topic gps_dump
                                INFO [qshell] Send cmd: 'px4io detect'
                                INFO [muorb] SLPI: qshell gotten: px4io detect
                                INFO [muorb] SLPI: serial port fd 2
                                ERROR [muorb] SLPI: px4io read failed
                                ERROR [muorb] SLPI: px4io io_reg_get(0,0,1): data error -5
                                ERROR [muorb] SLPI: IO not installed
                                ERROR [muorb] SLPI: Detection attempt 2 failed
                                ERROR [muorb] SLPI: Detection attempt 1 failed
                                ERROR [muorb] SLPI: Detection attempt 0 failed
                                ERROR [muorb] SLPI: Failed to execute command: px4io detect
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44408878, current timestamp 44408879
                                INFO [qshell] cmd returned with: -17
                                INFO [qshell] qshell return value timestamp: 44408878, local time: 44416905
                                ERROR [qshell] Command failed
                                M0065 not detected, starting Spektrum RC driver
                                INFO [qshell] Send cmd: 'spektrum_rc start -d 8'
                                INFO [muorb] SLPI: qshell gotten: spektrum_rc start -d 8
                                INFO [muorb] SLPI: Creating qurt thread spektrum_rc_main
                                INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 67
                                INFO [muorb] SLPI: Ok executing command: spektrum_rc start -d 8
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 44459706, current timestamp 44459708
                                INFO [qshell] qshell return value timestamp: 44459706, local time: 44463848
                                INFO [qshell] Send cmd: 'sensors start'
                                INFO [muorb] SLPI: qshell gotten: sensors start
                                INFO [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 66
                                INFO [muorb] SLPI: Ok executing command: sensors start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 45536132, current timestamp 45536133
                                INFO [uorb] Advertising remote topic vehicle_angular_acceleration
                                INFO [qshell] qshell return value timestamp: 45536132, local time: 45537985
                                INFO [uorb] Advertising remote topic vehicle_angular_velocity
                                INFO [muorb] SLPI: Creating qurt thread wq_INS0
                                INFO [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 65
                                INFO [uorb] Advertising remote topic vehicle_imu
                                INFO [uorb] Advertising remote topic vehicle_imu_status
                                INFO [uorb] Advertising remote topic sensors_status_imu
                                INFO [uorb] Advertising remote topic vehicle_acceleration
                                INFO [uorb] Advertising remote topic vehicle_air_data
                                INFO [qshell] Send cmd: 'ekf2 start'
                                INFO [muorb] SLPI: qshell gotten: ekf2 start
                                INFO [uorb] Advertising remote topic vehicle_magnetometer
                                INFO [uorb] Advertising remote topic sensor_preflight_mag
                                INFO [uorb] Advertising remote topic sensor_selection
                                INFO [uorb] Advertising remote topic sensor_combined
                                ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for EKF2_ASP_DELAY
                                INFO [muorb] SLPI: Ok executing command: ekf2 start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 45782283, current timestamp 45782283
                                INFO [qshell] qshell return value timestamp: 45782283, local time: 45784731
                                ERROR [muorb] SLPI: 0 - vehicle_magnetometer lost, generation 0 -> 8
                                INFO [uorb] Advertising remote topic ekf2_timestamps
                                INFO [qshell] Send cmd: 'mc_pos_control start'
                                INFO [muorb] SLPI: qshell gotten: mc_pos_control start
                                INFO [muorb] SLPI: Ok executing command: mc_pos_control start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 45833887, current timestamp 45833888
                                INFO [qshell] qshell return value timestamp: 45833887, local time: 45834370
                                INFO [qshell] Send cmd: 'mc_att_control start'
                                INFO [muorb] SLPI: qshell gotten: mc_att_control start
                                INFO [muorb] SLPI: Ok executing command: mc_att_control start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 45897359, current timestamp 45897360
                                INFO [qshell] qshell return value timestamp: 45897359, local time: 45898791
                                INFO [qshell] Send cmd: 'mc_rate_control start'
                                INFO [muorb] SLPI: qshell gotten: mc_rate_control start
                                INFO [muorb] SLPI: Ok executing command: mc_rate_control start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 45969574, current timestamp 45969574
                                INFO [qshell] qshell return value timestamp: 45969574, local time: 45971046
                                INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                                INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
                                INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 46028199, current timestamp 46028200
                                INFO [qshell] qshell return value timestamp: 46028199, local time: 46028634
                                INFO [qshell] Send cmd: 'land_detector start multicopter'
                                INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
                                INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
                                INFO [muorb] SLPI: Sending qshell retval with timestamp 46072642, current timestamp 46072643
                                INFO [qshell] qshell return value timestamp: 46072642, local time: 46073625
                                INFO [uorb] Advertising remote topic vehicle_land_detected
                                INFO [muorb] SLPI: 46371633: reset position to last known position
                                INFO [muorb] SLPI: 46371633: reset velocity to zero
                                INFO [uorb] Advertising remote topic vehicle_local_position
                                INFO [uorb] Advertising remote topic vehicle_odometry
                                INFO [uorb] Advertising remote topic estimator_states
                                INFO [uorb] Advertising remote topic estimator_status
                                INFO [uorb] Advertising remote topic estimator_status_flags
                                INFO [uorb] Advertising remote topic estimator_innovations
                                INFO [uorb] Advertising remote topic estimator_innovation_test_ratios
                                INFO [uorb] Advertising remote topic estimator_innovation_variances
                                INFO [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
                                INFO [uorb] Advertising remote topic estimator_sensor_bias
                                INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet
                                INFO [muorb] SLPI: Advertising remote topic mission
                                INFO [commander] LED: open /dev/led0 failed (22)
                                INFO [muorb] SLPI: Advertising remote topic led_control
                                INFO [muorb] SLPI: Advertising remote topic tune_control
                                INFO [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
                                INFO [muorb] SLPI: Advertising remote topic vehicle_control_mode
                                INFO [muorb] SLPI: Advertising remote topic vehicle_status
                                INFO [muorb] SLPI: Advertising remote topic actuator_armed
                                INFO [muorb] SLPI: Advertising remote topic commander_state
                                INFO [uorb] Advertising remote topic rate_ctrl_status
                                INFO [uorb] Advertising remote topic actuator_controls_0
                                INFO [muorb] SLPI: Advertising remote topic vehicle_status_flags
                                INFO [muorb] SLPI: Advertising remote topic vehicle_command
                                INFO [commander] Handling Commander command 176
                                INFO [muorb] SLPI: Advertising remote topic vehicle_command_ack
                                INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
                                INFO [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                                ERROR [muorb] SLPI: UBX CFG-GNSS message ACK failed
                                INFO [muorb] SLPI: Advertising remote topic telemetry_status
                                • kp ngK kp ng
                                  Hi Eric.
                                  Below are the logs
                                  voxl2:/$ voxl-px4
                                  | ___ \ \ \ / / / |
                                  | |/ / \ V / / /| |
                                  | __/ / \ / /
                                  | | / /^\ \ ___ |
                                  _| / / |_/
                                  px4 starting.
                                  Running on M0054
                                  INFO [muorb] SLPI:
                                  @kp-ng Okay, we have never encountered this situation before. My best guess is that the GPS unit, or cable, is somehow flawed and so we will send you a new one.
                                  • Adrian HidalgoA Offline
                                    Adrian Hidalgo
                                    wrote on last edited by Adrian Hidalgo
                                    #17
                                    @kp-ng if you would please reach out to: contact@modalai.com and we would be happy to help you out regarding replacement of the gps unit.
                                    • Benjamin RuksB Benjamin Ruks referenced this topic on
                                    • VinnyV Vinny
                                      Hi @kp-ng
                                      J Offline
                                      J Offline
                                      jmltt
                                      @Vinny
                                      @Vinny said in GPS Not OK with VOXL2 PX4:
                                      Hi @kp-ng
                                      ^Can you provide an example what the ideal routing for wifi antennae would be on the sentinel drone platform (specifically with the microhard modem carrier add-on)? I came across this post while trying to troubleshoot my own issues and realized that the way I have the antennae routed coming out the back of the flight deck puts one of them right next to the gps module because of how the modem is oriented.
                                      • M majjam referenced this topic on
                                      • Chase RileyC Chase Riley referenced this topic on
