    voxl-inspect on docker
    VOXL
    • H
      hedd
      hello !
      i try to run “voxl-inspect-cpu " which is on host machine coded in a python script and i want to execute it on docker ,but when i build and run the image with the script it dosen't give me the result that i want ,how can fix that ?
      • H
        hedd
        @wilkinsaf can you help !
          tom admin
          @hedd Docker containers don't have access to any programs outside of the scope of their container. Files from the host machine can be mounted inside the docker container: https://docs.docker.com/storage/bind-mounts/
          It may be possible to run certain "voxl-" scripts inside the container if they're purely bash or python but this likely wouldn't work if they require a bunch of dependencies that are only available on the host machine.
          • H
            hedd
            @tom there is no other methods for example use your nsenter ?!
