W
Wei Cui
@Wei Cui
  • RAW16 Depth images
    W Wei Cui
    Good afternoon everyone, I notice that the latest voxl portal supports RAW16 images. I wonder which version of camera server should I choose to generate RAW16 depth images. Thank you.
  • flashing VOXL2 errors
    W Wei Cui
    @Wei-Cui wiping the /data partition fixed the error.
    W Wei Cui
    Has anyone seen the following errors. I tried both sudo ./install.sh and sudo su then ./install.sh . Any advice would be greatly appreciated.
      File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
    Reading package lists... Done
    N: Download is performed unsandboxed as root as file '/data/voxl-suite-offline-packages/./InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
    E: Failed to fetch file:/data/voxl-suite-offline-packages/./Packages  File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
    E: Some index files failed to download. They have been ignored, or old ones used instead.
    [INFO] Installing packages on target
    Building dependency tree
    E: Unable to locate package voxl-suite
    [INFO] Pointing to correct repo
    /bin/bash: voxl-configure-pkg-manager: command not found
    [INFO] Done installing voxl-suite```
  • Displaying hires frames with timestamp
    W Wei Cui
    Hi everyone, would it be possible to see the timestamp of each hires camera frame in VOXL-portal? Thank you.
  • Display custom data in voxl-portal
    W Wei Cui
    I'd like to display some custom vio data on voxl-portal for comparison with the existing data. Shall I create a custom vio server to publish data to the portal? Any advice or suggestions would be greatly appreciated.
  • RB5 Streamer with System Image 1.3
    W Wei Cui
    Since the install of the latest image 1.3, I have a hard time to run view hi-res camera footage with VLC on a laptop (https://docs.modalai.com/Qualcomm-Flight-RB5-streamer/). Any suggestions would be greatly appreciated.
  • RB5 UART for external FC not working.
    W Wei Cui
    @modaltb hello, when will the next SDK release be available? Would love to the UARTs working for external FC. Thank you.
    Development Drones uart rb5 drivers external fc
  • voxl-tflite-server crashes after 5-10 minutes
    W Wei Cui
    @Matt-Turi Can you please let us know if voxl_mpa_to_ros is compatible with the new output pipe? Thanks.
