  2. VOXL Compute & Autopilot
  3. VOXL
  4. voxl-inspect on docker
Scheduled Pinned Locked Moved VOXL
4 Posts 2 Posters 1.6k Views 1 Watching
  • H Offline
    H Offline
    hedd
    hello !
    i try to run “voxl-inspect-cpu " which is on host machine coded in a python script and i want to execute it on docker ,but when i build and run the image with the script it dosen't give me the result that i want ,how can fix that ?
    • H Offline
      H Offline
      hedd
      @wilkinsaf can you help !
        @hedd Docker containers don't have access to any programs outside of the scope of their container. Files from the host machine can be mounted inside the docker container: https://docs.docker.com/storage/bind-mounts/
        It may be possible to run certain "voxl-" scripts inside the container if they're purely bash or python but this likely wouldn't work if they require a bunch of dependencies that are only available on the host machine.
        • H Offline
          H Offline
          hedd
          @tom there is no other methods for example use your nsenter ?!
