  3. missing camera config ID - VOXL board on Seeker drone
voxl
3 Posts 2 Posters 1.5k Views
  • J Offline
    J Offline
    jon
    Hi, I just reflashed the VOXL board on a Seeker development drone to 0.9.5 or whatever the exact version of the latest release was. All the other services seem to run / enable
    correctly, except voxl-camera-server throws up errors when I try to run and configure it.
    Specifically, voxl-configure-cameras returns:
    "missing camera config ID" and
    voxl-camera-server returns:
    "WARNING Failed to set priority, errno = 1
    This may be because the FIFO scheduler is not available when running in a console.
    It should work properly when run as a systemd background process on boot.
    WARNING: failed to set scheduler"
    As far as I know all the hardware on the drone should be functional, and this is right after a system image flash. Am I forgetting some part of the setup?
    -Jonathan
    • Adrian HidalgoA Offline
      Adrian Hidalgo
      @jonathankampia please run
      voxl-configure-mpa -p -f seeker -b blue -c "(either 3 for hires, tracking, stereo or c7 for TOF, hires, stereo)" --fc yes
        Adrian Hidalgo
        For the -c which is telling the Voxl board which cameras to expect, choose either 3 or 7 depending on your camera config.
