    voxl Tmotor f55 esc
    ESCs
    3741
    • bensusanaB
      bensusana
      should is use same firmware / params located here :https://docs.modalai.com/modal-esc-v2-manual/
      for the tmotor esc?
      or you have dedicated procedure for it
      bensusanaB 1 Reply Last reply Reply Quote 0
      • bensusanaB
        bensusana @bensusana
        @bensusana @Chad-Sweet @Alex-Kushleyev
          Alex Kushleyev ModalAI Team
          Hello Ben,
          The Tmotor ESC with ModalAI firmware supports the same protocol as all of our other ESCs. This means you can use voxl-esc tools to test and calibrate the ESC (https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/master/voxl-esc-tools).
          The firmware that is already loaded on your Tmotor ESC should be this one : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/firmware/modalai_esc_firmware_tmotor_f55a_pro_ii_4_in_1_revc_24khz_20230214.bin (firmware hash: ba6d193a, which can be checked using voxl-esc-scan.py script (part of voxl-esc package).
          The params that we use for this ESC are here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-params/FPV_RevB/FPV_RevB.xml -- they are tuned for 6S battery, Xing2 2207 1855kV motor with a 5.1x4.1x3 HQ prop.
          Have you already interfaced to the ESC using voxl-esc tools or do you need help? Do you have a proper connector for making a serial to USB adapter? Let me know if you need help with next steps. (I am not sure how much experience you already have with our ESCs)
          • M
            mzahana
            Hi @bensusana
            Could you please provide a link to the Tmotor ESC you refer to?
            • E
              ErezI @Alex Kushleyev
              Alex Hi,
              We tried using the same voxl-esc tools to communicate with the F55A ESC, but could not succeed.
              I show that the baud rate is different (2,000,000 and not 250,000 bps),
              but using automatic connectivity tool (different bps) did not change the connectivity status.
              Do we need to change the baud rate explicitly?
              I saw that you have now slpi-uart bridge support.
              Can we use it to communicate the ESC from the VOXL2 (via python ver 3 only?)?
              Erez
                Hello @ErezI,
                Can you please describe your setup? Specifically, in your first test, how are you connecting to the Tmotor ESC and where are you running voxl-esc tools? (on your PC or VOXL2 ?). Did you make your own cable for UART communication?
                ./voxl-esc-scan.py command will automatically try all typical baud rates, including 2Mbit and should detect the Tmotor ESC.
                • E
                  Hi Alex,
                  Using the same system (PC with Ubuntu OS & voxl-esc-tools, connected directly via FTDI 3.3v to the previous ESC V2, Seeker_V1_tmotor_f2203_1500kv_Param_Rev_A) we succeed to connect, control (spin for example), calibrate and update the xml parameters in the ESC.
                  The differences are the ESC connectors & relevant pins (RX, TX, GND). and the BAUD rate.
                  The same system connected to the f2203 ESC - works,
                  while connected to the F55A - fails.
                  So we know (succeed) how to work and to configure ESCs using your ESC tools.
                  Using a Wireshark sniffer (USB sniffer) I see transactions (command and response) between the two sides (PC & F55A ESC), but no ESC identified.
                  Can you send the interface protocol between the two sides, so I can understand the transactions?
                  Is it possible that we got ESCs without any firmware?
                  I tried to update the firmware/parameters also - but with a failure.
                  Erez
                  Do you have
                    Do the ESCs make motor sounds when powered on? Should be similar sound as our standard ESCs. If so, then there is ESC firmware loaded.
                    Can you please share which FTDI adapter you are using?
                    I can add a debug mode to voxl-esc tools to print out what it is sending and receiving, this may help. I will follow up tomorrow.
                    There is also C++ code example you can use for basic testing, i will share that shortly.
                    • E
                      Alex,
                      We use FTDI C232HD-DDHSP-0 & TTL-232RG-vsw3v3-we
                        Hello @ErezI ,
                        I have added a debug functionality to a new feature branch which i have been working on. https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/add-new-params . This branch has some changes to support upcoming ESC param updates, but it is also functional to test the ESCs (except reading and writing params - don't try it 🙂 ). We can use it to help debug your issue.
                        You can checkout the code from the add-new-params branch and try the following test with your Tmotor ESC. You will see that the ESCs are queried twice, but that is ok, it is part of the procedure (kind of redundant, but it's fine 🙂 ).
                        Each data packet (outgoing and incoming starts with a header 0xAF) and ends with a two-byte checksum.
                        In my case i am using a STLInk-V3 dongle as a serial to USB adapter.
                        ./voxl-esc-scan.py --enable-debug 1
                        Detected Python version : 3.10.6 (main, Mar 10 2023, 10:55:28) [GCC 11.3.0]
                        INFO: All COM ports:
                        	/dev/ttyACM0 : STLINK-V3 - ST-Link VCP Ctrl
                        INFO: UART Port Candidates:
                        	/dev/ttyACM0
                        Found previous connection information in .voxl_esc_cache ..
                        Prioritizing /dev/ttyACM0 @ 2000000
                        INFO: Scanning for ESC firmware: /dev/ttyACM0, baud: 2000000
                        	UART TX:  AF 06 00 00 91 C1
                        	UART TX:  AF 06 18 00 9B C1
                        	UART RX:  AF 0E 6D 00 25 00 21 00 00 00 00 00 64 DE AF 30 83 00 25 00 21 00 5D 00 46 00 17 50 32 53 34 35 34 20 62 61 36 64 31 39 33 61 2A 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 1B C5
                        	PACKET CRC OK:  AF 0E 6D 00 25 00 21 00 00 00 00 00 64 DE
                        	PACKET CRC OK:  AF 30 83 00 25 00 21 00 5D 00 46 00 17 50 32 53 34 35 34 20 62 61 36 64 31 39 33 61 2A 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 1B C5
                        	Got Short Version Response from ID 0
                        	Got Extended Version Response from ID 0
                        	UART TX:  AF 06 00 01 50 01
                        	UART TX:  AF 06 18 01 5A 01
                        	UART RX:  AF 0E 6D 01 25 00 21 00 00 00 00 00
                        	UART RX:  69 4E AF 30 83 01 25 00 21 00 5D 00 38 00 17 50 32 53 34 35 34 20 64 38 32 35 63 37 38 63 00 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 14 2B
                        	PACKET CRC OK:  AF 0E 6D 01 25 00 21 00 00 00 00 00 69 4E
                        	PACKET CRC OK:  AF 30 83 01 25 00 21 00 5D 00 38 00 17 50 32 53 34 35 34 20 64 38 32 35 63 37 38 63 00 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 14 2B
                        	Got Short Version Response from ID 1
                        	Got Extended Version Response from ID 1
                        	UART TX:  AF 06 00 02 10 00
                        	UART TX:  AF 06 18 02 1A 00
                        	UART RX:  AF 0E 6D 02 25 00 21 00 00 00 00 00 7D BE AF 30 83 02 25 00 21 00 5E 00 3E 00 17 50 32 53 34 35 34 20 64 38 32 35 63 37 38 63 00 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 62 BF
                        	PACKET CRC OK:  AF 0E 6D 02 25 00 21 00 00 00 00 00 7D BE
                        	PACKET CRC OK:  AF 30 83 02 25 00 21 00 5E 00 3E 00 17 50 32 53 34 35 34 20 64 38 32 35 63 37 38 63 00 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 62 BF
                        	Got Short Version Response from ID 2
                        	Got Extended Version Response from ID 2
                        	UART TX:  AF 06 00 03 D1 C0
                        	UART TX:  AF 06 18 03 DB C0
                        	UART RX:  AF 0E 6D 03 25 00 21 00 00 00 00 00 70 2E AF 30 83 03 25 00 21 00 55 00 40 00 17 50 32 53 34 35 34 20 64 38 32 35 63 37 38 63 00 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 1D DE
                        	PACKET CRC OK:  AF 0E 6D 03 25 00 21 00 00 00 00 00 70 2E
                        	PACKET CRC OK:  AF 30 83 03 25 00 21 00 55 00 40 00 17 50 32 53 34 35 34 20 64 38 32 35 63 37 38 63 00 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 1D DE
                        	Got Short Version Response from ID 3
                        	Got Extended Version Response from ID 3
                        INFO: ESC(s) detected on port: /dev/ttyACM0, baud rate: 2000000
                        	UART RX:  AF 0E 6D 01 25 00 21 00 00 00 00 00 69 4E AF 30 83 01 25 00 21 00 5D 00 38 00 17 50 32 53 34 35 34 20 64 38 32 35 63 37 38 63 00 00 00 00 37 61 30 31 61 37 38 30 00 00 00 00 00 00 14 2B
                        INFO: Additional Information:
                        INFO: ---------------------
                        	Board      : version 33: Blheli32 4-in-1 ESC Type B (Tmotor F55A PRO G071)
                        	UID        : 0x20343534533250170046005D
                        	Firmware   : version   37, hash ba6d193a*
                        	Bootloader : version    0, hash 7a01a780
                        	UID        : 0x20343534533250170038005D
                        	Firmware   : version   37, hash d825c78c
                        	UID        : 0x2034353453325017003E005E
                        	UID        : 0x203435345332501700400055
                        Additionally, there is an open source implementation of the basic communication protocol here : https://gitlab.com/voxl-public/support/esc-driver . I am able to use it to query the Tmotor ESC:
                        git clone git@gitlab.com:voxl-public/support/esc-driver.git
                        cd esc-driver/examples
                        make
                        ./qc_esc_test 0 /dev/ttyACM0 2000000 #this will send zero power command to 4 ESCs and query feedback
                        qc_esc_test version 1.0 build date May 31 2023
                        Usage: qc_esc_test <test_mode> <device path> <baud_rate>
                        Available test modes:
                        	 0: detect esc response
                        	 1: detect esc versions
                        	 2: open-loop test
                        	 3: closed-loop RPM test
                        Trying device /dev/ttyACM0, baud rate 2000000
                        Starting Test #0
                        Detecting ESC response (sending zero RPM commands and requesting feedback)..
                        ESC response: id  1, state  0, cntr  90, pwr +000,     0RPM, 12.135V, 0.000A, 27.840C
                        ESC response: id  2, state  0, cntr 154, pwr +000,     0RPM, 12.158V, 0.000A, 27.970C
                        got esc feedback (out of 15 packets each): 15 15 15 15 0 0 0 0
                        Found 4 ESCs
                        Another thing i can think of.. Maybe FTDI chip latency is too high, you can try to reduce it to 1ms with the following command (for appropriate device, such as ttyUSB0:
                        echo 1 > /sys/bus/usb-serial/devices/ttyUSB0/latency_timer
                        Please try these out and let me know your results!
                          Alex Kushleyev ModalAI Team @mzahana
                          @mzahana , we have a limited availability of Tmotor ESC with ModalAI firmware. It is officially not supported. We are working on our own version of a 6S Racing ESC, but it is not yet ready for release. If you can describe your application, perhaps one of our existing official ESCs could work for you.
                          • E
                            Thanks for your fast & helpful support..
                            The motors sound like 3-4 successive rings when powered on.
                            Erez
                              Alex Kushleyev ModalAI Team @ErezI
                              @ErezI , OK that means the firmware is loaded. All of our ESCs come programmed and tested before shipping.
                                Hello @ErezI , did the debugging mode help you figure out the issue?
                                E Yariv LandY 3 Replies Last reply Reply Quote 0
                                • E
                                  Hi Alex,
                                  No change.
                                  I can't reduce the latency:
                                  user@ubuntu18-VBox:/mnt/ushare/voxl-esc-add-new-params/voxl-esc-tools$ sudo echo 1 > /sys/bus/usb-serial/devices/ttyUSB0/latency_timer
                                  bash: /sys/bus/usb-serial/devices/ttyUSB0/latency_timer: Permission denied
                                  user@ubuntu18-VBox:/mnt/ushare/voxl-esc-add-new-params/voxl-esc-tools$ echo 1 > /sys/bus/usb-serial/devices/ttyUSB0/latency_timer
                                  and no ESCs identified:
                                  user@ubuntu18-VBox:/mnt/ushare/voxl-esc-add-new-params/voxl-esc-tools$ ./voxl-esc-scan.py --enable-debug 1
                                  Detected Python version : 3.8.16 (default, Dec 7 2022, 01:12:13)
                                  [GCC 7.5.0]
                                  /dev/ttyUSB0 : C232HD-DDHSP-0 - C232HD-DDHSP-0
                                  ERROR: No ESC(s) detected, exiting.
                                  • Yariv LandY
                                    Yariv Land @Alex Kushleyev
                                    Hi Alex,
                                    I am working with Erez ad Ben on this project and it seems that we are hitting a wall which I assume that you are the only one who can help.
                                    I would appreciate if we will be able to contact you directly in regards to the issue in hand, I don't know if this is a setup issue, wiring issue, FTDI issue or etc - but I do hope that in a quick conference chat we will be able to overcome this.
                                    I would appreciate if you will be able to contact me through my E-mail Yariv.l@pearls.org.il to schedule a quick chat to resolve this whole issue.
                                    Appreciate your help and support,
                                    Yariv
                                    • E
                                      Hi Alex,
                                      I added my tests' info using wsl2 (no success)
                                      on windows
                                      #process0
                                      C:\Program Files\usbipd-win>usbipd server
                                      on wsl (f55a-cyclic.sh)
                                      #!/bin/bash
                                      sleep 5
                                      #proces1
                                      sudo nome-terminal -x ./auto-attach.sh 172.24.192.1 3-2
                                      sleep 3
                                      #process2
                                      sudo gnome-terminal -x watch "ls -al /dev | egrep ttyU"
                                      sleep 3
                                      #process3
                                      sudo gnome-terminal -x dmesg -W
                                      sleep 3
                                      #process4
                                      sudo gnome-terminal --working-directory=/data/voxl-esc-add-new-params/voxl-esc-tools/ -x watch "python /data/voxl-esc-add-new-params/voxl-esc-tools/voxl-esc-scan.py --enable-debug 1"
                                      sleep 30
                                      ps -a
                                      sleep 3
                                      sudo pkill -9 gnome-terminal
                                      sleep 5
                                      #process0 output
                                      info: Microsoft.Hosting.Lifetime[0]
                                      Application started. Press Ctrl+C to shut down.
                                      Hosting environment: Production
                                      Content root path: C:\Program Files\usbipd-win
                                      info: Usbipd.ConnectedClient[1]
                                      Client 172.24.199.17 claimed device at 3-2 (USB\VID_0403&PID_6001\FT4TW3LE).
                                      info: Usbipd.ConnectedClient[2]
                                      Client 172.24.199.17 released device at 3-2 (USB\VID_0403&PID_6001\FT4TW3LE).
                                      #process1 output
                                      usbip: error: Attach Request for 3-2 failed - Device not found
                                      Attached
                                      Detached
                                      Attached
                                      Detached
                                      Attached
                                      #process2 output
                                      Every 2.0s: ls -al /dev | egrep ttyU PW-CONTROL07: Wed Jun 21 17:06:16 2023
                                      crw------- 1 root root 188, 0 Jun 21 2023 ttyUSB0
                                      #process3 output
                                      [ 1892.623021] vhci_hcd vhci_hcd.0: pdev(0) rhport(0) sockfd(3)
                                      [ 1892.628241] vhci_hcd vhci_hcd.0: devid(196610) speed(2) speed_str(full-speed)
                                      [ 1892.630748] vhci_hcd vhci_hcd.0: Device attached
                                      [ 1892.914403] vhci_hcd: vhci_device speed not set
                                      [ 1892.984269] usb 1-1: new full-speed USB device number 18 using vhci_hcd
                                      [ 1893.084280] vhci_hcd: vhci_device speed not set
                                      [ 1893.164250] usb 1-1: SetAddress Request (18) to port 0
                                      [ 1893.604492] usb 1-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
                                      [ 1893.606748] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                      [ 1893.609072] usb 1-1: Product: TTL232RG-VREG3V3
                                      [ 1893.609980] usb 1-1: Manufacturer: FTDI
                                      [ 1893.610659] usb 1-1: SerialNumber: FT4TW3LE
                                      [ 1893.623736] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
                                      [ 1893.625770] usb 1-1: Detected FT232RL
                                      [ 1893.632497] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
                                      [ 1895.017816] vhci_hcd: unlink->seqnum 81017
                                      [ 1895.018495] vhci_hcd: the urb (seqnum 81017) was already given back
                                      [ 1895.019313] vhci_hcd: unlink->seqnum 81019
                                      [ 1895.019856] vhci_hcd: the urb (seqnum 81019) was already given back
                                      [ 1895.163809] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1895.164874] vhci_hcd: unlink->seqnum 81055
                                      [ 1895.165354] vhci_hcd: the urb (seqnum 81055) was already given back
                                      [ 1895.310820] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1895.311921] vhci_hcd: unlink->seqnum 81089
                                      [ 1895.312494] vhci_hcd: the urb (seqnum 81089) was already given back
                                      [ 1895.461562] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1895.464395] vhci_hcd: unlink->seqnum 81123
                                      [ 1895.466541] vhci_hcd: the urb (seqnum 81123) was already given back
                                      [ 1895.628411] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1895.630861] vhci_hcd: unlink->seqnum 81158
                                      [ 1895.632078] vhci_hcd: the urb (seqnum 81158) was already given back
                                      [ 1895.784242] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1895.785161] vhci_hcd: unlink->seqnum 81193
                                      [ 1895.785654] vhci_hcd: the urb (seqnum 81193) was already given back
                                      [ 1896.349788] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1896.350886] vhci_hcd: unlink->seqnum 81521
                                      [ 1896.351526] vhci_hcd: the urb (seqnum 81521) was already given back
                                      [ 1896.914474] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1896.915333] vhci_hcd: unlink->seqnum 82125
                                      [ 1896.915797] vhci_hcd: the urb (seqnum 82125) was already given back
                                      [ 1899.267100] vhci_hcd: unlink->seqnum 82295
                                      [ 1899.267747] vhci_hcd: the urb (seqnum 82295) was already given back
                                      [ 1899.268576] vhci_hcd: unlink->seqnum 82297
                                      [ 1899.269365] vhci_hcd: the urb (seqnum 82297) was already given back
                                      [ 1899.416402] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1899.417294] vhci_hcd: unlink->seqnum 82468
                                      [ 1899.417874] vhci_hcd: the urb (seqnum 82468) was already given back
                                      [ 1899.561474] vhci_hcd: unlink->seqnum 82634
                                      [ 1899.562043] vhci_hcd: the urb (seqnum 82634) was already given back
                                      [ 1899.562994] vhci_hcd: unlink->seqnum 82636
                                      [ 1899.563598] vhci_hcd: the urb (seqnum 82636) was already given back
                                      [ 1899.708527] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1899.710263] vhci_hcd: unlink->seqnum 82802
                                      [ 1899.711258] vhci_hcd: the urb (seqnum 82802) was already given back
                                      [ 1899.859324] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1899.860214] vhci_hcd: unlink->seqnum 82958
                                      [ 1899.860859] vhci_hcd: the urb (seqnum 82958) was already given back
                                      [ 1900.003321] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1900.004322] vhci_hcd: unlink->seqnum 83123
                                      [ 1900.004759] vhci_hcd: the urb (seqnum 83123) was already given back
                                      [ 1900.567465] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1900.568335] vhci_hcd: unlink->seqnum 83730
                                      [ 1900.568811] vhci_hcd: the urb (seqnum 83730) was already given back
                                      [ 1901.130609] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1901.131840] vhci_hcd: unlink->seqnum 84335
                                      [ 1901.132850] vhci_hcd: the urb (seqnum 84335) was already given back
                                      [ 1903.459054] vhci_hcd: unlink->seqnum 84493
                                      [ 1903.460300] vhci_hcd: the urb (seqnum 84493) was already given back
                                      [ 1903.461365] vhci_hcd: unlink->seqnum 84495
                                      [ 1903.462478] vhci_hcd: the urb (seqnum 84495) was already given back
                                      [ 1903.611008] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1903.611918] vhci_hcd: unlink->seqnum 84668
                                      [ 1903.612309] vhci_hcd: the urb (seqnum 84668) was already given back
                                      [ 1903.757928] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1903.758831] vhci_hcd: unlink->seqnum 84837
                                      [ 1903.759266] vhci_hcd: the urb (seqnum 84837) was already given back
                                      [ 1903.904994] vhci_hcd: unlink->seqnum 85001
                                      [ 1903.905570] vhci_hcd: the urb (seqnum 85001) was already given back
                                      [ 1903.906408] vhci_hcd: unlink->seqnum 85003
                                      [ 1903.906866] vhci_hcd: the urb (seqnum 85003) was already given back
                                      [ 1904.055495] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1904.056528] vhci_hcd: unlink->seqnum 85174
                                      [ 1904.057186] vhci_hcd: the urb (seqnum 85174) was already given back
                                      [ 1904.199584] vhci_hcd: unlink->seqnum 85340
                                      [ 1904.200320] vhci_hcd: the urb (seqnum 85340) was already given back
                                      [ 1904.201153] vhci_hcd: unlink->seqnum 85342
                                      [ 1904.201755] vhci_hcd: the urb (seqnum 85342) was already given back
                                      [ 1904.770065] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1904.771215] vhci_hcd: unlink->seqnum 85941
                                      [ 1904.793412] vhci_hcd: the urb (seqnum 85941) was already given back
                                      [ 1905.378980] vhci_hcd: unlink->seqnum 86540
                                      [ 1905.379524] vhci_hcd: the urb (seqnum 86540) was already given back
                                      [ 1905.380213] vhci_hcd: unlink->seqnum 86542
                                      [ 1905.380672] vhci_hcd: the urb (seqnum 86542) was already given back
                                      [ 1907.712779] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1907.713839] vhci_hcd: unlink->seqnum 86708
                                      [ 1907.714369] vhci_hcd: the urb (seqnum 86708) was already given back
                                      [ 1907.856827] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1907.857885] vhci_hcd: unlink->seqnum 86873
                                      [ 1907.858613] vhci_hcd: the urb (seqnum 86873) was already given back
                                      [ 1908.000380] vhci_hcd: unlink->seqnum 87037
                                      [ 1908.000990] vhci_hcd: the urb (seqnum 87037) was already given back
                                      [ 1908.001894] vhci_hcd: unlink->seqnum 87039
                                      [ 1908.002283] vhci_hcd: the urb (seqnum 87039) was already given back
                                      [ 1908.144051] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1908.145049] vhci_hcd: unlink->seqnum 87203
                                      [ 1908.145540] vhci_hcd: the urb (seqnum 87203) was already given back
                                      [ 1908.287037] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1908.287877] vhci_hcd: unlink->seqnum 87365
                                      [ 1908.288349] vhci_hcd: the urb (seqnum 87365) was already given back
                                      [ 1908.429762] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1908.430658] vhci_hcd: unlink->seqnum 87530
                                      [ 1908.431205] vhci_hcd: the urb (seqnum 87530) was already given back
                                      [ 1908.985317] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1908.986189] vhci_hcd: unlink->seqnum 88127
                                      [ 1908.986661] vhci_hcd: the urb (seqnum 88127) was already given back
                                      [ 1909.548749] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1909.549567] vhci_hcd: unlink->seqnum 88733
                                      [ 1909.550019] vhci_hcd: the urb (seqnum 88733) was already given back
                                      [ 1911.260690] vhci_hcd: connection closed
                                      [ 1911.261065] vhci_hcd: stop threads
                                      [ 1911.269459] vhci_hcd: release socket
                                      [ 1911.270215] vhci_hcd: disconnect device
                                      [ 1911.270792] usb 1-1: USB disconnect, device number 18
                                      [ 1911.271620] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
                                      [ 1911.272759] ftdi_sio 1-1:1.0: device disconnected
                                      [ 1919.686333] vhci_hcd vhci_hcd.0: pdev(0) rhport(0) sockfd(3)
                                      [ 1919.694426] vhci_hcd vhci_hcd.0: devid(196610) speed(2) speed_str(full-speed)
                                      [ 1919.695445] vhci_hcd vhci_hcd.0: Device attached
                                      [ 1919.974230] vhci_hcd: vhci_device speed not set
                                      [ 1920.054310] usb 1-1: new full-speed USB device number 19 using vhci_hcd
                                      [ 1920.134299] vhci_hcd: vhci_device speed not set
                                      [ 1920.204355] usb 1-1: SetAddress Request (19) to port 0
                                      [ 1920.271386] usb 1-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
                                      [ 1920.272654] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                      [ 1920.276426] usb 1-1: Product: TTL232RG-VREG3V3
                                      [ 1920.283974] usb 1-1: Manufacturer: FTDI
                                      [ 1920.284659] usb 1-1: SerialNumber: FT4TW3LE
                                      [ 1920.290771] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
                                      [ 1920.294102] usb 1-1: Detected FT232RL
                                      [ 1920.302218] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
                                      [ 1921.677956] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1921.678813] vhci_hcd: unlink->seqnum 88782
                                      [ 1921.679423] vhci_hcd: the urb (seqnum 88782) was already given back
                                      [ 1921.876417] vhci_hcd: unlink->seqnum 88820
                                      [ 1921.879762] vhci_hcd: the urb (seqnum 88820) was already given back
                                      [ 1921.881034] vhci_hcd: unlink->seqnum 88822
                                      [ 1921.882547] vhci_hcd: the urb (seqnum 88822) was already given back
                                      [ 1922.043477] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1922.044895] vhci_hcd: unlink->seqnum 88857
                                      [ 1922.047776] vhci_hcd: the urb (seqnum 88857) was already given back
                                      [ 1922.198003] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1922.199267] vhci_hcd: unlink->seqnum 88892
                                      [ 1922.201613] vhci_hcd: the urb (seqnum 88892) was already given back
                                      [ 1922.347202] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1922.348165] vhci_hcd: unlink->seqnum 88926
                                      [ 1922.348714] vhci_hcd: the urb (seqnum 88926) was already given back
                                      [ 1922.499077] vhci_hcd: unlink->seqnum 88960
                                      [ 1922.501091] vhci_hcd: the urb (seqnum 88960) was already given back
                                      [ 1922.502717] vhci_hcd: unlink->seqnum 88962
                                      [ 1922.503551] vhci_hcd: the urb (seqnum 88962) was already given back
                                      [ 1923.072953] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1923.073985] vhci_hcd: unlink->seqnum 89043
                                      [ 1923.074516] vhci_hcd: the urb (seqnum 89043) was already given back
                                      [ 1923.635175] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1923.636452] vhci_hcd: unlink->seqnum 89124
                                      [ 1923.639462] vhci_hcd: the urb (seqnum 89124) was already given back
                                      [ 1925.988300] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1925.989173] vhci_hcd: unlink->seqnum 89294
                                      [ 1925.989803] vhci_hcd: the urb (seqnum 89294) was already given back
                                      [ 1926.134048] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1926.135052] vhci_hcd: unlink->seqnum 89463
                                      [ 1926.135819] vhci_hcd: the urb (seqnum 89463) was already given back
                                      [ 1926.278682] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1926.279729] vhci_hcd: unlink->seqnum 89630
                                      [ 1926.280229] vhci_hcd: the urb (seqnum 89630) was already given back
                                      [ 1926.421818] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1926.422654] vhci_hcd: unlink->seqnum 89795
                                      [ 1926.423078] vhci_hcd: the urb (seqnum 89795) was already given back
                                      [ 1926.564779] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1926.565697] vhci_hcd: unlink->seqnum 89960
                                      [ 1926.566098] vhci_hcd: the urb (seqnum 89960) was already given back
                                      [ 1926.708525] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1926.709465] vhci_hcd: unlink->seqnum 90126
                                      [ 1926.709876] vhci_hcd: the urb (seqnum 90126) was already given back
                                      [ 1927.274337] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1927.275263] vhci_hcd: unlink->seqnum 90734
                                      [ 1927.275660] vhci_hcd: the urb (seqnum 90734) was already given back
                                      [ 1927.845187] vhci_hcd: unlink->seqnum 91344
                                      [ 1927.850883] vhci_hcd: the urb (seqnum 91344) was already given back
                                      [ 1927.851973] vhci_hcd: unlink->seqnum 91345
                                      [ 1927.852996] vhci_hcd: the urb (seqnum 91345) was already given back
                                      [ 1930.171018] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1930.171928] vhci_hcd: unlink->seqnum 91510
                                      [ 1930.172363] vhci_hcd: the urb (seqnum 91510) was already given back
                                      [ 1930.314139] vhci_hcd: unlink->seqnum 91677
                                      [ 1930.314704] vhci_hcd: the urb (seqnum 91677) was already given back
                                      [ 1930.315339] vhci_hcd: unlink->seqnum 91678
                                      [ 1930.315820] vhci_hcd: the urb (seqnum 91678) was already given back
                                      [ 1930.459077] vhci_hcd: unlink->seqnum 91844
                                      [ 1930.459613] vhci_hcd: the urb (seqnum 91844) was already given back
                                      [ 1930.460384] vhci_hcd: unlink->seqnum 91846
                                      [ 1930.460758] vhci_hcd: the urb (seqnum 91846) was already given back
                                      [ 1930.604012] vhci_hcd: unlink->seqnum 92012
                                      [ 1930.604595] vhci_hcd: the urb (seqnum 92012) was already given back
                                      [ 1930.605499] vhci_hcd: unlink->seqnum 92014
                                      [ 1930.605943] vhci_hcd: the urb (seqnum 92014) was already given back
                                      [ 1930.749651] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1930.750537] vhci_hcd: unlink->seqnum 92180
                                      [ 1930.750994] vhci_hcd: the urb (seqnum 92180) was already given back
                                      [ 1930.892499] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1930.893423] vhci_hcd: unlink->seqnum 92342
                                      [ 1930.893815] vhci_hcd: the urb (seqnum 92342) was already given back
                                      [ 1931.450515] vhci_hcd: unlink->seqnum 92942
                                      [ 1931.451036] vhci_hcd: the urb (seqnum 92942) was already given back
                                      [ 1931.451855] vhci_hcd: unlink->seqnum 92943
                                      [ 1931.452310] vhci_hcd: the urb (seqnum 92943) was already given back
                                      [ 1932.005934] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1932.007079] vhci_hcd: unlink->seqnum 93538
                                      [ 1932.008051] vhci_hcd: the urb (seqnum 93538) was already given back
                                      [ 1934.344638] vhci_hcd: unlink->seqnum 93705
                                      [ 1934.345318] vhci_hcd: the urb (seqnum 93705) was already given back
                                      [ 1934.346020] vhci_hcd: unlink->seqnum 93707
                                      [ 1934.346914] vhci_hcd: the urb (seqnum 93707) was already given back
                                      [ 1934.492421] vhci_hcd: unlink->seqnum 93877
                                      [ 1934.493007] vhci_hcd: the urb (seqnum 93877) was already given back
                                      [ 1934.493725] vhci_hcd: unlink->seqnum 93879
                                      [ 1934.494085] vhci_hcd: the urb (seqnum 93879) was already given back
                                      [ 1934.635685] vhci_hcd: unlink->seqnum 94043
                                      [ 1934.636305] vhci_hcd: the urb (seqnum 94043) was already given back
                                      [ 1934.637020] vhci_hcd: unlink->seqnum 94045
                                      [ 1934.637408] vhci_hcd: the urb (seqnum 94045) was already given back
                                      [ 1934.781906] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1934.782873] vhci_hcd: unlink->seqnum 94212
                                      [ 1934.783484] vhci_hcd: the urb (seqnum 94212) was already given back
                                      [ 1934.928139] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1934.929093] vhci_hcd: unlink->seqnum 94374
                                      [ 1934.929506] vhci_hcd: the urb (seqnum 94374) was already given back
                                      [ 1935.072487] vhci_hcd: unlink->seqnum 94540
                                      [ 1935.073073] vhci_hcd: the urb (seqnum 94540) was already given back
                                      [ 1935.073747] vhci_hcd: unlink->seqnum 94542
                                      [ 1935.074123] vhci_hcd: the urb (seqnum 94542) was already given back
                                      [ 1935.636666] vhci_hcd: unlink->seqnum 95136
                                      [ 1935.637325] vhci_hcd: the urb (seqnum 95136) was already given back
                                      [ 1935.638064] vhci_hcd: unlink->seqnum 95137
                                      [ 1935.638408] vhci_hcd: the urb (seqnum 95137) was already given back
                                      [ 1936.206561] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1936.207426] vhci_hcd: unlink->seqnum 95734
                                      [ 1936.207861] vhci_hcd: the urb (seqnum 95734) was already given back
                                      [ 1938.546194] vhci_hcd: unlink->seqnum 95901
                                      [ 1938.547045] vhci_hcd: the urb (seqnum 95901) was already given back
                                      [ 1938.547876] vhci_hcd: unlink->seqnum 95902
                                      [ 1938.548267] vhci_hcd: the urb (seqnum 95902) was already given back
                                      [ 1938.693577] vhci_hcd: unlink->seqnum 96071
                                      [ 1938.694092] vhci_hcd: the urb (seqnum 96071) was already given back
                                      [ 1938.835928] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1938.836732] vhci_hcd: unlink->seqnum 96236
                                      [ 1938.837195] vhci_hcd: the urb (seqnum 96236) was already given back
                                      [ 1938.987705] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1938.988677] vhci_hcd: unlink->seqnum 96353
                                      [ 1938.989499] vhci_hcd: the urb (seqnum 96353) was already given back
                                      [ 1939.135970] vhci_hcd: unlink->seqnum 96522
                                      [ 1939.136689] vhci_hcd: the urb (seqnum 96522) was already given back
                                      [ 1939.137357] vhci_hcd: unlink->seqnum 96523
                                      [ 1939.137810] vhci_hcd: the urb (seqnum 96523) was already given back
                                      [ 1939.281588] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1939.282484] vhci_hcd: unlink->seqnum 96689
                                      [ 1939.282888] vhci_hcd: the urb (seqnum 96689) was already given back
                                      [ 1939.845544] vhci_hcd: unlink->seqnum 97291
                                      [ 1939.846182] vhci_hcd: the urb (seqnum 97291) was already given back
                                      [ 1939.846917] vhci_hcd: unlink->seqnum 97292
                                      [ 1939.847364] vhci_hcd: the urb (seqnum 97292) was already given back
                                      [ 1940.417903] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1940.418750] vhci_hcd: unlink->seqnum 97899
                                      [ 1940.419149] vhci_hcd: the urb (seqnum 97899) was already given back
                                      [ 1942.755591] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1942.756589] vhci_hcd: unlink->seqnum 98066
                                      [ 1942.757790] vhci_hcd: the urb (seqnum 98066) was already given back
                                      [ 1942.911059] vhci_hcd: unlink->seqnum 98221
                                      [ 1942.922839] vhci_hcd: the urb (seqnum 98221) was already given back
                                      [ 1942.924368] vhci_hcd: unlink->seqnum 98222
                                      [ 1942.925054] vhci_hcd: the urb (seqnum 98222) was already given back
                                      [ 1943.070474] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1943.071268] vhci_hcd: unlink->seqnum 98389
                                      [ 1943.071663] vhci_hcd: the urb (seqnum 98389) was already given back
                                      [ 1943.214148] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1943.215327] vhci_hcd: unlink->seqnum 98555
                                      [ 1943.216018] vhci_hcd: the urb (seqnum 98555) was already given back
                                      [ 1943.357497] vhci_hcd: unlink->seqnum 98720
                                      [ 1943.358063] vhci_hcd: the urb (seqnum 98720) was already given back
                                      [ 1943.358735] vhci_hcd: unlink->seqnum 98721
                                      [ 1943.359371] vhci_hcd: the urb (seqnum 98721) was already given back
                                      [ 1943.500841] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1943.501779] vhci_hcd: unlink->seqnum 98886
                                      [ 1943.502181] vhci_hcd: the urb (seqnum 98886) was already given back
                                      [ 1944.063008] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1944.064232] vhci_hcd: unlink->seqnum 99489
                                      [ 1944.064739] vhci_hcd: the urb (seqnum 99489) was already given back
                                      [ 1944.632563] vhci_hcd: unlink->seqnum 100100
                                      [ 1944.633273] vhci_hcd: the urb (seqnum 100100) was already given back
                                      [ 1944.634220] vhci_hcd: unlink->seqnum 100102
                                      [ 1944.634954] vhci_hcd: the urb (seqnum 100102) was already given back
                                      [ 1946.987708] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1946.988507] vhci_hcd: unlink->seqnum 100265
                                      [ 1946.988882] vhci_hcd: the urb (seqnum 100265) was already given back
                                      [ 1947.131863] vhci_hcd: unlink->seqnum 100433
                                      [ 1947.132557] vhci_hcd: the urb (seqnum 100433) was already given back
                                      [ 1947.133420] vhci_hcd: unlink->seqnum 100435
                                      [ 1947.133848] vhci_hcd: the urb (seqnum 100435) was already given back
                                      [ 1947.277502] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1947.278353] vhci_hcd: unlink->seqnum 100601
                                      [ 1947.278806] vhci_hcd: the urb (seqnum 100601) was already given back
                                      [ 1947.421364] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1947.422139] vhci_hcd: unlink->seqnum 100766
                                      [ 1947.422522] vhci_hcd: the urb (seqnum 100766) was already given back
                                      [ 1947.564322] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1947.565243] vhci_hcd: unlink->seqnum 100931
                                      [ 1947.565648] vhci_hcd: the urb (seqnum 100931) was already given back
                                      [ 1947.708369] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1947.709290] vhci_hcd: unlink->seqnum 101096
                                      [ 1947.709646] vhci_hcd: the urb (seqnum 101096) was already given back
                                      [ 1948.271305] vhci_hcd: unlink->seqnum 101700
                                      [ 1948.271907] vhci_hcd: the urb (seqnum 101700) was already given back
                                      [ 1948.272566] vhci_hcd: unlink->seqnum 101701
                                      [ 1948.272967] vhci_hcd: the urb (seqnum 101701) was already given back
                                      [ 1948.836005] vhci_hcd: unlink->seqnum 102308
                                      [ 1948.836530] vhci_hcd: the urb (seqnum 102308) was already given back
                                      [ 1948.837297] vhci_hcd: unlink->seqnum 102310
                                      [ 1948.837803] vhci_hcd: the urb (seqnum 102310) was already given back
                                      [ 1951.221720] vhci_hcd: unlink->seqnum 102476
                                      [ 1951.222227] vhci_hcd: the urb (seqnum 102476) was already given back
                                      [ 1951.223094] vhci_hcd: unlink->seqnum 102478
                                      [ 1951.223494] vhci_hcd: the urb (seqnum 102478) was already given back
                                      [ 1951.366078] vhci_hcd: unlink->seqnum 102645
                                      [ 1951.366657] vhci_hcd: the urb (seqnum 102645) was already given back
                                      [ 1951.507570] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1951.508420] vhci_hcd: unlink->seqnum 102809
                                      [ 1951.508825] vhci_hcd: the urb (seqnum 102809) was already given back
                                      [ 1951.649614] vhci_hcd: unlink->seqnum 102972
                                      [ 1951.650215] vhci_hcd: the urb (seqnum 102972) was already given back
                                      [ 1951.650835] vhci_hcd: unlink->seqnum 102973
                                      [ 1951.651252] vhci_hcd: the urb (seqnum 102973) was already given back
                                      [ 1951.793651] vhci_hcd: unlink->seqnum 103135
                                      [ 1951.794324] vhci_hcd: the urb (seqnum 103135) was already given back
                                      [ 1951.795432] vhci_hcd: unlink->seqnum 103137
                                      [ 1951.795971] vhci_hcd: the urb (seqnum 103137) was already given back
                                      [ 1951.945607] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1951.946650] vhci_hcd: unlink->seqnum 103266
                                      [ 1951.947846] vhci_hcd: the urb (seqnum 103266) was already given back
                                      [ 1952.526231] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1952.527052] vhci_hcd: unlink->seqnum 103855
                                      [ 1952.527565] vhci_hcd: the urb (seqnum 103855) was already given back
                                      [ 1953.086825] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1953.087673] vhci_hcd: unlink->seqnum 104455
                                      [ 1953.088135] vhci_hcd: the urb (seqnum 104455) was already given back
                                      [ 1955.428797] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1955.429715] vhci_hcd: unlink->seqnum 104623
                                      [ 1955.430191] vhci_hcd: the urb (seqnum 104623) was already given back
                                      [ 1955.572786] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1955.573645] vhci_hcd: unlink->seqnum 104791
                                      [ 1955.574106] vhci_hcd: the urb (seqnum 104791) was already given back
                                      [ 1955.716720] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1955.717641] vhci_hcd: unlink->seqnum 104957
                                      [ 1955.718139] vhci_hcd: the urb (seqnum 104957) was already given back
                                      [ 1955.862343] vhci_hcd: unlink->seqnum 105123
                                      [ 1955.862955] vhci_hcd: the urb (seqnum 105123) was already given back
                                      [ 1955.863721] vhci_hcd: unlink->seqnum 105125
                                      [ 1955.864233] vhci_hcd: the urb (seqnum 105125) was already given back
                                      [ 1956.025327] vhci_hcd: unlink->seqnum 105299
                                      [ 1956.025921] vhci_hcd: the urb (seqnum 105299) was already given back
                                      [ 1956.026807] vhci_hcd: unlink->seqnum 105301
                                      [ 1956.027397] vhci_hcd: the urb (seqnum 105301) was already given back
                                      [ 1956.168997] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1956.169933] vhci_hcd: unlink->seqnum 105466
                                      [ 1956.170407] vhci_hcd: the urb (seqnum 105466) was already given back
                                      [ 1956.730264] ftdi_sio ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
                                      [ 1956.731121] vhci_hcd: unlink->seqnum 106071
                                      [ 1956.731612] vhci_hcd: the urb (seqnum 106071) was already given back
                                      #process4 output
                                      Every 2.0s: python /data/voxl-esc-add-new-params/voxl-esc-tools/voxl-esc-scan.py --enable-debug 1 PW-CONTROL07: Wed Jun 21 17:11:43 2023
                                      Detected Python version : 3.8.0 (default, Jun 18 2023, 12:37:59)
                                      [GCC 11.3.0]
                                      /dev/ttyUSB0 : TTL232RG-VREG3V3 - TTL232RG-VREG3V3
                                      /dev/ttyUSB0
                                      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 2000000
                                      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000
                                      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 921600
                                      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 230400
                                      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 57600
                                      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 115200
                                      INFO: Scanning for ESC bootloader: /dev/ttyUSB0, baud: 38400
                                      UART TX: FA FA 00 05 64 32 3E 65 1A
                                      UART TX: FA FA 00 05 65 B5 92 BD 1B
                                      UART TX: FA FA 00 05 66 3C 67 D4 19
                                        @ErezI sorry i missed your earlier message. Please email me at akushley @ modalai . com and we will discuss via email. No need to re-send the previous information. Thank you.
                                        E 2 Replies Last reply Reply Quote 0
                                        • E
                                          OK
                                          • E
                                            Hi Alex
                                            When we try to verify or update ESC params (xml file) to the F5A esc,
                                            we get the following error:
                                            data/voxl-esc-add-new-params/voxl-esc-tools$ sudo ./voxl-esc-verify-params.py
                                            Detected Python version : 3.8.10 (default, May 26 2023, 14:05:08)
                                            [GCC 9.4.0]
                                            /dev/ttyS4 : n/a
                                            /dev/ttyUSB0
                                            Prioritizing /dev/ttyUSB0 @ 2000000
                                            INFO: ESC(s) detected on port: /dev/ttyUSB0, baud rate: 2000000
                                            Exception in thread uartserial:
                                            Traceback (most recent call last):
                                            File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner
                                            self.run()
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/uarttransceiver.py", line 100, in run
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/escmanager.py", line 135, in handle_packets
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/escmanager.py", line 270, in handle_config_data
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/esc.py", line 84, in set_params
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/params.py", line 268, in parse_params
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/params.py", line 394, in parse_tune_params
                                            Exception: Tune length got: 136, expected: 180
                                            Tune config CRC mismatch 42914 != 0
                                            ERROR: Params for ID 0 are invalid!
                                            ID config CRC mismatch 60163 != 0
                                            ERROR: Params for ID 1 are invalid!
                                            ERROR: Params for ID 2 are invalid!
                                            ERROR: Params for ID 3 are invalid!
                                            ERROR: Params from ID 0 and 1 are not the same
                                            ERROR: Params from ID 0 and 2 are not the same
                                            ERROR: Params from ID 0 and 3 are not the same
                                            ERROR: Some params are invalid or not the same!
                                            Number of ESCs expected : 4
                                            Number of ESCs found : 4
                                            Number of invalid params : 4
                                            Number of matched params : 1
                                            user@user-CF-54-3:/data/voxl-esc-add-new-params/voxl-esc-tools$
                                            [sudo] password for user:
                                            Starting Wizard
                                            What do you want to do?
                                            1. scan 3) spin 5) upload_params
                                            2. detect 4) upgrade_firmware
                                              #? 5
                                            Which ?
                                            1. starling_v2 3) fpv_revB 5) MPD
                                            2. sentinel_v1 4) starling_m129
                                              #? 5
                                              uploading params file ../voxl-esc-params/MPD/mpd_params.xml
                                              enabling bridge
                                              Failed to get unit file state for voxl-px4.service: No such file or directory
                                              bridge enabled
                                              [GCC 9.4.0]
                                              /dev/ttyS4 : n/a
                                              /dev/ttyUSB0
                                              UID : 0x203135385631500200730034
                                              UID : 0x203135385631500200320035
                                              UID : 0x203135385631500200340033
                                              UID : 0x203135385631500200710034
                                            successfully pinged ESCs
                                            [GCC 9.4.0]
                                            INFO: Params file name : ../voxl-esc-params/MPD/mpd_params.xml
                                            INFO: Params file size : 6959 bytes
                                            /dev/ttyS4 : n/a
                                            /dev/ttyUSB0
                                            INFO: ESCs detected:
                                            ID: 0, SW: 37, HW: 33: Blheli32 4-in-1 ESC Type B (Tmotor F55A PRO G071)
                                            ID: 1, SW: 37, HW: 33: Blheli32 4-in-1 ESC Type B (Tmotor F55A PRO G071)
                                            ID: 2, SW: 37, HW: 33: Blheli32 4-in-1 ESC Type B (Tmotor F55A PRO G071)
                                            ID: 3, SW: 37, HW: 33: Blheli32 4-in-1 ESC Type B (Tmotor F55A PRO G071)
                                            INFO: Loading XML config file...
                                            File "voxl-esc-upload-params.py", line 114, in <module>
                                            esc.params.parse_xml_string( xml_string )
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/params.py", line 518, in parse_xml_string
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/params.py", line 935, in set_packet_metadata
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/params.py", line 249, in update_crc
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/params.py", line 165, in get_param_bytes_for_crc
                                            File "./tmp/voxl-esc-tools-bin-export-1.2/libesc/params.py", line 85, in byteify
                                            struct.error: pack expected 12 items for packing (got 4)
                                            disabling bridge
                                            bridge disabled
                                            we use the following xml file for the f40 pro 2400kv:
                                            sudo cat ./mpd_params.xml
                                            <?xml version="1.0" encoding="UTF-8"?>
                                            <!-- Copyright (c) 2020 ModalAI Inc.
                                            Redistribution and use in source and binary forms, with or without
                                            modification, are permitted provided that the following conditions are met:
                                            1. Redistributions of source code must retain the above copyright notice,
                                              this list of conditions and the following disclaimer.
                                            2. Redistributions in binary form must reproduce the above copyright notice,
                                              this list of conditions and the following disclaimer in the documentation
                                              and/or other materials provided with the distribution.
                                            3. Neither the name of the copyright holder nor the names of its contributors
                                              may be used to endorse or promote products derived from this software
                                              without specific prior written permission.
                                            4. The Software is used solely in conjunction with devices provided by
                                              ModalAI Inc.
                                            THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
                                            AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
                                            IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
                                            ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
                                            LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
                                            CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
                                            SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
                                            INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
                                            CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
                                            ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
                                            POSSIBILITY OF SUCH DAMAGE.
                                            For a license to use on non-ModalAI hardware, please contact license@modalai.com -->
                                            <EscParameters>
                                            <IdParams>
                                            <param name="id" value="127"/> <!-- 0-7 .. 127 means use hardware ID pins to read ID-->
                                            <param name="dir" value="2"/> <!-- 0=fwd, 1=rev, 2=fwd id-based, 3=rev id-based -->
                                            </IdParams>
                                            <BoardParams>
                                            <param name="id_map" value="[0, 1, 2, 3, 4, 5, 6, 7]"/> <!-- reserved for future use -->
                                            <param name="vsense_scale" value="6.0"/> <!-- voltage_mv = adc_val_mv * vsense_mult / vsense_ div -->
                                            <param name="isense_scale" value="18.25"/> <!-- Ima * 0.001 * 50 = Vmv, so mult is 1 / (0.001 * 50) = 20 . Note that actual gain is a bit off -->
                                            <param name="isense_zero_mv" value="550"/> <!-- voltage offset of current sensor when current is zero (0.55V by design) -->
                                            </BoardParams>
                                            <UartParams>
                                            <param name="protocol_version" value="2"/> <!-- reserved for future use -->
                                            <param name="input_mode" value="0"/> <!-- reserved for future use -->
                                            <param name="baud_rate" value="2000000"/> <!-- communication bit rate -->
                                            <param name="char_timeout_ns" value="0"/> <!-- not used -->
                                            <param name="cmd_timeout_ns" value="100000000"/> <!-- timeout for incoming commands before ESC will stop the motor -->
                                            </UartParams>
                                            <TuneParams>
                                            <param name="pwm_frequency" value="48000"/> <!-- switching freqency of PWM signal going to motors. 24Khz and 48Khz are only options for now -->
                                            <param name="vbat_nominal_mv" value="14800"/> <!-- used for sanity checking and limiting of voltage-dependent funcions -->
                                            <param name="num_cycles_per_rev" value="7"/> <!-- number of pole pairs in the motor. used for converting electrical frequency to mechanical rpm -->
                                            <param name="min_rpm" value="1000"/> <!-- minimum RPM that will be attempted, otherwise capped -->
                                            <param name="max_rpm" value="25000"/> <!-- maximum RPM that will be attempted, otherwise capped -->
                                            <param name="min_pwm" value="50"/> <!-- cap for minimum power to be ever applied. max is 999 -->
                                            <param name="max_pwm" value="999"/> <!-- cap for maximum power to be ever applied. max is 999 -->
                                            <param name="pwm_vs_rpm_curve_a0" value="870.0"/> <!-- this is actually motor_voltage vs rpm curve.. using legacy naming -->
                                            <param name="pwm_vs_rpm_curve_a1" value="0.5"/> <!-- Emax RS1306 3300KV with tri-blade 3x3x3 -->
                                            <param name="pwm_vs_rpm_curve_a2" value="3.0e-06"/>
                                            <param name="kp" value="250"/> <!-- RPM controller proportional gain -->
                                            <param name="ki" value="30"/> <!-- RPM controller proportional gain -->
                                            <param name="max_kpe" value="300"/> <!-- maximum proportional erorr term (max is 999) -->
                                            <param name="max_kie" value="100"/> <!-- maximum integral error term (max is 999) -->
                                            <param name="max_rpm_delta" value="3000"/> <!-- cap for maximum rpm error used in RPM controller -->
                                            <param name="alignment_time_ns"   value="0"/>
                                            <param name="spinup_power"        value="70"/>      <!-- power used to give the motor initial kick (out of 999) -->
                                            <param name="latch_power"         value="80"/>     <!-- power used during latching stage of spin-up (out of 999)-->
                                            <param name="min_num_cross_for_closed_loop" value="50"/>  <!-- exit latching mode of fixed power after this number of zero crossings -->
                                            <param name="brake_to_stop"       value="0"/>             <!-- apply brake when stopping motor (or not) -->
                                            <param name="stall_timeout_ns"    value="20000000"/>      <!-- after spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled -->
                                            <param name="require_reset_if_stalled"      value="0"/>   <!-- require sending an array of zero commands to reset before next spin-up, if motor stalled -->
                                            <!-- <param name="tone_freqs_10hz" value="[200, 215, 225, 250]"/> --> <!-- 200 is 2000Hz, max 255 -->
                                            <!-- <param name="tone_times_ms" value="[10, 10, 10, 10]"/> --> <!-- duration of each tone in units of 10 milli-seconds. Poor naming!!! -->
                                            <param name="tone_powers" value="[100, 100, 100, 100]"/> <!-- max is 255 -->
                                            <param name="dt_threshold_ns"       value="150000"/>      <!-- during start up, ignore inter-commutation times less than this val, probably noise -->
                                            <param name="max_dt_ns"             value="2500000"/>     <!-- min and max values for time between two commutations. these are used as caps -->
                                            <param name="min_dt_ns"             value="10000"/>
                                            <param name="dt_bootstrap_ns"       value="2000000"/>     <!-- filter bootstrap value for commutation dt during start up -->
                                            <param name="spinup_stall_dt_ns"    value="6000000"/>     <!-- during spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled -->
                                            <param name="spinup_stall_check_ns" value="30000000"/>    <!-- time after beginning of spinup to start checking for spinup stall -->
                                            <param name="timing_advance"        value="0"/>
                                            <param name="sense_advance"         value="0"/>
                                            <param name="demag_timing"          value="0"/>    <!-- unused -->
                                            </TuneParams>
                                            </EscParameters>
                                            Erez
