Viktor GalV
Viktor Gal
@Viktor Gal
  • VOXL2 TOF Camera not working
    Viktor GalV Viktor Gal
    @Thomas-Müller interesting. i'm just experience the very same thing. have you by chance figured out what was the issue?
  • flashing starling 1.1.4 with the latest 1.4.5
    @Alex-Kushleyev yes yes, it boots up fine in normal mode
    Development Drones starling
    @Alex-Kushleyev you reckon? i mean the starling v2 just went to fastboot mode very nicely and i could flash it easily on the same macos. or is there so much of a difference between the starling v1 and v2 chips? i'll give it a go on the raspberry pi.
    @Alex-Kushleyev
    using the dip switch and powercycling there's no devices showing up with sudo fastboot devices.
    unfortunately no lsbusb as i'm under macos, but sysprofiler's output is:
          Host Controller Driver: AppleT6000USBXHCI
            QUSB_BULK_CID:0412_SN:008A1847:
              Product ID: 0x9008
              Vendor ID: 0x05c6  (Qualcomm, Inc)
              Version: 0.00
              Speed: Up to 480 Mb/s
              Manufacturer: Qualcomm CDMA Technologies MSM
              Location ID: 0x01100000 / 1
              Current Available (mA): 500
              Current Required (mA): 2
              Extra Operating Current (mA): 0
    if you really think there's some extra info with lsusb that you are looking for i can hook it up to my raspberry pi.
    @Alex-Kushleyev as said above with the very same machine i successfully updated a starling v2 drone. but i'll try to check what you've just suggested.
  • elrs fw compatibility
    @Maxwell-Schaefer thnx for getting back to me. i've seen that on starling the betafpv module is currently having 3.2.1.2. are you using any specific customiziation? i'm just wondering as the mavlink-rc support requires 3.5.0 or later.
    i have an older starling (v1) with a preinstalled 1.1.4 voxl2 sdk. i'm trying to flash it with the latest 1.4.5 version and i'm having problems as the device does not go into fastboot mode, note i've tried power cycling and switching the fastboot dip switch to on. I've attached the logs.
    additional info: doing the same (without actually needing to do the fastboot switch turning on) i've successfully flashed the 1.4.5 on a starling v2!
    although this is a general question for voxl sdk since i'm using it with starlings i'm wondering whether there's any limitation (or has anybody tested) for the FW version of the ELRS controller with the latest voxl2 sdk? meaning the latest release of the ELRS FW is 3.5.5, my iflight commando is flashed with a custom modalai v2.8.5, and i'm wondering if anybody tested with 3.5.x FW....?
  • starling 2 RMA
    @tom as said when we swapped the voxl2 board from another drone everything works fine. moreover, i assume that the board should work without connecting anything to it (just power and usbc) but there's 0 signal from the voxl2 board itself. meaning nothing pops up in lsusb -v.
  • starling 2 RMA
    I'm writing you as I couldn't find relevant information regarding my question neither in the forum nor at the FAQ section. We purchased about 6 drones from you in the past and currently facing a problem with one of our drones. basically the VOXL2 main board seems to be dead. we've tried to connect to it via usb from various computers, but it doesn't even show up in the dmesg/lsusb. since we have many other drones (hence parts) we quickly eliminated the other options, i.e. other parts being broken. it is definitely the main voxl2 board.
    I'm wondering now whether in this case, for creating an RMA, would it be sufficient for you that we send back the board itself or you really need us to send back the full Starling 2 drone itself?
  • Timeline for open-vins documentation
    @Moderator et.al. i just want to follow up that switching to the nightly builds that uses out of box the openvins implementation for VIO, is significantly better than the qvio. in other words, it actually fixed all the problems that we were facing with the QVIO.
    @Moderator yep, back and forth. unfortunately no change.
    @Zachary-Lowell-0 i hear you, but could you maybe give some pointers how one could make the qvio more stable? as i said it is at the moment only has 25% success rate: meaning 1 out of 5 flights i dont have problems with the qvio, the rest of the time the drone becomes unstable and crashes.
    @Zachary-Lowell-0 hey so i did what you suggested, here's the full output of openvins server but it's the very same behaviour; the qvio is nicely picking up the movements, openvins is just stationary on the portal. here are the detailed logs:
    voxl2:~$ voxl-open-vins-server --verbosity 0
    Setting printing level to: SILENT
    Setting printing level to: ALL
    Loading our own config file
    =========================AUTO RESET==============================
    en_auto_reset:                    1
    auto_reset_max_velocity:          20.000
    auto_reset_max_v_cov_instant:      0.100
    auto_reset_max_v_cov:              0.100
    auto_reset_max_v_cov_timeout_s:    0.500
    auto_reset_min_features:          1
    auto_reset_min_feature_timeout_s:  3.000
    auto_fallback_timeout_s:  3.000
    auto_fallback_min_v:  0.600
    en_cont_yaw_checks: false
    fast_yaw_thresh:  5.000
    fast_yaw_timeout_s:  1.750
    ===========================STATE=================================
    do fej:                           true
    imu avg:                          true
    use rk4 integration:              true
    cam to imu refinement:            true
    cam intrins refinement:           true
    cam imu ts refinement:            true
    max clone size:                   8
    max slam features:                40
    max slam in update:               25
    max msckf in update:              25
    feat rep msckf:                   ANCHORED_MSCKF_INVERSE_DEPTH
    feat rep slam:                    ANCHORED_MSCKF_INVERSE_DEPTH
    cam imu time offset:              0.00150
    slam delay:                       1.00000
    =====================INERTIAL INITIALIZER========================
    gravity mag:                      9.80665
    init window time:                 1.00000
    init imu thresh:                  1.00000
    init dyn use:                         false
    ==========================IMU NOISE==============================
    imu sigma w:                      0.00014
    imu sigma wb:                     0.00000
    imu sigma a:                      0.00389
    imu sigma ab:                     0.00006
    ========================FEATURE NOISE============================
    msckf chi^2 multiplier:           1.00000
    msckf sigma px:                   1.00000
    slam chi^2 multiplier:            40.00000
    slam sigma px:                    1.80000
    zupt chi^2 multiplier:            1.00000
    zupt sigma px:                    1.00000
    =============================ZUPT================================
    try zupt:                         true
    zupt max velocity:                0.03000
    zupt only at beginning:           true
    zupt noise multiplier:            1.00000
    zupt max disparity:               3.00000
    use mask:                         true
    use stereo:                       false
    use baro:                       false
    ========================FEATURE INITIALIZER======================
    triangulate 1d:                   false
    refine features:                  false
    max runs:                         5
    init lamda:                       0.00100
    max lamda:                        10000000000.00000
    min dx:                           0.00000
    min dcost:                        0.00000
    lam mult:                         10.00000
    min dist:                         0.10000
    max dist:                         60.00000
    max baseline:                     40.00000
    num_opencv_threads:                  9
    fast_threshold:                  15
    histogram_method:                  HISTOGRAM
    knn_ratio:                  0.70000
    track_frequency:                  15.00000
    publish_frequency:                  3
    imu takeoff accel thresh:                  0.10000
    force init on takeoff:                  false
    use takeoff_camera_as:                  0
    takeoff_threshold(m):                  -0.100000
    publish stats:                  false
    max_allowable_cep:                  1.00000
    force FLU to NED transform:                  false
    VIO always on (for bench testing):                  false
    Number of cameras found for this config: 1
    [INFO] External feature trackers being used? false
    camera count: 1
    MONO mode (using cam idx: 0)
    camera count: 1
    Skipping camera group index: 2, not enabled
    Loading OpenCV intrinsics cal file from: /data/modalai/opencv_tracking_front_intrinsics.yml
    Loading OpenCV intrinsics cal file from: /data/modalai/opencv_tracking_down_intrinsics.yml
    cam_load_extrinsics_file
    World Rotation Matrix:
     1.000000  0  0
     0  1.000000  0
     0  0  1.000000
    load extrinsics 2
    Using extrinsics under camera ID: tracking_front
    [INFO] Camera: 0 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 90.000000, Yaw -90.000000
    (local) CAMERA ROTATION MATRIX:
    [0, 0, 1;
     -1, 0, 0;
     0, -1, 0]
    (local) CAMERA TRANSLATION:
      0.037
         -0
    -0.0006
    Using extrinsics under camera ID: tracking_down
    [INFO] Camera: 1 -- converted extrinsics *in FLU* are: Roll: -0.000000, Pitch 180.000000, Yaw -360.000000
    [-1, 0, 0;
     0, 1, 0;
     0, 0, -1]
    -0.08825
      0.0045
    -0.00269
    Done transfer camera configuration transfer
    ==========================CAMERA 0================================
    mode:                             MONO
    camera matrix:
    460.27780 0.00000 621.21213
    0.00000 459.85438 408.51998
    0.00000 0.00000 1.00000
    distortion coefficients:
    0.05324 0.02329 -0.00926 0.00026
    ==========================CAMERA 1================================
    mode:                             MONO
    camera matrix:
    462.04073 0.00000 660.98324
    0.00000 462.09738 397.45450
    0.04984 0.04004 -0.02646 0.00611
    =============================KLT=================================
    num_features_to_track:            30
    grid_x:                           5
    grid_y:                           5
    min_pix_dist:                     50
    pyramid_levels:                   5
    [block] window_size:                 (25 x 25)
    ===========================KLTGYRO===============================
    tmp_imu_name:                         imu_apps
    tracking_front wrt imu_apps:
    -1.00000 0.00000 0.00000
    0.00000 -1.00000 0.00000
    tracking_down wrt imu_apps:
    0.00000 1.00000 0.00000
    0.00000 0.00000 -1.00000
    Loading external config file
    =====> imu to read from: imu
    OpenVINS using fisheye camera
    OpenVINS FINAL Cam extrinsics to IMU for tracking_front: 7
        -0.5
        0.5
       -0.5
        0.5
      0.037
         -0
    -0.0006
    OpenVINS FINAL Cam extrinsics to IMU for tracking_down: 7
     -1.22465e-16
              -1
     -7.4988e-33
    -6.12323e-17
        -0.08825
          0.0045
        -0.00269
    OpenVINS reports number of cameras being used, regardless of delivery method (pipe, merge, etc...):  2
    VioManagerOptions.h:108 ESTIMATOR PARAMETERS:
    StateOptions.h:108   - use_fej: 1
    StateOptions.h:109   - use_imuavg: 1
    StateOptions.h:110   - use_rk4int: 1
    StateOptions.h:111   - calib_cam_extrinsics: 1
    StateOptions.h:112   - calib_cam_intrinsics: 1
    StateOptions.h:113   - calib_cam_timeoffset: 1
    StateOptions.h:114   - max_clones: 8
    StateOptions.h:115   - max_slam: 40
    StateOptions.h:116   - max_slam_in_update: 25
    StateOptions.h:117   - max_msckf_in_update: 25
    StateOptions.h:118   - max_aruco: 1024
    StateOptions.h:119   - max_cameras: 2
    StateOptions.h:120   - feat_rep_msckf: ANCHORED_MSCKF_INVERSE_DEPTH
    StateOptions.h:121   - feat_rep_slam: ANCHORED_MSCKF_INVERSE_DEPTH
    StateOptions.h:122   - feat_rep_aruco: GLOBAL_3D
    InertialInitializerOptions.h:125 INITIALIZATION SETTINGS:
    InertialInitializerOptions.h:150   - init_window_time: 1.00
    InertialInitializerOptions.h:151   - init_imu_thresh: 1.00
    InertialInitializerOptions.h:152   - init_max_disparity: 3.00
    InertialInitializerOptions.h:153   - init_max_features: 0.00
    InertialInitializerOptions.h:171   - init_dyn_use: 0
    InertialInitializerOptions.h:172   - init_dyn_mle_opt_calib: 0
    InertialInitializerOptions.h:173   - init_dyn_mle_max_iter: 20
    InertialInitializerOptions.h:174   - init_dyn_mle_max_threads: 20
    InertialInitializerOptions.h:175   - init_dyn_mle_max_time: 2.00
    InertialInitializerOptions.h:176   - init_dyn_num_pose: 8
    InertialInitializerOptions.h:177   - init_dyn_min_deg: 45.00
    InertialInitializerOptions.h:178   - init_dyn_inflation_ori: 1.00e+01
    InertialInitializerOptions.h:179   - init_dyn_inflation_vel: 1.00e+01
    InertialInitializerOptions.h:180   - init_dyn_inflation_bg: 1.00e+02
    InertialInitializerOptions.h:181   - init_dyn_inflation_ba: 1.00e+02
    InertialInitializerOptions.h:182   - init_dyn_min_rec_cond: 1.00e-15
    InertialInitializerOptions.h:188   - init_dyn_bias_g: 0.00, 0.00, 0.00
    InertialInitializerOptions.h:189   - init_dyn_bias_a: 0.00, 0.00, 0.00
    InertialInitializerOptions.h:216 NOISE PARAMETERS:
    InertialInitializerOptions.h:224   - gyroscope_noise_density: 0.000170
    InertialInitializerOptions.h:225   - accelerometer_noise_density: 0.00200
    InertialInitializerOptions.h:226   - gyroscope_random_walk: 0.0000194
    InertialInitializerOptions.h:227   - accelerometer_random_walk: 0.003000
    InertialInitializerOptions.h:228   - sigma_pix: 1.00
    InertialInitializerOptions.h:318 STATE PARAMETERS:
    InertialInitializerOptions.h:319   - gravity_mag: 9.8066
    InertialInitializerOptions.h:320   - gravity: 0.000, 0.000, 9.807
    InertialInitializerOptions.h:321   - num_cameras: 2
    InertialInitializerOptions.h:322   - use_stereo: 0
    InertialInitializerOptions.h:323   - downsize cameras: 0
    InertialInitializerOptions.h:332   - calib_camimu_dt: 0.0000
    InertialInitializerOptions.h:348 cam_0_fisheye:1
    cam_0_wh:
    1280 x 800
    cam_0_intrinsic(0:3):
    460.278 459.854 621.212  408.52
    cam_0_intrinsic(4:7):
      0.0532387   0.0232891  -0.0092603 0.000263136
    cam_0_extrinsic(0:3):
    -0.5  0.5 -0.5  0.5
    cam_0_extrinsic(4:6):
      0.037      -0 -0.0006
    T_C0toI:
               0  2.22045e-16            1       0.0006
              -1  2.22045e-16            0        0.037
    -2.22045e-16           -1  2.22045e-16  8.34888e-18
               0            0            0            1
    InertialInitializerOptions.h:348 cam_1_fisheye:1
    cam_1_wh:
    1280 x 800
    cam_1_intrinsic(0:3):
    462.041 462.097 660.983 397.455
    cam_1_intrinsic(4:7):
     0.0498391   0.040037 -0.0264578  0.0061076
    cam_1_extrinsic(0:3):
    -1.22465e-16           -1  -7.4988e-33 -6.12323e-17
    cam_1_extrinsic(4:6):
    -0.08825   0.0045 -0.00269
    T_C1toI:
              -1  2.44929e-16  1.22465e-16     -0.08825
     2.44929e-16            1            0      -0.0045
    -1.22465e-16  2.99952e-32           -1     -0.00269
               0            0            0            1
    VioManagerOptions.h:121   - dt_slam_delay: 1.0
    VioManagerOptions.h:122   - zero_velocity_update: 1
    VioManagerOptions.h:123   - zupt_max_velocity: 0.03
    VioManagerOptions.h:124   - zupt_noise_multiplier: 1.00
    VioManagerOptions.h:125   - zupt_max_disparity: 3.0000
    VioManagerOptions.h:126   - zupt_only_at_beginning?: 1
    VioManagerOptions.h:127   - record timing?: 0
    VioManagerOptions.h:128   - record timing filepath: ov_msckf_timing.txt
    VioManagerOptions.h:155 NOISE PARAMETERS:
    NoiseManager.h:62   - gyroscope_noise_density: 0.000140
    NoiseManager.h:63   - accelerometer_noise_density: 0.00389
    NoiseManager.h:64   - gyroscope_random_walk: 0.0000004
    NoiseManager.h:65   - accelerometer_random_walk: 0.000055
    VioManagerOptions.h:179   Updater MSCKF Feats:
    UpdaterOptions.h:45     - chi2_multipler: 1.0
    UpdaterOptions.h:46     - sigma_pix: 1.00
    VioManagerOptions.h:181   Updater SLAM Feats:
    UpdaterOptions.h:45     - chi2_multipler: 40.0
    UpdaterOptions.h:46     - sigma_pix: 1.80
    VioManagerOptions.h:183   Updater ARUCO Tags:
    UpdaterOptions.h:45     - chi2_multipler: 5.0
    VioManagerOptions.h:185   Updater ZUPT:
    VioManagerOptions.h:292 STATE PARAMETERS:
    VioManagerOptions.h:293   - gravity_mag: 9.8100
    VioManagerOptions.h:294   - gravity: 0.000, 0.000, 9.810
    VioManagerOptions.h:295   - camera masks?: 1
    VioManagerOptions.h:304   - calib_camimu_dt: 0.0015
    VioManagerOptions.h:320 cam_0_fisheye:1
    cam_0_wh:
    1280 x 800
    -0.5  0.5 -0.5  0.5
      0.037      -0 -0.0006
    T_C0toI:
               0            0            0            1
    VioManagerOptions.h:320 cam_1_fisheye:1
    cam_1_wh:
    1280 x 800
    T_C1toI:
               0            0            0            1
    VioManagerOptions.h:426 FEATURE TRACKING PARAMETERS:
    VioManagerOptions.h:427   - use_stereo: 0
    VioManagerOptions.h:428   - use_klt: 1
    VioManagerOptions.h:429   - use_aruco: 0
    VioManagerOptions.h:430   - downsize aruco: 1
    VioManagerOptions.h:431   - downsize cameras: 0
    VioManagerOptions.h:432   - num opencv threads: 9
    VioManagerOptions.h:433   - use multi-threading pubs: 1
    VioManagerOptions.h:434   - use multi-threading subs: 1
    VioManagerOptions.h:435   - num_pts: 30
    VioManagerOptions.h:436   - fast threshold: 15
    VioManagerOptions.h:437   - grid X by Y: 5 by 5
    VioManagerOptions.h:438   - min px dist: 50
    VioManagerOptions.h:439   - hist method: 1
    VioManagerOptions.h:440   - knn ratio: 0.700
    VioManagerOptions.h:441   - track frequency: 15.0
    VioManagerOptions.h:442   - limit imu propagation (windows based on init_imu+cam-imu delay): 1
    FeatureInitializerOptions.h:87 	- triangulate_1d: 0
    FeatureInitializerOptions.h:88 	- refine_features: 0
    FeatureInitializerOptions.h:89 	- max_runs: 5
    FeatureInitializerOptions.h:90 	- init_lamda: 0.001
    FeatureInitializerOptions.h:91 	- max_lamda: 10000000000.000
    FeatureInitializerOptions.h:92 	- min_dx: 0.0000010
    FeatureInitializerOptions.h:93 	- min_dcost: 0.0000010
    FeatureInitializerOptions.h:94 	- lam_mult: 10.000
    FeatureInitializerOptions.h:95 	- min_dist: 0.100
    FeatureInitializerOptions.h:96 	- max_dist: 60.000
    FeatureInitializerOptions.h:97 	- max_baseline: 40.000
    FeatureInitializerOptions.h:98 	- max_cond_number: 600000.000
    Set camera intrinsics and extrinsics
    ====> Using Internal KLT feature tracker <====
    >>>>>>>>>> Current reference counts:
    trackDB: 1
    trackFEATS: 1
    propagator: 2
    updaterMSCKF: 1
    updaterSLAM: 1
    active_tracks_initializer: 1
    initializer: 1
    setting scheduler
    INFO: set FIFO priority successfully!
    create_server_pipes
    connecting client pipes
    Number of Cameras active: 2
    Camera merge --- > ch: 1 to cam id: 0
    Opening camera pipe: tracking_front
    tmp_camera_pipe_names.push_back(): tracking_front
    Camera merge --- > ch: 2 to cam id: 1
    Opening camera pipe: tracking_down
    tmp_camera_pipe_names.push_back(): tracking_down
    imu pipe name: imu_apps
    Camera processing thread is now locked to the following cores: 7
    VioManager.cpp:454 [TIME]: 0.0358 seconds for tracking
    VioManagerHelper.cpp:174 [init]: failed initialization in 0.0000 seconds
    VioManager.cpp:454 [TIME]: 0.0139 seconds for tracking
    InertialInitializer.cpp:127 [init]: not enough feats to compute disp: 0,0 < 15
    VioManagerHelper.cpp:174 [init]: failed initialization in 0.0002 seconds
    VioManager.cpp:454 [TIME]: 0.0170 seconds for tracking
    VioManagerHelper.cpp:174 [init]: failed initialization in 0.0003 seconds
    VioManager.cpp:454 [TIME]: 0.0162 seconds for tracking
    InertialInitializer.cpp:127 [init]: not enough feats to compute disp: 0,62 < 15
    VioManagerHelper.cpp:174 [init]: failed initialization in 0.0001 seconds
    VioManager.cpp:454 [TIME]: 0.0112 seconds for tracking
    VioManager.cpp:454 [TIME]: 0.0175 seconds for tracking
    VioManager.cpp:454 [TIME]: 0.0156 seconds for tracking
    VioManager.cpp:454 [TIME]: 0.0105 seconds for tracking
    VioManager.cpp:454 [TIME]: 0.0169 seconds for tracking
    InertialInitializer.cpp:134 [init]: *** disparity is 0.000,0.000 (3.00 thresh)
    InertialInitializer.cpp:145 [init]: USING STATIC INITIALIZER METHOD!
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 241.141469 - 240.222589  (0.918880)
    StaticInitializer.cpp:55 [init-s]: unable to select window of IMU readings, not enough readings
    VioManagerHelper.cpp:174 [init]: failed initialization in 0.0004 seconds
    VioManager.cpp:454 [TIME]: 0.0115 seconds for tracking
    StaticInitializer.cpp:104 [init-s]: IMU excitation stats: 0.029,0.014
    VioManagerHelper.cpp:138 [init]: successful initialization in 0.0008 seconds
    VioManagerHelper.cpp:140 [init]: orientation = -0.0029, 0.0025, 0.0000, 1.0000
    VioManagerHelper.cpp:142 [init]: bias gyro = 0.0025, 0.0000, 0.0016
    VioManagerHelper.cpp:144 [init]: velocity = 0.0000, 0.0000, 0.0000
    VioManagerHelper.cpp:146 [init]: bias accel = 0.0000, 0.0000, -0.0046
    VioManagerHelper.cpp:148 [init]: position = 0.0000, 0.0000, 0.0000
    VioManagerHelper.cpp:168 [init]: moved the state forward 0.00 seconds
    StateHelper.cpp:686 new augment clone at timestamp: 241.367844
    waiting for enough clone states (1 of 5)....
    [INFO] TAKEOFF: DISPARITY disturbed, possible motion detected. Avg: 91.364071 (3.000000)	# feats: 5 (20).
    UpdaterZeroVelocity.cpp:242 [ZUPT]: failed disparity (91.364 > 3.000, 5 features)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 99.575 < 113.145)
    [INFO] TAKEOFF: DISPARITY disturbed, possible motion detected. Avg: 0.000000 (3.000000)	# feats: 5 (20).
    UpdaterZeroVelocity.cpp:242 [ZUPT]: failed disparity (0.000 > 3.000, 5 features)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.007 (chi2 62.236 < 106.395)
    UpdaterZeroVelocity.cpp:233 [ZUPT]: passed disparity (0.000 < 3.000, 40 features)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.004 (chi2 88.421 < 119.871)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.004 (chi2 96.190 < 119.871)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 132.910 < 119.871)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 95.202 < 119.871)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.003 (chi2 76.613 < 106.395)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.002 (chi2 105.215 < 113.145)
    UpdaterZeroVelocity.cpp:255 [ZUPT]: accepted |v_IinG| = 0.002 (chi2 86.990 < 119.871)
    @Zachary-Lowell-0 so those params are after running voxl-configure-mpa; i still dont understand why there's a diff between the apparently same v2 starlings.
    i can run the imu_apps calibration and retry OV.
    just for clarity here's the diff of the two params above:
    --- px4.params	2024-10-30 16:15:04.683354722 +0100
    +++ Downloads/params_update.params	2024-10-30 16:59:34.597742954 +0100
    @@ -25,11 +25,11 @@
     1	1	CAL_ACC0_ID	2490378	6
     1	1	CAL_ACC0_PRIO	50	6
     1	1	CAL_ACC0_ROT	-1	6
    -1	1	CAL_ACC0_XOFF	-0.004399999976158142	9
    +1	1	CAL_ACC0_XOFF	-0.041400000452995300	9
     1	1	CAL_ACC0_XSCALE	1.000000000000000000	9
    -1	1	CAL_ACC0_YOFF	0.004999999888241291	9
    +1	1	CAL_ACC0_YOFF	-0.014000000432133675	9
     1	1	CAL_ACC0_YSCALE	1.000000000000000000	9
    -1	1	CAL_ACC0_ZOFF	-0.136299997568130493	9
    +1	1	CAL_ACC0_ZOFF	-0.050900001078844070	9
     1	1	CAL_ACC0_ZSCALE	1.000000000000000000	9
     1	1	CAL_ACC1_ID	0	6
     1	1	CAL_ACC2_ID	0	6
    @@ -44,9 +44,9 @@
     1	1	CAL_GYRO0_ID	2490378	6
     1	1	CAL_GYRO0_PRIO	50	6
     1	1	CAL_GYRO0_ROT	-1	6
    -1	1	CAL_GYRO0_XOFF	0.009499999694526196	9
    -1	1	CAL_GYRO0_YOFF	0.012900000438094139	9
    -1	1	CAL_GYRO0_ZOFF	0.003199999919161201	9
    +1	1	CAL_GYRO0_XOFF	0.001399999950081110	9
    +1	1	CAL_GYRO0_YOFF	0.019099999219179153	9
    +1	1	CAL_GYRO0_ZOFF	-0.001799999969080091	9
     1	1	CAL_GYRO1_ID	0	6
     1	1	CAL_GYRO2_ID	0	6
     1	1	CAL_GYRO3_ID	0	6
    @@ -54,17 +54,17 @@
     1	1	CAL_MAG0_PRIO	75	6
     1	1	CAL_MAG0_ROT	0	6
     1	1	CAL_MAG0_XCOMP	0.000000000000000000	9
    -1	1	CAL_MAG0_XODIAG	-0.002300000051036477	9
    -1	1	CAL_MAG0_XOFF	0.019600000232458115	9
    -1	1	CAL_MAG0_XSCALE	0.371300011873245239	9
    +1	1	CAL_MAG0_XODIAG	-0.027599999681115150	9
    +1	1	CAL_MAG0_XOFF	-0.093400001525878906	9
    +1	1	CAL_MAG0_XSCALE	1.085199952125549316	9
     1	1	CAL_MAG0_YCOMP	0.000000000000000000	9
    -1	1	CAL_MAG0_YODIAG	0.009100000374019146	9
    -1	1	CAL_MAG0_YOFF	0.122199997305870056	9
    -1	1	CAL_MAG0_YSCALE	0.383500009775161743	9
    +1	1	CAL_MAG0_YODIAG	0.014800000004470348	9
    +1	1	CAL_MAG0_YOFF	0.249599993228912354	9
    +1	1	CAL_MAG0_YSCALE	0.836799979209899902	9
     1	1	CAL_MAG0_ZCOMP	0.000000000000000000	9
    -1	1	CAL_MAG0_ZODIAG	0.008999999612569809	9
    -1	1	CAL_MAG0_ZOFF	-4.477099895477294922	9
    -1	1	CAL_MAG0_ZSCALE	0.055500000715255737	9
    +1	1	CAL_MAG0_ZODIAG	-0.007000000216066837	9
    +1	1	CAL_MAG0_ZOFF	-0.107400000095367432	9
    +1	1	CAL_MAG0_ZSCALE	1.048200011253356934	9
     1	1	CAL_MAG1_ID	0	6
     1	1	CAL_MAG1_ROT	-1	6
     1	1	CAL_MAG2_ID	0	6
    @@ -632,10 +632,10 @@
     1	1	RC11_REV	1.000000000000000000	9
     1	1	RC11_TRIM	1500.000000000000000000	9
     1	1	RC12_DZ	0.000000000000000000	9
    -1	1	RC12_MAX	1988.000000000000000000	9
    -1	1	RC12_MIN	1011.000000000000000000	9
    +1	1	RC12_MAX	2000.000000000000000000	9
    +1	1	RC12_MIN	1000.000000000000000000	9
     1	1	RC12_REV	1.000000000000000000	9
    -1	1	RC12_TRIM	1499.000000000000000000	9
    +1	1	RC12_TRIM	1500.000000000000000000	9
     1	1	RC13_DZ	0.000000000000000000	9
     1	1	RC13_MAX	2000.000000000000000000	9
     1	1	RC13_MIN	1000.000000000000000000	9
    @@ -668,44 +668,44 @@
     1	1	RC18_TRIM	1500.000000000000000000	9
     1	1	RC1_DZ	10.000000000000000000	9
     1	1	RC1_MAX	2000.000000000000000000	9
    -1	1	RC1_MIN	1000.000000000000000000	9
    +1	1	RC1_MIN	1001.000000000000000000	9
     1	1	RC1_REV	1.000000000000000000	9
    -1	1	RC1_TRIM	1500.000000000000000000	9
    +1	1	RC1_TRIM	1499.000000000000000000	9
     1	1	RC2_DZ	10.000000000000000000	9
     1	1	RC2_MAX	2000.000000000000000000	9
    -1	1	RC2_MIN	1000.000000000000000000	9
    +1	1	RC2_MIN	1001.000000000000000000	9
     1	1	RC2_REV	1.000000000000000000	9
    -1	1	RC2_TRIM	1500.000000000000000000	9
    +1	1	RC2_TRIM	1501.000000000000000000	9
     1	1	RC3_DZ	10.000000000000000000	9
     1	1	RC3_MAX	2000.000000000000000000	9
    -1	1	RC3_MIN	1000.000000000000000000	9
    +1	1	RC3_MIN	1001.000000000000000000	9
     1	1	RC3_REV	1.000000000000000000	9
    -1	1	RC3_TRIM	1500.000000000000000000	9
    +1	1	RC3_TRIM	1001.000000000000000000	9
     1	1	RC4_DZ	10.000000000000000000	9
     1	1	RC4_MAX	2000.000000000000000000	9
    -1	1	RC4_MIN	1000.000000000000000000	9
    +1	1	RC4_MIN	1001.000000000000000000	9
     1	1	RC4_REV	1.000000000000000000	9
    -1	1	RC4_TRIM	1500.000000000000000000	9
    +1	1	RC4_TRIM	1507.000000000000000000	9
     1	1	RC5_DZ	10.000000000000000000	9
     1	1	RC5_MAX	1988.000000000000000000	9
     1	1	RC5_MIN	1011.000000000000000000	9
     1	1	RC5_REV	1.000000000000000000	9
    -1	1	RC5_TRIM	1500.000000000000000000	9
    +1	1	RC5_TRIM	1499.000000000000000000	9
     1	1	RC6_DZ	10.000000000000000000	9
     1	1	RC6_MAX	1988.000000000000000000	9
     1	1	RC6_MIN	1011.000000000000000000	9
     1	1	RC6_REV	1.000000000000000000	9
    -1	1	RC6_TRIM	1500.000000000000000000	9
    +1	1	RC6_TRIM	1499.000000000000000000	9
     1	1	RC7_DZ	10.000000000000000000	9
     1	1	RC7_MAX	1988.000000000000000000	9
     1	1	RC7_MIN	1011.000000000000000000	9
     1	1	RC7_REV	1.000000000000000000	9
    -1	1	RC7_TRIM	1500.000000000000000000	9
    +1	1	RC7_TRIM	1499.000000000000000000	9
     1	1	RC8_DZ	10.000000000000000000	9
     1	1	RC8_MAX	1988.000000000000000000	9
     1	1	RC8_MIN	1011.000000000000000000	9
     1	1	RC8_REV	1.000000000000000000	9
    -1	1	RC8_TRIM	1500.000000000000000000	9
    +1	1	RC8_TRIM	1499.000000000000000000	9
     1	1	RC9_DZ	0.000000000000000000	9
     1	1	RC9_MAX	2000.000000000000000000	9
     1	1	RC9_MIN	1000.000000000000000000	9
    @@ -774,8 +774,8 @@
     1	1	SENS_BARO_QNH	1013.250000000000000000	9
     1	1	SENS_BARO_RATE	20.000000000000000000	9
     1	1	SENS_BOARD_ROT	0	6
    -1	1	SENS_BOARD_X_OFF	-0.067400000989437103	9
    -1	1	SENS_BOARD_Y_OFF	-0.318699985742568970	9
    +1	1	SENS_BOARD_X_OFF	-0.587000012397766113	9
    +1	1	SENS_BOARD_Y_OFF	-0.263300001621246338	9
     1	1	SENS_BOARD_Z_OFF	0.000000000000000000	9
     1	1	SENS_DPRES_OFF	0.000000000000000000	9
     1	1	SENS_GPS_MASK	7	6
    note when dumping the same params on the another starling v2 drone i'm getting a slightly different set of params, which i have no idea why it is.
    # Onboard parameters for Vehicle 1
    # Stack: PX4 Pro
    # Vehicle: Multi-Rotor
    # Version: 1.14.0 dev
    # Git Revision: 70d986f08a020054
    # Vehicle-Id Component-Id Name Value Type
    1	1	ASPD_SCALE_1	1.000000000000000000	9
    1	1	BAT1_CAPACITY	3950.000000000000000000	9
    1	1	BAT1_N_CELLS	2	6
    1	1	BAT1_R_INTERNAL	0.021999999880790710	9
    1	1	BAT1_SOURCE	0	6
    1	1	BAT1_V_CHARGED	4.099999904632568359	9
    1	1	BAT1_V_EMPTY	2.799999952316284180	9
    1	1	BAT1_V_LOAD_DROP	0.100000001490116119	9
    1	1	BAT_AVRG_CURRENT	4.300000190734863281	9
    1	1	BAT_CRIT_THR	0.100000001490116119	9
    1	1	BAT_EMERGEN_THR	0.050000000745058060	9
    1	1	BAT_LOW_THR	0.150000005960464478	9
    1	1	BAT_N_CELLS	3	6
    1	1	BAT_V_CHARGED	4.050000190734863281	9
    1	1	BAT_V_EMPTY	3.599999904632568359	9
    1	1	BAT_V_LOAD_DROP	0.300000011920928955	9
    1	1	CAL_ACC1_ID	0	6
    1	1	CAL_ACC2_ID	0	6
    1	1	CAL_ACC3_ID	0	6
    1	1	CAL_AIR_CMODEL	0	6
    1	1	CAL_AIR_TUBED_MM	1.500000000000000000	9
    1	1	CAL_AIR_TUBELEN	0.200000002980232239	9
    1	1	CAL_BARO0_ID	0	6
    1	1	CAL_BARO1_ID	0	6
    1	1	CAL_BARO2_ID	0	6
    1	1	CAL_BARO3_ID	0	6
    1	1	CAL_MAG0_ID	527625	6
    1	1	CAL_MAG1_ID	0	6
    1	1	CAL_MAG2_ID	0	6
    1	1	CAL_MAG2_ROT	-1	6
    1	1	CAL_MAG3_ID	0	6
    1	1	CAL_MAG3_ROT	-1	6
    1	1	CAL_MAG_COMP_TYP	0	6
    1	1	CAL_MAG_SIDES	63	6
    1	1	CA_AIRFRAME	0	6
    1	1	CA_FAILURE_MODE	0	6
    1	1	CA_METHOD	2	6
    1	1	CA_R0_SLEW	0.000000000000000000	9
    1	1	CA_R10_SLEW	0.000000000000000000	9
    1	1	CA_R11_SLEW	0.000000000000000000	9
    1	1	CA_R1_SLEW	0.000000000000000000	9
    1	1	CA_R2_SLEW	0.000000000000000000	9
    1	1	CA_R3_SLEW	0.000000000000000000	9
    1	1	CA_R4_SLEW	0.000000000000000000	9
    1	1	CA_R5_SLEW	0.000000000000000000	9
    1	1	CA_R6_SLEW	0.000000000000000000	9
    1	1	CA_R7_SLEW	0.000000000000000000	9
    1	1	CA_R8_SLEW	0.000000000000000000	9
    1	1	CA_R9_SLEW	0.000000000000000000	9
    1	1	CA_ROTOR0_AX	0.000000000000000000	9
    1	1	CA_ROTOR0_AY	0.000000000000000000	9
    1	1	CA_ROTOR0_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR0_CT	6.500000000000000000	9
    1	1	CA_ROTOR0_KM	0.050000000745058060	9
    1	1	CA_ROTOR0_PX	0.085000000894069672	9
    1	1	CA_ROTOR0_PY	0.062500000000000000	9
    1	1	CA_ROTOR0_PZ	0.000000000000000000	9
    1	1	CA_ROTOR10_AX	0.000000000000000000	9
    1	1	CA_ROTOR10_AY	0.000000000000000000	9
    1	1	CA_ROTOR10_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR10_CT	6.500000000000000000	9
    1	1	CA_ROTOR10_KM	0.050000000745058060	9
    1	1	CA_ROTOR10_PX	0.000000000000000000	9
    1	1	CA_ROTOR10_PY	0.000000000000000000	9
    1	1	CA_ROTOR10_PZ	0.000000000000000000	9
    1	1	CA_ROTOR11_AX	0.000000000000000000	9
    1	1	CA_ROTOR11_AY	0.000000000000000000	9
    1	1	CA_ROTOR11_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR11_CT	6.500000000000000000	9
    1	1	CA_ROTOR11_KM	0.050000000745058060	9
    1	1	CA_ROTOR11_PX	0.000000000000000000	9
    1	1	CA_ROTOR11_PY	0.000000000000000000	9
    1	1	CA_ROTOR11_PZ	0.000000000000000000	9
    1	1	CA_ROTOR1_AX	0.000000000000000000	9
    1	1	CA_ROTOR1_AY	0.000000000000000000	9
    1	1	CA_ROTOR1_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR1_CT	6.500000000000000000	9
    1	1	CA_ROTOR1_KM	0.050000000745058060	9
    1	1	CA_ROTOR1_PX	-0.085000000894069672	9
    1	1	CA_ROTOR1_PY	-0.062500000000000000	9
    1	1	CA_ROTOR1_PZ	0.000000000000000000	9
    1	1	CA_ROTOR2_AX	0.000000000000000000	9
    1	1	CA_ROTOR2_AY	0.000000000000000000	9
    1	1	CA_ROTOR2_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR2_CT	6.500000000000000000	9
    1	1	CA_ROTOR2_KM	-0.050000000745058060	9
    1	1	CA_ROTOR2_PX	0.085000000894069672	9
    1	1	CA_ROTOR2_PY	-0.062500000000000000	9
    1	1	CA_ROTOR2_PZ	0.000000000000000000	9
    1	1	CA_ROTOR3_AX	0.000000000000000000	9
    1	1	CA_ROTOR3_AY	0.000000000000000000	9
    1	1	CA_ROTOR3_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR3_CT	6.500000000000000000	9
    1	1	CA_ROTOR3_KM	-0.050000000745058060	9
    1	1	CA_ROTOR3_PX	-0.085000000894069672	9
    1	1	CA_ROTOR3_PY	0.062500000000000000	9
    1	1	CA_ROTOR3_PZ	0.000000000000000000	9
    1	1	CA_ROTOR4_AX	0.000000000000000000	9
    1	1	CA_ROTOR4_AY	0.000000000000000000	9
    1	1	CA_ROTOR4_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR4_CT	6.500000000000000000	9
    1	1	CA_ROTOR4_KM	0.050000000745058060	9
    1	1	CA_ROTOR4_PX	0.000000000000000000	9
    1	1	CA_ROTOR4_PY	0.000000000000000000	9
    1	1	CA_ROTOR4_PZ	0.000000000000000000	9
    1	1	CA_ROTOR5_AX	0.000000000000000000	9
    1	1	CA_ROTOR5_AY	0.000000000000000000	9
    1	1	CA_ROTOR5_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR5_CT	6.500000000000000000	9
    1	1	CA_ROTOR5_KM	0.050000000745058060	9
    1	1	CA_ROTOR5_PX	0.000000000000000000	9
    1	1	CA_ROTOR5_PY	0.000000000000000000	9
    1	1	CA_ROTOR5_PZ	0.000000000000000000	9
    1	1	CA_ROTOR6_AX	0.000000000000000000	9
    1	1	CA_ROTOR6_AY	0.000000000000000000	9
    1	1	CA_ROTOR6_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR6_CT	6.500000000000000000	9
    1	1	CA_ROTOR6_KM	0.050000000745058060	9
    1	1	CA_ROTOR6_PX	0.000000000000000000	9
    1	1	CA_ROTOR6_PY	0.000000000000000000	9
    1	1	CA_ROTOR6_PZ	0.000000000000000000	9
    1	1	CA_ROTOR7_AX	0.000000000000000000	9
    1	1	CA_ROTOR7_AY	0.000000000000000000	9
    1	1	CA_ROTOR7_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR7_CT	6.500000000000000000	9
    1	1	CA_ROTOR7_KM	0.050000000745058060	9
    1	1	CA_ROTOR7_PX	0.000000000000000000	9
    1	1	CA_ROTOR7_PY	0.000000000000000000	9
    1	1	CA_ROTOR7_PZ	0.000000000000000000	9
    1	1	CA_ROTOR8_AX	0.000000000000000000	9
    1	1	CA_ROTOR8_AY	0.000000000000000000	9
    1	1	CA_ROTOR8_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR8_CT	6.500000000000000000	9
    1	1	CA_ROTOR8_KM	0.050000000745058060	9
    1	1	CA_ROTOR8_PX	0.000000000000000000	9
    1	1	CA_ROTOR8_PY	0.000000000000000000	9
    1	1	CA_ROTOR8_PZ	0.000000000000000000	9
    1	1	CA_ROTOR9_AX	0.000000000000000000	9
    1	1	CA_ROTOR9_AY	0.000000000000000000	9
    1	1	CA_ROTOR9_AZ	-1.000000000000000000	9
    1	1	CA_ROTOR9_CT	6.500000000000000000	9
    1	1	CA_ROTOR9_KM	0.050000000745058060	9
    1	1	CA_ROTOR9_PX	0.000000000000000000	9
    1	1	CA_ROTOR9_PY	0.000000000000000000	9
    1	1	CA_ROTOR9_PZ	0.000000000000000000	9
    1	1	CA_ROTOR_COUNT	4	6
    1	1	CA_R_REV	0	6
    1	1	CA_SV0_SLEW	0.000000000000000000	9
    1	1	CA_SV1_SLEW	0.000000000000000000	9
    1	1	CA_SV2_SLEW	0.000000000000000000	9
    1	1	CA_SV3_SLEW	0.000000000000000000	9
    1	1	CA_SV4_SLEW	0.000000000000000000	9
    1	1	CA_SV5_SLEW	0.000000000000000000	9
    1	1	CA_SV6_SLEW	0.000000000000000000	9
    1	1	CA_SV7_SLEW	0.000000000000000000	9
    1	1	CBRK_AIRSPD_CHK	0	6
    1	1	CBRK_FLIGHTTERM	121212	6
    1	1	CBRK_IO_SAFETY	22027	6
    1	1	CBRK_SUPPLY_CHK	894281	6
    1	1	CBRK_USB_CHK	197848	6
    1	1	CBRK_VTOLARMING	0	6
    1	1	COM_ACT_FAIL_ACT	0	6
    1	1	COM_ARM_ARSP_EN	1	6
    1	1	COM_ARM_AUTH_ID	10	6
    1	1	COM_ARM_AUTH_MET	0	6
    1	1	COM_ARM_AUTH_REQ	0	6
    1	1	COM_ARM_AUTH_TO	1.000000000000000000	9
    1	1	COM_ARM_BAD_INOV	0	6
    1	1	COM_ARM_CHK_ESCS	0	6
    1	1	COM_ARM_EKF_BIAS	3.000000000000000000	9
    1	1	COM_ARM_EKF_HGT	1.000000000000000000	9
    1	1	COM_ARM_EKF_POS	0.500000000000000000	9
    1	1	COM_ARM_EKF_VEL	0.500000000000000000	9
    1	1	COM_ARM_EKF_YAW	0.500000000000000000	9
    1	1	COM_ARM_HFLT_CHK	1	6
    1	1	COM_ARM_IMU_ACC	0.699999988079071045	9
    1	1	COM_ARM_IMU_GYR	0.250000000000000000	9
    1	1	COM_ARM_MAG_ANG	60	6
    1	1	COM_ARM_MAG_STR	2	6
    1	1	COM_ARM_MIS_REQ	0	6
    1	1	COM_ARM_ODID	0	6
    1	1	COM_ARM_SDCARD	0	6
    1	1	COM_ARM_SWISBTN	0	6
    1	1	COM_ARM_WO_GPS	1	6
    1	1	COM_CPU_MAX	-1.000000000000000000	9
    1	1	COM_DISARM_FORCE	0	6
    1	1	COM_DISARM_LAND	0.100000001490116119	9
    1	1	COM_DISARM_PRFLT	20.000000000000000000	9
    1	1	COM_DL_LOSS_T	10	6
    1	1	COM_FAIL_ACT_T	5.000000000000000000	9
    1	1	COM_FLIGHT_UUID	0	6
    1	1	COM_FLTMODE1	0	6
    1	1	COM_FLTMODE2	0	6
    1	1	COM_FLTMODE3	2	6
    1	1	COM_FLTMODE4	2	6
    1	1	COM_FLTMODE5	7	6
    1	1	COM_FLTMODE6	7	6
    1	1	COM_FLT_PROFILE	0	6
    1	1	COM_FLT_TIME_MAX	-1	6
    1	1	COM_FORCE_SAFETY	0	6
    1	1	COM_HLDL_LOSS_T	120	6
    1	1	COM_HLDL_REG_T	0	6
    1	1	COM_HOME_EN	1	6
    1	1	COM_HOME_IN_AIR	0	6
    1	1	COM_IMB_PROP_ACT	0	6
    1	1	COM_KILL_DISARM	0.000000000000000000	9
    1	1	COM_LKDOWN_TKO	3.000000000000000000	9
    1	1	COM_LOW_BAT_ACT	0	6
    1	1	COM_MOT_TEST_EN	1	6
    1	1	COM_OBC_LOSS_T	5.000000000000000000	9
    1	1	COM_OBL_RC_ACT	0	6
    1	1	COM_OBS_AVOID	0	6
    1	1	COM_OF_LOSS_T	1.000000000000000000	9
    1	1	COM_PARACHUTE	0	6
    1	1	COM_POSCTL_NAVL	0	6
    1	1	COM_POS_FS_DELAY	1	6
    1	1	COM_POS_FS_EPH	5.000000000000000000	9
    1	1	COM_POS_LOW_EPH	-1.000000000000000000	9
    1	1	COM_POWER_COUNT	1	6
    1	1	COM_PREARM_MODE	0	6
    1	1	COM_QC_ACT	0	6
    1	1	COM_RCL_EXCEPT	0	6
    1	1	COM_RC_ARM_HYST	1000	6
    1	1	COM_RC_IN_MODE	3	6
    1	1	COM_RC_LOSS_T	0.500000000000000000	9
    1	1	COM_RC_OVERRIDE	1	6
    1	1	COM_RC_STICK_OV	30.000000000000000000	9
    1	1	COM_SPOOLUP_TIME	2.000000000000000000	9
    1	1	COM_TAKEOFF_ACT	0	6
    1	1	COM_VEL_FS_EVH	1.000000000000000000	9
    1	1	COM_WIND_MAX	-1.000000000000000000	9
    1	1	COM_WIND_WARN	-1.000000000000000000	9
    1	1	CP_DELAY	0.400000005960464478	9
    1	1	CP_DIST	-1.000000000000000000	9
    1	1	CP_GO_NO_DATA	0	6
    1	1	CP_GUIDE_ANG	30.000000000000000000	9
    1	1	EKF2_ABIAS_INIT	0.200000002980232239	9
    1	1	EKF2_ABL_ACCLIM	25.000000000000000000	9
    1	1	EKF2_ABL_GYRLIM	3.000000000000000000	9
    1	1	EKF2_ABL_LIM	0.400000005960464478	9
    1	1	EKF2_ABL_TAU	0.500000000000000000	9
    1	1	EKF2_ACC_B_NOISE	0.003000000026077032	9
    1	1	EKF2_ACC_NOISE	0.349999994039535522	9
    1	1	EKF2_AID_MASK	0	6
    1	1	EKF2_ANGERR_INIT	0.100000001490116119	9
    1	1	EKF2_ARSP_THR	0.000000000000000000	9
    1	1	EKF2_ASPD_MAX	20.000000000000000000	9
    1	1	EKF2_ASP_DELAY	100.000000000000000000	9
    1	1	EKF2_AVEL_DELAY	5.000000000000000000	9
    1	1	EKF2_BARO_CTRL	1	6
    1	1	EKF2_BARO_DELAY	0.000000000000000000	9
    1	1	EKF2_BARO_GATE	5.000000000000000000	9
    1	1	EKF2_BARO_NOISE	3.500000000000000000	9
    1	1	EKF2_BCOEF_X	100.000000000000000000	9
    1	1	EKF2_BCOEF_Y	100.000000000000000000	9
    1	1	EKF2_BETA_GATE	5.000000000000000000	9
    1	1	EKF2_BETA_NOISE	0.300000011920928955	9
    1	1	EKF2_DECL_TYPE	7	6
    1	1	EKF2_DRAG_CTRL	0	6
    1	1	EKF2_DRAG_NOISE	2.500000000000000000	9
    1	1	EKF2_EAS_NOISE	1.399999976158142090	9
    1	1	EKF2_EVA_NOISE	0.100000001490116119	9
    1	1	EKF2_EVP_GATE	5.000000000000000000	9
    1	1	EKF2_EVP_NOISE	0.100000001490116119	9
    1	1	EKF2_EVV_GATE	3.000000000000000000	9
    1	1	EKF2_EVV_NOISE	0.100000001490116119	9
    1	1	EKF2_EV_CTRL	15	6
    1	1	EKF2_EV_DELAY	0.000000000000000000	9
    1	1	EKF2_EV_HGT_TO	5000	6
    1	1	EKF2_EV_NOISE_MD	0	6
    1	1	EKF2_EV_POS_TO	1000	6
    1	1	EKF2_EV_POS_X	0.000000000000000000	9
    1	1	EKF2_EV_POS_Y	0.000000000000000000	9
    1	1	EKF2_EV_POS_Z	0.000000000000000000	9
    1	1	EKF2_EV_QMIN	1	6
    1	1	EKF2_FUSE_BETA	0	6
    1	1	EKF2_GBIAS_INIT	0.100000001490116119	9
    1	1	EKF2_GND_EFF_DZ	4.000000000000000000	9
    1	1	EKF2_GND_MAX_HGT	0.500000000000000000	9
    1	1	EKF2_GPS_CHECK	245	6
    1	1	EKF2_GPS_CTRL	0	6
    1	1	EKF2_GPS_DELAY	110.000000000000000000	9
    1	1	EKF2_GPS_POS_X	0.000000000000000000	9
    1	1	EKF2_GPS_POS_Y	0.000000000000000000	9
    1	1	EKF2_GPS_POS_Z	0.000000000000000000	9
    1	1	EKF2_GPS_P_GATE	5.000000000000000000	9
    1	1	EKF2_GPS_P_NOISE	0.500000000000000000	9
    1	1	EKF2_GPS_V_GATE	5.000000000000000000	9
    1	1	EKF2_GPS_V_NOISE	0.300000011920928955	9
    1	1	EKF2_GRAV_NOISE	1.000000000000000000	9
    1	1	EKF2_GSF_TAS	15.000000000000000000	9
    1	1	EKF2_GYR_B_LIM	0.150000005960464478	9
    1	1	EKF2_GYR_B_NOISE	0.001000000047497451	9
    1	1	EKF2_GYR_NOISE	0.014999999664723873	9
    1	1	EKF2_HDG_GATE	2.599999904632568359	9
    1	1	EKF2_HEAD_NOISE	0.300000011920928955	9
    1	1	EKF2_HGT_REF	3	6
    1	1	EKF2_IMU_CTRL	3	6
    1	1	EKF2_IMU_POS_X	0.004300000146031380	9
    1	1	EKF2_IMU_POS_Y	0.007300000172108412	9
    1	1	EKF2_IMU_POS_Z	-0.016000000759959221	9
    1	1	EKF2_MAG_ACCLIM	0.500000000000000000	9
    1	1	EKF2_MAG_B_NOISE	0.000099999997473788	9
    1	1	EKF2_MAG_CHECK	1	6
    1	1	EKF2_MAG_DECL	0.000000000000000000	9
    1	1	EKF2_MAG_DELAY	0.000000000000000000	9
    1	1	EKF2_MAG_E_NOISE	0.001000000047497451	9
    1	1	EKF2_MAG_GATE	3.000000000000000000	9
    1	1	EKF2_MAG_NOISE	0.050000000745058060	9
    1	1	EKF2_MAG_TYPE	5	6
    1	1	EKF2_MAG_YAWLIM	0.200000002980232239	9
    1	1	EKF2_MCOEF	0.150000005960464478	9
    1	1	EKF2_MIN_RNG	0.100000001490116119	9
    1	1	EKF2_NOAID_NOISE	10.000000000000000000	9
    1	1	EKF2_NOAID_TOUT	5000000	6
    1	1	EKF2_OF_CTRL	0	6
    1	1	EKF2_OF_DELAY	20.000000000000000000	9
    1	1	EKF2_OF_GATE	3.000000000000000000	9
    1	1	EKF2_OF_N_MAX	0.500000000000000000	9
    1	1	EKF2_OF_N_MIN	0.150000005960464478	9
    1	1	EKF2_OF_POS_X	0.000000000000000000	9
    1	1	EKF2_OF_POS_Y	0.000000000000000000	9
    1	1	EKF2_OF_POS_Z	0.000000000000000000	9
    1	1	EKF2_OF_QMIN	1	6
    1	1	EKF2_PCOEF_XN	0.000000000000000000	9
    1	1	EKF2_PCOEF_XP	0.000000000000000000	9
    1	1	EKF2_PCOEF_YN	0.000000000000000000	9
    1	1	EKF2_PCOEF_YP	0.000000000000000000	9
    1	1	EKF2_PCOEF_Z	0.000000000000000000	9
    1	1	EKF2_PREDICT_US	10000	6
    1	1	EKF2_REQ_EPH	3.000000000000000000	9
    1	1	EKF2_REQ_EPV	5.000000000000000000	9
    1	1	EKF2_REQ_GPS_H	5.000000000000000000	9
    1	1	EKF2_REQ_HDRIFT	0.100000001490116119	9
    1	1	EKF2_REQ_NSATS	6	6
    1	1	EKF2_REQ_PDOP	2.500000000000000000	9
    1	1	EKF2_REQ_SACC	1.500000000000000000	9
    1	1	EKF2_REQ_VDRIFT	0.200000002980232239	9
    1	1	EKF2_RNG_A_HMAX	5.000000000000000000	9
    1	1	EKF2_RNG_A_IGATE	1.000000000000000000	9
    1	1	EKF2_RNG_A_VMAX	1.000000000000000000	9
    1	1	EKF2_RNG_CTRL	0	6
    1	1	EKF2_RNG_DELAY	5.000000000000000000	9
    1	1	EKF2_RNG_GATE	5.000000000000000000	9
    1	1	EKF2_RNG_K_GATE	1.000000000000000000	9
    1	1	EKF2_RNG_NOISE	0.100000001490116119	9
    1	1	EKF2_RNG_PITCH	0.000000000000000000	9
    1	1	EKF2_RNG_POS_X	0.000000000000000000	9
    1	1	EKF2_RNG_POS_Y	0.000000000000000000	9
    1	1	EKF2_RNG_POS_Z	0.000000000000000000	9
    1	1	EKF2_RNG_QLTY_T	1.000000000000000000	9
    1	1	EKF2_RNG_SFE	0.050000000745058060	9
    1	1	EKF2_SYNT_MAG_Z	0	6
    1	1	EKF2_TAS_GATE	3.000000000000000000	9
    1	1	EKF2_TAU_POS	0.250000000000000000	9
    1	1	EKF2_TAU_VEL	0.250000000000000000	9
    1	1	EKF2_TERR_GRAD	0.500000000000000000	9
    1	1	EKF2_TERR_MASK	3	6
    1	1	EKF2_TERR_NOISE	5.000000000000000000	9
    1	1	EKF2_WIND_NSD	0.009999999776482582	9
    1	1	FD_ACT_EN	1	6
    1	1	FD_ACT_MOT_C2T	2.000000000000000000	9
    1	1	FD_ACT_MOT_THR	0.200000002980232239	9
    1	1	FD_ACT_MOT_TOUT	100	6
    1	1	FD_ESCS_EN	1	6
    1	1	FD_EXT_ATS_EN	0	6
    1	1	FD_EXT_ATS_TRIG	1900	6
    1	1	FD_FAIL_P	60	6
    1	1	FD_FAIL_P_TTRI	0.300000011920928955	9
    1	1	FD_FAIL_R	60	6
    1	1	FD_FAIL_R_TTRI	0.300000011920928955	9
    1	1	FD_IMB_PROP_THR	30	6
    1	1	FLW_TGT_ALT_M	0	6
    1	1	FLW_TGT_DST	8.000000000000000000	9
    1	1	FLW_TGT_FA	180.000000000000000000	9
    1	1	FLW_TGT_HT	8.000000000000000000	9
    1	1	FLW_TGT_MAX_VEL	5.000000000000000000	9
    1	1	FLW_TGT_RS	0.100000001490116119	9
    1	1	FW_AIRSPD_MAX	20.000000000000000000	9
    1	1	FW_AIRSPD_TRIM	15.000000000000000000	9
    1	1	FW_ARSP_MODE	0	6
    1	1	FW_PSP_OFF	0.000000000000000000	9
    1	1	FW_T_CLMB_R_SP	3.000000000000000000	9
    1	1	FW_T_SINK_R_SP	2.000000000000000000	9
    1	1	GF_ACTION	2	6
    1	1	GF_ALTMODE	0	6
    1	1	GF_COUNT	-1	6
    1	1	GF_MAX_HOR_DIST	0.000000000000000000	9
    1	1	GF_MAX_VER_DIST	0.000000000000000000	9
    1	1	GF_PREDICT	0	6
    1	1	GF_SOURCE	0	6
    1	1	GND_SPEED_THR_SC	1.000000000000000000	9
    1	1	GPIO_CTL_CH	0	6
    1	1	GPS_1_GNSS	0	6
    1	1	GPS_1_PROTOCOL	1	6
    1	1	GPS_DUMP_COMM	0	6
    1	1	GPS_PITCH_OFFSET	0.000000000000000000	9
    1	1	GPS_SAT_INFO	0	6
    1	1	GPS_UBX_BAUD2	230400	6
    1	1	GPS_UBX_CFG_INTF	0	6
    1	1	GPS_UBX_DYNMODEL	7	6
    1	1	GPS_UBX_MODE	0	6
    1	1	GPS_YAW_OFFSET	0.000000000000000000	9
    1	1	HTE_ACC_GATE	3.000000000000000000	9
    1	1	HTE_HT_ERR_INIT	0.100000001490116119	9
    1	1	HTE_HT_NOISE	0.003599999938160181	9
    1	1	HTE_THR_RANGE	0.200000002980232239	9
    1	1	HTE_VXY_THR	10.000000000000000000	9
    1	1	HTE_VZ_THR	2.000000000000000000	9
    1	1	IMU_ACCEL_CUTOFF	80.000000000000000000	9
    1	1	IMU_DGYRO_CUTOFF	60.000000000000000000	9
    1	1	IMU_GYRO_CUTOFF	80.000000000000000000	9
    1	1	IMU_GYRO_DNF_BW	15.000000000000000000	9
    1	1	IMU_GYRO_DNF_EN	1	6
    1	1	IMU_GYRO_DNF_HMC	3	6
    1	1	IMU_GYRO_DNF_MIN	25.000000000000000000	9
    1	1	IMU_GYRO_NF0_BW	20.000000000000000000	9
    1	1	IMU_GYRO_NF0_FRQ	0.000000000000000000	9
    1	1	IMU_GYRO_NF1_BW	20.000000000000000000	9
    1	1	IMU_GYRO_NF1_FRQ	0.000000000000000000	9
    1	1	IMU_GYRO_RATEMAX	800	6
    1	1	IMU_INTEG_RATE	200	6
    1	1	LNDMC_ALT_GND	2.000000000000000000	9
    1	1	LNDMC_ALT_MAX	-1.000000000000000000	9
    1	1	LNDMC_ROT_MAX	30.000000000000000000	9
    1	1	LNDMC_TRIG_TIME	0.500000000000000000	9
    1	1	LNDMC_XY_VEL_MAX	1.500000000000000000	9
    1	1	LNDMC_Z_VEL_MAX	0.250000000000000000	9
    1	1	LND_FLIGHT_T_HI	0	6
    1	1	LND_FLIGHT_T_LO	0	6
    1	1	MAN_ARM_GESTURE	1	6
    1	1	MAV_COMP_ID	1	6
    1	1	MAV_FWDEXTSP	1	6
    1	1	MAV_HASH_CHK_EN	1	6
    1	1	MAV_HB_FORW_EN	1	6
    1	1	MAV_PROTO_VER	0	6
    1	1	MAV_RADIO_TOUT	5	6
    1	1	MAV_SIK_RADIO_ID	0	6
    1	1	MAV_SYS_ID	1	6
    1	1	MAV_TYPE	2	6
    1	1	MAV_USEHILGPS	0	6
    1	1	MC_ACRO_EXPO	0.689999997615814209	9
    1	1	MC_ACRO_EXPO_Y	0.689999997615814209	9
    1	1	MC_ACRO_P_MAX	720.000000000000000000	9
    1	1	MC_ACRO_R_MAX	720.000000000000000000	9
    1	1	MC_ACRO_SUPEXPO	0.699999988079071045	9
    1	1	MC_ACRO_SUPEXPOY	0.699999988079071045	9
    1	1	MC_ACRO_Y_MAX	540.000000000000000000	9
    1	1	MC_AIRMODE	0	6
    1	1	MC_AT_APPLY	1	6
    1	1	MC_AT_AXES	3	6
    1	1	MC_AT_RISE_TIME	0.140000000596046448	9
    1	1	MC_AT_START	0	6
    1	1	MC_AT_SYSID_AMP	0.699999988079071045	9
    1	1	MC_BAT_SCALE_EN	0	6
    1	1	MC_INJECT_AMP	0.050000000745058060	9
    1	1	MC_INJECT_CNT	12	6
    1	1	MC_INJECT_EN	0	6
    1	1	MC_INJECT_INC	1.000000000000000000	9
    1	1	MC_INJECT_REST_T	1.000000000000000000	9
    1	1	MC_INJECT_RPY	2	6
    1	1	MC_INJECT_SINE_T	5.000000000000000000	9
    1	1	MC_INJECT_START	3.000000000000000000	9
    1	1	MC_MAN_TILT_TAU	0.000000000000000000	9
    1	1	MC_ORBIT_RAD_MAX	1000.000000000000000000	9
    1	1	MC_PITCHRATE_D	0.001099999994039536	9
    1	1	MC_PITCHRATE_FF	0.000000000000000000	9
    1	1	MC_PITCHRATE_I	0.228000000119209290	9
    1	1	MC_PITCHRATE_K	1.000000000000000000	9
    1	1	MC_PITCHRATE_MAX	130.000000000000000000	9
    1	1	MC_PITCHRATE_P	0.097000002861022949	9
    1	1	MC_PITCH_CUTOFF	30.000000000000000000	9
    1	1	MC_PITCH_P	16.000000000000000000	9
    1	1	MC_PR_INT_LIM	0.300000011920928955	9
    1	1	MC_ROLLRATE_D	0.000899999984540045	9
    1	1	MC_ROLLRATE_FF	0.000000000000000000	9
    1	1	MC_ROLLRATE_I	0.171000003814697266	9
    1	1	MC_ROLLRATE_K	1.000000000000000000	9
    1	1	MC_ROLLRATE_MAX	130.000000000000000000	9
    1	1	MC_ROLLRATE_P	0.071999996900558472	9
    1	1	MC_ROLL_CUTOFF	30.000000000000000000	9
    1	1	MC_ROLL_P	16.000000000000000000	9
    1	1	MC_RR_INT_LIM	0.300000011920928955	9
    1	1	MC_THR_CURVE_ACR	0	6
    1	1	MC_YAWRATE_D	0.000000000000000000	9
    1	1	MC_YAWRATE_FF	0.000000000000000000	9
    1	1	MC_YAWRATE_I	0.500000000000000000	9
    1	1	MC_YAWRATE_K	1.000000000000000000	9
    1	1	MC_YAWRATE_MAX	150.000000000000000000	9
    1	1	MC_YAWRATE_P	0.150000005960464478	9
    1	1	MC_YAW_CUTOFF	10.000000000000000000	9
    1	1	MC_YAW_P	2.799999952316284180	9
    1	1	MC_YAW_WEIGHT	0.400000005960464478	9
    1	1	MC_YR_INT_LIM	0.300000011920928955	9
    1	1	MIS_DIST_1WP	900.000000000000000000	9
    1	1	MIS_LND_ABRT_ALT	30	6
    1	1	MIS_MNT_YAW_CTL	0	6
    1	1	MIS_PD_TO	5.000000000000000000	9
    1	1	MIS_TAKEOFF_ALT	2.500000000000000000	9
    1	1	MIS_TKO_LAND_REQ	0	6
    1	1	MIS_YAW_ERR	12.000000000000000000	9
    1	1	MIS_YAW_TMT	-1.000000000000000000	9
    1	1	MODALAI_CONFIG	0	6
    1	1	MOT_SLEW_MAX	0.000000000000000000	9
    1	1	MPC_ACC_DOWN_MAX	3.000000000000000000	9
    1	1	MPC_ACC_HOR	3.000000000000000000	9
    1	1	MPC_ACC_HOR_MAX	1000.000000000000000000	9
    1	1	MPC_ACC_UP_MAX	3.000000000000000000	9
    1	1	MPC_ALT_MODE	0	6
    1	1	MPC_HOLD_DZ	0.100000001490116119	9
    1	1	MPC_HOLD_MAX_XY	0.000000000000000000	9
    1	1	MPC_HOLD_MAX_Z	0.000000000000000000	9
    1	1	MPC_JERK_AUTO	4.000000000000000000	9
    1	1	MPC_JERK_MAX	40.000000000000000000	9
    1	1	MPC_LAND_ALT1	10.000000000000000000	9
    1	1	MPC_LAND_ALT2	5.000000000000000000	9
    1	1	MPC_LAND_ALT3	1.000000000000000000	9
    1	1	MPC_LAND_CRWL	0.300000011920928955	9
    1	1	MPC_LAND_RADIUS	1000.000000000000000000	9
    1	1	MPC_LAND_RC_HELP	0	6
    1	1	MPC_LAND_SPEED	1.000000000000000000	9
    1	1	MPC_MANTHR_MIN	0.079999998211860657	9
    1	1	MPC_MAN_TILT_MAX	35.000000000000000000	9
    1	1	MPC_MAN_Y_MAX	150.000000000000000000	9
    1	1	MPC_MAN_Y_TAU	0.079999998211860657	9
    1	1	MPC_POS_MODE	4	6
    1	1	MPC_THR_CURVE	0	6
    1	1	MPC_THR_HOVER	0.340000003576278687	9
    1	1	MPC_THR_MAX	0.600000023841857910	9
    1	1	MPC_THR_MIN	0.079999998211860657	9
    1	1	MPC_THR_XY_MARG	0.300000011920928955	9
    1	1	MPC_TILTMAX_AIR	30.000000000000000000	9
    1	1	MPC_TILTMAX_LND	12.000000000000000000	9
    1	1	MPC_TKO_RAMP_T	1.000000000000000000	9
    1	1	MPC_TKO_SPEED	1.500000000000000000	9
    1	1	MPC_USE_HTE	1	6
    1	1	MPC_VELD_LP	5.000000000000000000	9
    1	1	MPC_VEL_MANUAL	3.000000000000000000	9
    1	1	MPC_VEL_MAN_BACK	-1.000000000000000000	9
    1	1	MPC_VEL_MAN_SIDE	-1.000000000000000000	9
    1	1	MPC_XY_CRUISE	3.000000000000000000	9
    1	1	MPC_XY_ERR_MAX	2.000000000000000000	9
    1	1	MPC_XY_MAN_EXPO	0.449999988079071045	9
    1	1	MPC_XY_P	3.500000000000000000	9
    1	1	MPC_XY_TRAJ_P	0.500000000000000000	9
    1	1	MPC_XY_VEL_ALL	-10.000000000000000000	9
    1	1	MPC_XY_VEL_D_ACC	0.000000000000000000	9
    1	1	MPC_XY_VEL_I_ACC	0.100000001490116119	9
    1	1	MPC_XY_VEL_MAX	3.000000000000000000	9
    1	1	MPC_XY_VEL_P_ACC	3.000000000000000000	9
    1	1	MPC_YAWRAUTO_MAX	45.000000000000000000	9
    1	1	MPC_YAW_EXPO	0.300000011920928955	9
    1	1	MPC_YAW_MODE	0	6
    1	1	MPC_Z_MAN_EXPO	0.100000001490116119	9
    1	1	MPC_Z_P	5.000000000000000000	9
    1	1	MPC_Z_VEL_ALL	-3.000000000000000000	9
    1	1	MPC_Z_VEL_D_ACC	0.000000000000000000	9
    1	1	MPC_Z_VEL_I_ACC	2.000000000000000000	9
    1	1	MPC_Z_VEL_MAX_DN	1.000000000000000000	9
    1	1	MPC_Z_VEL_MAX_UP	1.000000000000000000	9
    1	1	MPC_Z_VEL_P_ACC	8.000000000000000000	9
    1	1	MPC_Z_V_AUTO_DN	1.000000000000000000	9
    1	1	MPC_Z_V_AUTO_UP	1.000000000000000000	9
    1	1	NAV_ACC_RAD	10.000000000000000000	9
    1	1	NAV_DLL_ACT	0	6
    1	1	NAV_FORCE_VT	1	6
    1	1	NAV_FW_ALTL_RAD	5.000000000000000000	9
    1	1	NAV_FW_ALT_RAD	10.000000000000000000	9
    1	1	NAV_LOITER_RAD	80.000000000000000000	9
    1	1	NAV_MC_ALT_RAD	0.800000011920928955	9
    1	1	NAV_MIN_LTR_ALT	-1.000000000000000000	9
    1	1	NAV_RCL_ACT	2	6
    1	1	NAV_TRAFF_AVOID	1	6
    1	1	NAV_TRAFF_A_HOR	500.000000000000000000	9
    1	1	NAV_TRAFF_A_VER	500.000000000000000000	9
    1	1	NAV_TRAFF_COLL_T	60	6
    1	1	PLD_BTOUT	5.000000000000000000	9
    1	1	PLD_FAPPR_ALT	0.100000001490116119	9
    1	1	PLD_HACC_RAD	0.200000002980232239	9
    1	1	PLD_MAX_SRCH	3	6
    1	1	PLD_SRCH_ALT	10.000000000000000000	9
    1	1	PLD_SRCH_TOUT	10.000000000000000000	9
    1	1	RC10_DZ	0.000000000000000000	9
    1	1	RC10_MAX	2000.000000000000000000	9
    1	1	RC10_MIN	1000.000000000000000000	9
    1	1	RC10_REV	1.000000000000000000	9
    1	1	RC10_TRIM	1500.000000000000000000	9
    1	1	RC11_DZ	0.000000000000000000	9
    1	1	RC11_MAX	2000.000000000000000000	9
    1	1	RC11_MIN	1000.000000000000000000	9
    1	1	RC13_REV	1.000000000000000000	9
    1	1	RC13_TRIM	1500.000000000000000000	9
    1	1	RC14_DZ	0.000000000000000000	9
    1	1	RC14_MAX	2000.000000000000000000	9
    1	1	RC14_MIN	1000.000000000000000000	9
    1	1	RC14_REV	1.000000000000000000	9
    1	1	RC14_TRIM	1500.000000000000000000	9
    1	1	RC15_DZ	0.000000000000000000	9
    1	1	RC15_MAX	2000.000000000000000000	9
    1	1	RC15_MIN	1000.000000000000000000	9
    1	1	RC15_REV	1.000000000000000000	9
    1	1	RC15_TRIM	1500.000000000000000000	9
    1	1	RC16_DZ	0.000000000000000000	9
    1	1	RC16_MAX	2000.000000000000000000	9
    1	1	RC16_MIN	1000.000000000000000000	9
    1	1	RC16_REV	1.000000000000000000	9
    1	1	RC16_TRIM	1500.000000000000000000	9
    1	1	RC17_DZ	0.000000000000000000	9
    1	1	RC17_MAX	2000.000000000000000000	9
    1	1	RC17_MIN	1000.000000000000000000	9
    1	1	RC17_REV	1.000000000000000000	9
    1	1	RC17_TRIM	1500.000000000000000000	9
    1	1	RC18_DZ	0.000000000000000000	9
    1	1	RC18_MAX	2000.000000000000000000	9
    1	1	RC18_MIN	1000.000000000000000000	9
    1	1	RC18_REV	1.000000000000000000	9
    1	1	RC9_REV	1.000000000000000000	9
    1	1	RC9_TRIM	1500.000000000000000000	9
    1	1	RC_ARMSWITCH_TH	0.750000000000000000	9
    1	1	RC_CHAN_CNT	16	6
    1	1	RC_CRSF_TEL_EN	0	6
    1	1	RC_ENG_MOT_TH	0.750000000000000000	9
    1	1	RC_FAILS_THR	0	6
    1	1	RC_GEAR_TH	0.750000000000000000	9
    1	1	RC_KILLSWITCH_TH	0.750000000000000000	9
    1	1	RC_LOITER_TH	0.750000000000000000	9
    1	1	RC_MAP_ACRO_SW	0	6
    1	1	RC_MAP_ARM_SW	0	6
    1	1	RC_MAP_AUX1	0	6
    1	1	RC_MAP_AUX2	0	6
    1	1	RC_MAP_AUX3	0	6
    1	1	RC_MAP_AUX4	0	6
    1	1	RC_MAP_AUX5	0	6
    1	1	RC_MAP_AUX6	0	6
    1	1	RC_MAP_ENG_MOT	0	6
    1	1	RC_MAP_FAILSAFE	0	6
    1	1	RC_MAP_FLAPS	0	6
    1	1	RC_MAP_FLTMODE	6	6
    1	1	RC_MAP_FLTM_BTN	0	6
    1	1	RC_MAP_GEAR_SW	0	6
    1	1	RC_MAP_KILL_SW	5	6
    1	1	RC_MAP_LOITER_SW	0	6
    1	1	RC_MAP_MAN_SW	0	6
    1	1	RC_MAP_MODE_SW	0	6
    1	1	RC_MAP_OFFB_SW	0	6
    1	1	RC_MAP_PARAM1	0	6
    1	1	RC_MAP_PARAM2	0	6
    1	1	RC_MAP_PARAM3	0	6
    1	1	RC_MAP_PITCH	2	6
    1	1	RC_MAP_POSCTL_SW	0	6
    1	1	RC_MAP_RATT_SW	0	6
    1	1	RC_MAP_RETURN_SW	0	6
    1	1	RC_MAP_ROLL	1	6
    1	1	RC_MAP_STAB_SW	0	6
    1	1	RC_MAP_THROTTLE	3	6
    1	1	RC_MAP_TRANS_SW	0	6
    1	1	RC_MAP_YAW	4	6
    1	1	RC_OFFB_TH	0.750000000000000000	9
    1	1	RC_RETURN_TH	0.750000000000000000	9
    1	1	RC_TRANS_TH	0.750000000000000000	9
    1	1	RTL_CONE_ANG	45	6
    1	1	RTL_DESCEND_ALT	30.000000000000000000	9
    1	1	RTL_HDG_MD	0	6
    1	1	RTL_LAND_DELAY	0.000000000000000000	9
    1	1	RTL_LOITER_RAD	80.000000000000000000	9
    1	1	RTL_MIN_DIST	10.000000000000000000	9
    1	1	RTL_PLD_MD	0	6
    1	1	RTL_RETURN_ALT	60.000000000000000000	9
    1	1	RTL_TIME_FACTOR	1.100000023841857910	9
    1	1	RTL_TIME_MARGIN	100	6
    1	1	RTL_TYPE	0	6
    1	1	SDLOG_BOOT_BAT	0	6
    1	1	SDLOG_DIRS_MAX	0	6
    1	1	SDLOG_MISSION	0	6
    1	1	SDLOG_MODE	0	6
    1	1	SDLOG_PROFILE	129	6
    1	1	SDLOG_UTC_OFFSET	0	6
    1	1	SDLOG_UUID	1	6
    1	1	SENS_GPS_PRIME	0	6
    1	1	SENS_GPS_TAU	10.000000000000000000	9
    1	1	SENS_IMU_AUTOCAL	0	6
    1	1	SENS_IMU_MODE	1	6
    1	1	SENS_MAG_AUTOCAL	0	6
    1	1	SENS_MAG_AUTOROT	0	6
    1	1	SENS_MAG_MODE	1	6
    1	1	SENS_MAG_RATE	15.000000000000000000	9
    1	1	SENS_MAG_SIDES	63	6
    1	1	SYS_AUTOCONFIG	0	6
    1	1	SYS_AUTOSTART	4001	6
    1	1	SYS_CAL_TDEL	24	6
    1	1	SYS_CAL_TMAX	10	6
    1	1	SYS_CAL_TMIN	5	6
    1	1	SYS_FAC_CAL_MODE	0	6
    1	1	SYS_FAILURE_EN	0	6
    1	1	SYS_HAS_BARO	1	6
    1	1	SYS_HAS_GPS	1	6
    1	1	SYS_HAS_MAG	1	6
    1	1	SYS_HAS_NUM_DIST	0	6
    1	1	SYS_HITL	0	6
    1	1	SYS_MC_EST_GROUP	2	6
    1	1	SYS_RGB_MAXBRT	1.000000000000000000	9
    1	1	SYS_STCK_EN	1	6
    1	1	SYS_VEHICLE_RESP	-0.400000005960464478	9
    1	1	THR_MDL_FAC	0.899999976158142090	9
    1	1	TRIG_MODE	0	6
    1	1	UAVCAN_ENABLE	0	6
    1	1	VOXL_ESC_BAUD	2000000	6
    1	1	VOXL_ESC_CONFIG	1	6
    1	1	VOXL_ESC_FUNC1	102	6
    1	1	VOXL_ESC_FUNC2	103	6
    1	1	VOXL_ESC_FUNC3	101	6
    1	1	VOXL_ESC_FUNC4	104	6
    1	1	VOXL_ESC_MODE	0	6
    1	1	VOXL_ESC_PUB_BST	1	6
    1	1	VOXL_ESC_REV	0	6
    1	1	VOXL_ESC_RPM_MAX	15000	6
    1	1	VOXL_ESC_RPM_MIN	2000	6
    1	1	VOXL_ESC_SDIR1	0	6
    1	1	VOXL_ESC_SDIR2	0	6
    1	1	VOXL_ESC_SDIR3	0	6
    1	1	VOXL_ESC_SDIR4	0	6
    1	1	VOXL_ESC_T_COSP	0.990000009536743164	9
    1	1	VOXL_ESC_T_DEAD	20	6
    1	1	VOXL_ESC_T_EXPO	35	6
    1	1	VOXL_ESC_T_MINF	0.150000005960464478	9
    1	1	VOXL_ESC_T_OVER	0	6
    1	1	VOXL_ESC_T_PERC	90	6
    1	1	VOXL_ESC_T_WARN	0	6
    1	1	VOXL_ESC_VLOG	1	6
    1	1	VTO_LOITER_ALT	80.000000000000000000	9
    1	1	VT_B_DEC_MSS	2.000000000000000000	9
    1	1	WV_EN	0	6
    1	1	WV_GAIN	1.000000000000000000	9
    1	1	WV_ROLL_MIN	1.000000000000000000	9
    1	1	WV_YRATE_MAX	90.000000000000000000	9
    1	1	XRCE_DDS_DOM_ID	0	6
    1	1	XRCE_DDS_KEY	1	6
    @Zachary-Lowell-0 it's a typical indoor environment (a room in a flat).
    # Stack: PX4 Pro
    1	1	BAT1_SOURCE	0	6
    1	1	BAT_N_CELLS	3	6
    1	1	CAL_ACC1_ID	0	6
    1	1	CAL_ACC2_ID	0	6
    1	1	CAL_ACC3_ID	0	6
    1	1	CAL_MAG1_ID	0	6
    1	1	CAL_MAG2_ID	0	6
    1	1	CAL_MAG3_ID	0	6
    1	1	CA_AIRFRAME	0	6
    1	1	CA_METHOD	2	6
    1	1	CA_R_REV	0	6
    1	1	COM_HOME_EN	1	6
    1	1	COM_QC_ACT	0	6
    1	1	FD_ACT_EN	1	6
    1	1	FD_ESCS_EN	1	6
    1	1	FD_FAIL_P	60	6
    1	1	FD_FAIL_R	60	6
    1	1	GF_ACTION	2	6
    1	1	GF_ALTMODE	0	6
    1	1	GF_COUNT	-1	6
    1	1	GF_PREDICT	0	6
    1	1	GF_SOURCE	0	6
    1	1	GPIO_CTL_CH	0	6
    1	1	GPS_1_GNSS	0	6
    1	1	MAV_COMP_ID	1	6
    1	1	MAV_SYS_ID	1	6
    1	1	MAV_TYPE	2	6
    1	1	MC_AIRMODE	0	6
    1	1	MC_AT_APPLY	1	6
    1	1	MC_AT_AXES	3	6
    1	1	MC_AT_START	0	6
    1	1	MPC_USE_HTE	1	6
    1	1	NAV_DLL_ACT	0	6
    1	1	NAV_RCL_ACT	2	6
    1	1	RC_MAP_AUX1	0	6
    1	1	RC_MAP_AUX2	0	6
    1	1	RC_MAP_AUX3	0	6
    1	1	RC_MAP_AUX4	0	6
    1	1	RC_MAP_AUX5	0	6
    1	1	RC_MAP_AUX6	0	6
    1	1	RC_MAP_ROLL	1	6
    1	1	RC_MAP_YAW	4	6
    1	1	RTL_HDG_MD	0	6
    1	1	RTL_PLD_MD	0	6
    1	1	RTL_TYPE	0	6
    1	1	SDLOG_MODE	0	6
    1	1	SDLOG_UUID	1	6
    1	1	SYS_HAS_GPS	1	6
    1	1	SYS_HAS_MAG	1	6
    1	1	SYS_HITL	0	6
    1	1	SYS_STCK_EN	1	6
    1	1	TRIG_MODE	0	6
    1	1	WV_EN	0	6
    @Zachary-Lowell-0 yep i i've constantly updating the stack and rerun voxl-configure-mpa. what parameters do you exactly need from PX4?
    @Zachary-Lowell-0 sure; basically 20% of the time it is working when i'm flying the drone around.
    at the moment it is:
    • constantly loosing Z axis estimate, so it is just shooting up to the air uncontrollably
    • loosing speed estimation and then just shoots out to some random direction
    • the yaw estimates; again getting uncontrollable.
    so yeah at the moment i have 4 starling drones (mostly v2) and they are really not usable most of the time with qvio.
