Y
y_yoshihara
@y_yoshihara
  • Starling 2 Max for indoor use in Japan: radio options, prop guards and payload mounting
    Y y_yoshihara
    @Moderator Thank you very much for the clear answers on the prop guards, payload, and lead time.
    They were very helpful for our planning.
    Given the lead time (about 60 business days) and the need to design the payload mount ourselves,
    we have decided to start our indoor autonomous flight tests with a smaller drone that we can get right away.
    We may consider the Starling 2 Max again for a later phase.
    Thank you again to Eric, Tom, and the ModalAI team for your support.
    Development Drones
    Y y_yoshihara
    @tom
    Thank you, Eric and tom. The answers on the RC receiver, failsafe and Wi-Fi were very helpful.
    We expect to make our purchase decision soon, so I would like to follow up on the remaining points from my last post:
    1. Propeller guards: Are official guards or a cage available for the Starling 2 Max? If not, are CAD/STEP files of the frame or arms available?
    2. Payload (about 100-300 g): Is there a recommended mounting point? What power output is available (voltage and maximum current)? Roughly what flight time should we expect with 300 g?
    3. Lead time: Is "ships within 60 business days" still the current lead time for the C28 / Wi-Fi configuration?
    The lead time is the most urgent for us, so even a rough answer on that alone would help a lot.
    Thank you for your support.
    Development Drones
    Y y_yoshihara
    Thank you very much, Eric. That answers our question about the RC receiver.
    If we remove the ELRS receiver and fly with a QGC joystick over Wi-Fi, is there anything we should set for the case where the Wi-Fi/QGC link is lost (for example, a GCS loss failsafe such as land or hold)?
    We would also be grateful for any information on the remaining points:
    1. Wi-Fi (-M36): What is the model of the included Wi-Fi dongle? Can VOXL 2 use another USB Wi-Fi adapter, and if so, which chipsets/drivers are supported? (In Japan we need a radio that is certified under Japanese radio law.)
    2. Propeller guards: Are official guards or a cage available for the Starling 2 Max? If not, are CAD/STEP files of the frame or arms available so we can design 3D-printed guards?
    3. Payload (about 100-300 g): Is there a recommended mounting point or mounting holes on the frame? What power output is available for a payload (voltage and maximum current)? And roughly what flight time should we expect with 300 g?
    4. Lead time: Is "ships within 60 business days" still the current lead time for the C28 / Wi-Fi configuration?
    Thank you again for your help.
    Development Drones
    Y y_yoshihara
    Hardware: Starling 2 Max (C28 / Wi-Fi) - evaluating before purchase. We do not own one yet, so there is no software version or log to share.
    Hello ModalAI team,
    We are evaluating the Starling 2 Max for indoor, GPS-denied autonomous flight research in Japan. Sales kindly pointed us to this forum for technical questions. We would appreciate any guidance on the following:
    1. Wi-Fi (-M36 option)
      • What is the exact model of the Wi-Fi module/dongle included with the -M36 option?
      • Can VOXL 2 use a different USB Wi-Fi adapter? If so, which chipsets/drivers are supported? (Radio equipment used in Japan must be certified under Japanese radio law, so we may need to use a locally certified adapter.)
    2. RC receiver
      The product page shows that every configuration includes an ELRS 915 MHz receiver (-T8). The 915 MHz band cannot be used for this purpose in Japan.
      • Can the Starling 2 Max be flown with no RC receiver at all, for example manual control from QGroundControl over Wi-Fi plus autonomous offboard missions? Are there any PX4 settings we should change for this (e.g. RC loss failsafe)?
      • Alternatively, can we replace it with a 2.4 GHz ELRS receiver or an S.BUS receiver (e.g. Futaba)? Which port and parameters should we use?
    3. Propeller guards
      • Are official propeller guards or a protective cage available for the Starling 2 Max (180 mm propellers)?
      • If not, are CAD/STEP files of the frame or arms available, so that we can design 3D-printed guards? How much extra weight would you expect the drone to handle without re-tuning?
    4. Payload mounting
      We plan to carry a sensor of about 100-300 g.
      • Are there mounting holes or a recommended mounting point on the frame (we understand the mass should be close to the center)?
      • What power outputs are available for a payload (voltage and maximum current)?
      • Can the payload communicate with VOXL 2 over USB or UART?
      • What flight time can we expect with about 300 g of payload?
    5. Lead time
      The product page says "Expected to ship within 60 business days." Is this the current lead time for the C28 / Wi-Fi configuration?
    Thank you very much for your help.
    Development Drones
