    VOXL2 PX4 cannot connect to QGC
    1714
    • kp ngK
      kp ng
      Hi.
      I purchased the VOXL2 flight deck (without the ESC and motors) and tried to run the example to connect PX4 MAVLINK to QGC. I play to run the flight simulation with gazebo
      I am unable to get connection up. I also realised there is no config files e.g.
      /etc/modalai/voxl-px4.config
      Would appreciate if you could help
      • Zachary Lowell 0Z
        Zachary Lowell 0 ModalAI Team
        Hi @kp-ng,
        Multiple questions here: Are you trying to connect over the network or serially? Serial connection is not an option. You need to have a connection to a LAN or WAN to connect to QGC. Another option is to put the device in fastboot which it already should be out the gate and you can connect to the voxl2 wifi. Then when you open QGC it will auto connect.
        Also if there is a file called voxl-px4.conf then you should have everything you need if you plan on editing said config file.
        Can you explain a bit more what you are trying to do. Get as specific as possible please.
        Zach
        kp ngK 1 Reply Last reply Reply Quote 0
          tom admin
          @kp-ng It would also help to see what software versions you're running with voxl-version
          • kp ngK
            kp ng @Zachary Lowell 0
            @Zachary-Lowell-0 Hi. Yes. I am able to set up voxl-wifi station properly and can ping between my QgroundCtrl computer and VOXL2. I am to run mavlink server and vision px4 as well.
            • kp ngK
              kp ng
              I have a voxl2 flight deck.
              I want to set it up and simulate fly by waypoints, guided by GPS, using QGC-Gazebo and PX4 before I go and size up the motor-props-frame and develop the drone.
              So far,
              I have been able to set up the mavlink and PX4 server running.
              I have been able to ping the QGC computer from voxl2 and voxl2 from computer
              I have set up the IP address to be the computer hosting QGC.
              But I am unable to get QGC automatically connect to the PX4. It says disconnected
              I am not sure if it is QGC issue or the VOXL2 setup though
              • kp ngK
                kp ng
                I checked on QGroundControl Logs. It says
                "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/4"
                • kp ngK
                  kp ng
                  I also don't see any UDP traffic originating from VXOL2 using wireshark on the laptop hosting QGroundControl. Please help
                    Eric Katzfey ModalAI Team @kp ng
                    @kp-ng As @tom stated, knowing what version of software you are running is very important for us to be able to help out.
                    • kp ngK
                      kp ng
                      Sorry. Here is the voxl-version output.
                      I have also check with another PX4 flight control board and it works. so it is unlikely an issue with QGC side.
                      libmodal-cv              0.2.3
                      libmodal-exposure        0.0.7
                      libmodal-journal         0.2.1
                      libmodal-json            0.4.3
                      libmodal-pipe            2.8.2
                      libqrb5165-io            0.1.0
                      libvoxl-cci-direct       0.1.5
                      libvoxl-cutils           0.1.1
                      mv-voxl                  0.1-r0
                      qrb5165-bind             0.1-r0
                      qrb5165-dfs-server       0.1.0
                      qrb5165-imu-server       0.5.0
                      qrb5165-slpi-test-sig    01-r0
                      qrb5165-system-tweaks    0.1.5
                      qrb5165-tflite           2.8.0-2
                      voxl-bind                0.0.1
                      voxl-camera-calibration  0.2.3
                      voxl-camera-server       1.3.5
                      voxl-cpu-monitor         0.3.0
                      voxl-docker-support      1.2.4
                      voxl-gphoto2-server      0.0.10
                      voxl-jpeg-turbo          2.1.3-4
                      voxl-libgphoto2          0.0.4
                      voxl-libuvc              1.0.7
                      voxl-logger              0.3.4
                      voxl-mavlink             0.1.0
                      voxl-mavlink-server      0.3.0
                      voxl-modem               0.16.1
                      voxl-mongoose            7.7.0-1
                      voxl-mpa-to-ros          0.3.6
                      voxl-mpa-tools           0.7.6
                      voxl-opencv              4.5.5-1
                      voxl-portal              0.5.0
                      voxl-px4                 1.12.31
                      voxl-px4-imu-server      0.1.2
                      voxl-qvio-server         0.8.2
                      voxl-remote-id           0.0.5
                      voxl-streamer            0.4.1
                      voxl-suite               0.9.5
                      voxl-tag-detector        0.0.4
                      voxl-tflite-server       0.3.1
                      voxl-utils               1.2.2
                      voxl-uvc-server          0.1.3
                      voxl-vision-px4          1.4.0
                      voxl2-system-image       1.5.5-r0
                      voxl2-wlan               1.0-r0
                      • kp ngK
                        kp ng
                        I have managed to get the VOXL2 px4 to connect to QGC
                        • M
                          majjam @kp ng
                          @kp-ng Do you recall the steps you took to fix your issue?
