<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[missing camera config ID - VOXL board on Seeker drone]]></title><description><![CDATA[<p dir="auto">Hi, I just reflashed the VOXL board on a Seeker development drone to 0.9.5 or whatever the exact version of the latest release was. All the other services seem to run / enable<br />
correctly, except voxl-camera-server throws up errors when I try to run and configure it.</p>
<p dir="auto">Specifically, <strong>voxl-configure-cameras</strong> returns:</p>
<p dir="auto">"missing camera config ID" and</p>
<p dir="auto"><strong>voxl-camera-server</strong> returns:</p>
<p dir="auto">"WARNING Failed to set priority, errno = 1<br />
This may be because the FIFO scheduler is not available when running in a console.<br />
It should work properly when run as a systemd background process on boot.<br />
WARNING: failed to set scheduler"</p>
<p dir="auto">As far as I know all the hardware on the drone should be functional, and this is right after a system image flash. Am I forgetting some part of the setup?</p>
<p dir="auto">Thanks<br />
-Jonathan</p>
]]></description><link>https://forum.modalai.com/topic/2229/missing-camera-config-id-voxl-board-on-seeker-drone</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 07:36:43 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2229.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Jun 2023 19:10:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to missing camera config ID - VOXL board on Seeker drone on Tue, 06 Jun 2023 20:03:56 GMT]]></title><description><![CDATA[<p dir="auto">For the -c which is telling the Voxl board which cameras to expect, choose either 3 or 7 depending on your camera config.</p>
]]></description><link>https://forum.modalai.com/post/10396</link><guid isPermaLink="true">https://forum.modalai.com/post/10396</guid><dc:creator><![CDATA[Adrian Hidalgo]]></dc:creator><pubDate>Tue, 06 Jun 2023 20:03:56 GMT</pubDate></item><item><title><![CDATA[Reply to missing camera config ID - VOXL board on Seeker drone on Tue, 06 Jun 2023 19:57:24 GMT]]></title><description><![CDATA[<p dir="auto">@jonathankampia please run</p>
<pre><code>voxl-configure-mpa -p -f seeker -b blue -c "(either 3 for hires, tracking, stereo or c7 for TOF, hires, stereo)" --fc yes
]]></description><link>https://forum.modalai.com/post/10394</link><guid isPermaLink="true">https://forum.modalai.com/post/10394</guid><dc:creator><![CDATA[Adrian Hidalgo]]></dc:creator><pubDate>Tue, 06 Jun 2023 19:57:24 GMT</pubDate></item></channel></rss>
