Syed OmairS
Syed Omair
@Syed Omair
  • help with pip installing opencv
    Syed OmairS Syed Omair
    hello,
    i am trying to run this command in my m500 drone "pip3 install opencv-python" inside the provided ubuntu docker container from modal ai. i was able to simply do a pip3 install numpy and pip3 install pandas. but pip3 -v install opencv-python is becoming a very lengthy process taking almost 3 hours before failing with an error. i can understand from the debugger output that it is building the library somehow.
    "ERROR: Could not build wheels for opencv-python which use PEP 517 and cannot be installed directly"
    no matter what I try it won't install. is there an easy solution to get opencv working in the docker container ? i am working with is python 3.5.2 and pip 20.3.4
    i consulted this stackoverflow question for solutions
    https://stackoverflow.com/questions/63732353/error-could-not-build-wheels-for-opencv-python-which-use-pep-517-and-cannot-be
    thank you,
    omair
  • how can i have a more recent version of ubuntu using docker
    hello everybody,
    i have a m500 development drone. I am following this tutorial
    https://docs.modalai.com/docker-on-voxl/
    to have docker on my drone but i kind of want to use a more recent version of ubuntu because i want a more recent version of python to work with.
    like i want to be able to install more recent versions of numpy and opencv and pandas packages and run scripts on the drone itself.
    however, installing the pip version of python3 itself on roskinetic-xenial_v1_0 docker image is something of a pain itself. and in the end it doesn't work.
    i was looking for a solution where i didn't have to deal with outdated distributions...
    someone said they were able to do ros:noetic-robot a more recent version of python and ubuntu running but when i try to do it I get an error
    here is the forum post
    https://forum.modalai.com/topic/1699/out-of-space-for-docker-load-i/4?_=1717186547613
    i accidentally asked in the wrong forum (FAQs) so reposting here. any help is appreciated
    thanks,
    omair
  • having a more recent version of ubuntu using docker
    hello everybody,
    the forum post
    any help would be appreciated
    thanks,
    omair
    FAQs
  • Out of space for docker load -i
    @tpavlic
    heyyy... i do agree that using roskinetic and xenial is kind of a dumb thing... could you help me with something ? are you using the m500 drone with voxl 1 here to do the "docker pull ros:noetic-robot" command? if you are i do get an error saying
    Error: Status 410 trying to pull repository library/ros: "<html>\r\n<head><title>410 Gone</title></head>\r\n<body>\r\n<center><h1>410 Gone</h1></center>\r\n<hr><center>openresty</center>\r\n</body>\r\n</html>\r\n"
    i really kind of want to use the higher versions of python and a more recent ubuntu distribution.
    any tips or suggestions ?
    Development Drones m500
  • m500: export sensor data as a json file
    Hello everyone,
    I have a m500 drone and after a flight I would like to export all the sensor data from the drone to a json file. looking at the docs, couldn't find much help. could someone point me in the direction? I basically want to gather all the data provided by all the voxl-inspect-* commands like voxl-inspect-cpu voxl-inspect-gps etc. ideally i'd prefer python but I see some C libraries involved on this page here
  • m500 camera stream
    @Alex-Kushleyev
    I apologize for being late. I am aware of the voxl-portal for debugging purposes but no that's not what I want for now. like I want to be able to read the data frame by frame using a python script which reads from a rtsp "live" link. I think its just configuring the voxl-streamer server to something else ? idk I am lost on what to do her
    two more questions
    1. is there a way for me to also in real time read the point cloud data ? I can view one the being generated in the voxl-portal section "pointcloud" but I want to read the actual pointcloud dataset in real time so I can do some other visualizations with it.
    2. I would love if you could let me know how i can read quaternion data in real time as well..
    Thank you
    can someone tell me how I can stream video from a different camera than the hi res camera ? like I want to be able to see all of these
    cameras
    I followed steps on this site but was only able to get hires
    https://docs.modalai.com/voxl-streamer-0_9/
    thank you
  • px4 disconnected from uart
    @Dobry-Kolacz thanksss!!!
    @Adrian-Hidalgo thank you so much. I am sorry I saw this so late
    @tom hey tom. Thanks it worked. I just had to resrt TELEM1 to default settings through qgroundcontrol and then run voxl-configure-mavlink-server and reset the mavlink server to default settings and after that it connected wirelessly automatically.
    But on a side note, can you also help me in pairing a taranis x7 transmitter to the m500 drone. I ordered the drone with the frsky transmitter but is it supposed to be on the drone somewhere or does it come separate like shown in the documentation??
    like so https://www.youtube.com/watch?v=1IYg5mQdLVI
    I am unable to find it on the drone anywhere. thank you.
    @tom I’ll be in touch once I get the cable and test it out
    @tom apologies I saw this so late.
    I cannot connect to qgroundcontrol since the error started showing. it used to automatically connect but it doesn't anymore. I have the correct ip address and everything. I try to initiate a connection from qgroundcontrol but this is what i get.
    also external_fc was disabled (false) so i made it true.
    @tom said in px4 disconnected from uart:
    Reply Quote 0
    I believe its all in one board. i have pictures.
    and thanks for the quick reply !!!
    @Syed-Omair I tried the voxl-uart-loopback tests and I fail all 4 of them. can someone please help!!!!
    I have the m500 drone. I get error PX4 DISCONNECTED FROM UART. can someone help ???
  • can't connect m500 drone to qgroundcontrol
    for anyone who has the voxl-qvio issue where it says state FAIL, just try centering (using your fingers and wiggling) the voxl board and it will work. I think it just needs to be centered.
    I have seen multiple posts on this forum with the same issue and tried multiple solutions but none of them seem to work
    some of the things I have tried.
    • changing sdk versions (tldr: upgraded from 0.9.4 -> 0.9.5, it wasn't working.)
      voxl upgrade guide
      "connected to voxl-mavlink-server but no messages from PX4"
    • checked and "external_fc" is false
      "Connected to voxl-mavlink-server but no messages from PX4" again 🙂
    • tried monitoring if mavlink is sending messages. and nothing works.
      mavlink monitoring
    • something that is potentially interesting. this down here wasn't the case before.
      below is the output to voxl-qvio-server
    • followed this guide.
      Connect m500 to PX4
    • checked for loose connections. unplugged and plugged everything back in
      loose connection
    • I want to try this solution but I can't get a wired connection to qgroundcontrol. any help with that would be appreciated
      wired connection to qgc solution
    Thank you for your time and help,
    Omair
