S
Sarika Sharma
@Sarika Sharma
  • Switching between Mag+GPS and VIO indoors
    S Sarika Sharma
    Hii @Eric-Katzfey ,
    I am trying to install the voxl-mainline-px4 package on a VOXL2 Mini (M0104) running VOXL SDK 1.6.3.
    The installation fails due to a dependency on a newer version of libfc-sensor.
    System information
    • Hardware: VOXL2 Mini (M0104)
    • SDK: 1.6.3
    • Installed library:
    libfc-sensor 1.0.9
    Command used
    sudo dpkg -i voxl-mainline-px4_1.17.0-1.0.2-202602240859_arm64.deb
    Error
    voxl-mainline-px4 depends on libfc-sensor (>= 1.0.10); however:
    Version of libfc-sensor on system is 1.0.9.
    Package metadata
    Running dpkg -s voxl-mainline-px4 shows:
    Depends:
    libfc-sensor (>= 1.0.10),
    voxl-px4-params (>= 0.3.10),
    voxl2-system-image (>= 1.5.4),
    modalai-slpi (>= 1.1.16)
    Repository check
    The SDK repository only provides:
    libfc-sensor 1.0.9
    apt-cache policy libfc-sensor
    Installed: 1.0.9
    Candidate: 1.0.9
    Question
    How to solve this issue???
    Thanks.
  • How to Fuse VL53L1X Rangefinder for Height-Above-Ground (HAGL) Estimation with PX4 on VOXL2
    S Sarika Sharma
    Hi ModalAI Team,
    I am working with a VOXL2 Mini test fixture (TF-M0104) and trying to integrate a VL53L1X ToF rangefinder with PX4 for altitude hold / height-above-ground estimation.
    My goal is for PX4 EKF2 to fuse the rangefinder data so that the drone can use the sensor for altitude estimation (dist_bottom / HAGL).
    Sensor configuration:
    /etc/modalai/voxl-rangefinder-server.conf
    "i2c_bus": 0,
    "vl53l1x_timing_budget_ms": 50,
    "id_for_mavlink": 0,
    "sensors": [{
    "enabled": true,
    "sensor_id": 0,
    "type": "TOF_VL53L1X",
    "fov_deg": 15,
    "range_max_m": 3,
    "location_wrt_body": [0,0,0],
    "direction_wrt_body": [0,0,1],
    "is_on_mux": false
    PX4 parameters
    EKF2_HGT_REF = 2
    EKF2_RNG_CTRL = 1
    EKF2_RNG_A_HMAX = 11.5 ft
    SENS_EN_VL53L1X : 1
    Sensor data received in PX4
    px4-listener distance_sensor
    current_distance: 0.62
    signal_quality: 100
    orientation: 25
    So PX4 is receiving the rangefinder data correctly.
    However, when I check:
    voxl2-mini-test-fixture (TF-M0104):/etc/modalai$ px4-listener vehicle_local_position
    TOPIC: vehicle_local_position
    timestamp: 1258315007 (0.002534 seconds ago)
    timestamp_sample: 1258313140 (1867 us before timestamp)
    ref_timestamp: 0
    ref_lat: nan
    ref_lon: nan
    x: -58.15529
    y: -29.38294
    z: -43.47373
    delta_xy: [-8.27161, 3.48610]
    delta_z: 0.00000
    vx: -5.77044
    vy: -8.23159
    vz: 0.09748
    z_deriv: 0.09754
    delta_vxy: [-0.89175, 1.40937]
    delta_vz: 0.65828
    ax: 1.33592
    ay: -1.74908
    az: 0.01860
    heading: 2.12604
    delta_heading: 1.62808
    ref_alt: nan
    dist_bottom: 0.10000
    eph: 0.61074
    epv: 0.20321
    evh: 0.41361
    evv: 0.11114
    vxy_max: inf
    vz_max: inf
    hagl_min: inf
    hagl_max: inf
    xy_valid: True
    z_valid: True
    v_xy_valid: True
    v_z_valid: True
    xy_reset_counter: 32
    z_reset_counter: 6
    vxy_reset_counter: 37
    vz_reset_counter: 26
    heading_reset_counter: 17
    heading_good_for_control: False
    xy_global: False
    z_global: False
    dist_bottom_valid: False
    dist_bottom_sensor_bitfield: 0
    dead_reckoning: True
    which means EKF2 is not fusing the rangefinder measurement.
    Am I missing any configuration steps to enable rangefinder fusion for altitude hold on VOXL2?
    S Sarika Sharma
    Hii @Eric-Katzfey we wanted to confirm whether ModalAI has a recommended parameter set or procedure to achieve a smooth transition between outdoor and indoor flight on VOXL 2 mini ??
  • PX4 -> QGC connection through USB for VOXL2
    S Sarika Sharma
    What is the recommended workflow to switch between usb0 and wlan0 ????
    as when i tried to use voxl-wifi in station mode ,it configured succesfully.
    But current IP is still:
    voxl2-mini-test-fixture (TF-M0104):~$ voxl-my-ip
    usb0: 192.168.7.2
    S Sarika Sharma
    Thankyou so much @Alex-Kushleyev
    This setup solves my use case where Wi-Fi is not available. Thanks for the support — looking forward to the scripted version in the future.
    Best regards,
    Sarika
  • Hardware configuration for 2× M0014 tracking + 1× M0169 PMD ToF + 1× M0024 HiRes
    S Sarika Sharma
    Hii @Alex-Kushleyev , Thankyou so much for your time...
    Previously, I said 4 cameras are detected and working properly only with M0135 interposer not with M0084 flex cable and the screenshot above is taken while using M0084 flex cables that's why only 3 cameras are detected out of 4 and hires is not streaming.
    S Sarika Sharma
    @Alex-Kushleyev
    S Sarika Sharma
    @Alex-Kushleyev Hi ,
    Thanks for the explanation.
    I tested this on VOXL2 Mini and can confirm the following observations:
    With kernel 2.0.0, all 4 cameras are detected correctly, but only with the specific hardware configuration below.
    Working hardware configuration:
    J6 → M0135
    JL: HiRes
    JU: Tracking
    J7 → M0135
    JL: Tracking
    JU: PMD-ToF
    In this configuration, all four cameras are detected successfully.
    Additional observation regarding M0084 flex cables(with kernel 2.0.0):
    I have two different M0084 flex cables, and I’m seeing :
    With one M0084 cable, the HiRes camera is detected, but no high-resolution stream appears in voxl-portal.
    With the other M0084 cable, the HiRes camera is not detected properly. The voxl-camera-server log shows:
    Starting Camera: hires (id #0)
    ERROR: Camera 0 failed to find supported stream config: 1024x768
    WARNING: Failed to start cam hires due to invalid resolution
    WARNING: assuming cam is missing and trying to compensate
    S Sarika Sharma
    @modaltb Hii, is there any update on this?
    S Sarika Sharma
    @Alex-Kushleyev Hii, Kindly look at the hardware configuration .
    I am only able to detect 2 cameras out of 4 cameras .
    Hires and one out of 2 tracking are not detected.
  • ToF sensor and VOA
    S Sarika Sharma
    @James-Strawson Hii , I am also getting the same issue . Kindly look at the following details . I have defined tof in my extrinsics.conf file as given below:
    parent: body
    child: tof
    T_child_wrt_parent: 0.070 0.024 -0.029
    RPY_parent_to_child: 0.0 90.0 90.0
    R_child_to_parent: 0.000 -0.000 1.000
    1.000 0.000 -0.000
    -0.000 1.000 0.000
    when i run voxl-vision-hub -s i got the following
    slice 0 dist none back
    slice 1 dist none
    slice 2 dist none
    slice 3 dist none
    slice 4 dist none
    slice 5 dist none
    slice 6 dist none
    slice 7 dist none
    slice 8 dist none
    slice 9 dist none left
    slice 10 dist none
    slice 11 dist none
    slice 12 dist none
    slice 13 dist none
    slice 14 dist none
    slice 15 dist none
    slice 16 dist none
    slice 17 dist none
    slice 18 dist none forward
    slice 19 dist none
    slice 20 dist none
    slice 21 dist none
    slice 22 dist none
    slice 23 dist none
    slice 24 dist none
    slice 25 dist none
    slice 26 dist none
    slice 27 dist none right
    slice 28 dist none
    and in my vision-hub-conf file i have the folloeing set up:
    "en_vio": true,
    "vio_pipe": "qvio",
    "secondary_vio_pipe": "ov",
    "vfc_vio_pipe": "ov",
    "vio_warmup_s": 3,
    "send_odom_while_failed": true,
    "horizon_cal_tolerance": 0.5,
    "en_hitl": false,
    "offboard_mode": "figure_eight",
    "follow_tag_id": 0,
    "figure_eight_move_home": true,
    "collision_sampling_dt": 0.1,
    "max_lookahead_distance": 1,
    "backtrack_seconds": 60,
    "backtrack_rc_chan": 8,
    "backtrack_rc_thresh": 1500,
    "wps_move_home": true,
    "wps_stride": 0,
    "wps_timeout": 0,
    "wps_damp": 1,
    "wps_vfc_mission": true,
    "wps_vfc_mission_loop": false,
    "wps_vfc_mission_to_ramp": 25,
    "wps_vfc_mission_to_kp": 0.10000000149011612,
    "wps_vfc_mission_cruise_speed": 1,
    "en_tag_fixed_frame": false,
    "fixed_frame_filter_len": 5,
    "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
    "vfc_rate": 100,
    "vfc_rc_chan_min": 980,
    "vfc_rc_chan_max": 2020,
    "vfc_thrust_ch": 3,
    "vfc_roll_ch": 1,
    "vfc_pitch_ch": 2,
    "vfc_yaw_ch": 4,
    "vfc_submode_ch": 6,
    "vfc_alt_mode_rc_min": 0,
    "vfc_alt_mode_rc_max": 0,
    "vfc_flow_mode_rc_min": 0,
    "vfc_flow_mode_rc_max": 0,
    "vfc_hybrid_flow_mode_rc_min": 0,
    "vfc_hybrid_flow_mode_rc_max": 0,
    "vfc_position_mode_rc_min": 0,
    "vfc_position_mode_rc_max": 2100,
    "vfc_traj_mode_rc_min": 0,
    "vfc_traj_mode_rc_max": 0,
    "vfc_yaw_deadband": 30,
    "vfc_vxy_deadband": 50,
    "vfc_vz_deadband": 150,
    "vfc_min_thrust": 0,
    "vfc_max_thrust": 0.800000011920929,
    "vfc_tilt_max": 0.43599998950958252,
    "vfc_yaw_rate_max": 3,
    "vfc_thrust_hover": 0.5,
    "vfc_vz_max": 1,
    "vfc_kp_z": 5.2899999618530273,
    "vfc_kd_z": 5.9800000190734863,
    "vfc_vxy_max": 3,
    "vfc_kp_xy": 0.63999998569488525,
    "vfc_kd_xy": 2.559999942779541,
    "vfc_kp_z_vio": 5.2899999618530273,
    "vfc_kd_z_vio": 5.9800000190734863,
    "vfc_kp_xy_vio": 3.2400000095367432,
    "vfc_kd_xy_vio": 3.9600000381469727,
    "vfc_w_filt_xy_vio": 10,
    "vfc_w_filt_xy_flow": 3,
    "vfc_vel_ff_factor_vio": 0.899999976158142,
    "vfc_xy_acc_limit_vio": 2.5,
    "vfc_max_z_delta": 3,
    "vfc_att_transition_time": 0.5,
    "vfc_stick_move_threshold": 30,
    "vfc_flow_transition_time": 1,
    "vfc_q_min": 10,
    "vfc_points_min": 7,
    "vfc_en_submode_announcement": 1,
    "vfc_disable_fallback": false,
    "vfc_traj_csv": "/data/voxl-vision-hub/traj.csv",
    "en_voa": true,
    "voa_upper_bound_m": -0.15000000596046448,
    "voa_lower_bound_m": 0.15000000596046448,
    "voa_memory_s": 1,
    "voa_max_pc_per_fusion": 100,
    "voa_pie_max_dist_m": 20,
    "voa_pie_min_dist_m": 0.25,
    "voa_pie_under_trim_m": 1,
    "voa_pie_threshold": 3,
    "voa_send_rate_hz": 20,
    "voa_pie_slices": 36,
    "voa_pie_bin_depth_m": 0.15000000596046448,
    "voa_inputs": [{
    "enabled": false,
    "type": "point_cloud",
    "input_pipe": "dfs_point_cloud",
    "frame": "stereo_l",
    "max_depth": 8,
    "min_depth": 0.300000011920929,
    "cell_size": 0.079999998211860657,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": false,
    "input_pipe": "stereo_front_pc",
    "frame": "stereo_front_l",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": false,
    "input_pipe": "stereo_rear_pc",
    "frame": "stereo_rear_l",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "enabled": true,
    "type": "tof",
    "input_pipe": "tof",
    "frame": "tof",
    "max_depth": 6,
    "min_depth": 0.15000000596046448,
    "threshold": 3,
    "x_fov_deg": 106.5,
    "y_fov_deg": 85.0999984741211,
    "conf_cutoff": 125
    "enabled": false,
    "type": "rangefinder",
    "input_pipe": "rangefinders",
    "frame": "body",
    "max_depth": 8,
    "threshold": 4,
    "x_fov_deg": 68,
    "y_fov_deg": 56,
    "conf_cutoff": 0
    "voa_voa_memory_s": 1
    S Sarika Sharma
    @Sarika-Sharma and I also wanna tell you my goal i.e. stable indoor flight without GPS
    S Sarika Sharma
    Hello @Alex-Kushleyev
    Thank you for getting back to me.
    Yes, I already have the above cameras.I am attaching image of the PMD TOF image sensor along with the adapters that were included, so you can confirm exactly which configuration I have.
    I would also be very open to your suggestions regarding updates or improvements to the camera selection. Please feel free to recommend better options based on your experience.
    Looking forward to your guidance.
    S Sarika Sharma
    Hello Team, I’m working with a VOXL2 Mini and would like guidance on the correct hardware configuration (cables and ports) for the following camera setup:
    Cameras
    1. 2× M0014 (OV7251 tracking cameras)
    2. 1× M0169 (PMD ToF camera)
    3. 1× M0024 (IMX214 high-resolution camera)
    Available accessories
    1. M0084 flex cables
    2. M0135 interface board
    Could you please confirm the correct physical connection / port mapping for this setup on VOXL2 Mini?
  • PMD ToF not detected on VOXL2
    S Sarika Sharma
    @Sarika-Sharma Now TOF is detected. I have choosed pmd-tof instead of pmd-tof-liow2.
    But please give solution for the following problem.
    When I used J7 according to the following configuration
    Hardware Setup
    M0104 Connector Interposer Sensor HW ID
    J7 M0135 JL Tracking (M0014 ) 2
    J7 M0135 JU Hires (M0025-2 ) 3
    OR
    J7 M0135 JL Hires (M0025-2 ) 2
    J7 M0135 JU Tracking (M0014 ) 3
    ONLY , The camera which is connected to JL is working either tracking or hires.
    Cameras connected to JU is not working.
    When i run voxl-camera-server it gives this
    WARNING: cam tracking (id 1) does not seem to be alive
    ------ voxl-camera-server: Started 1 of 2 cameras
    OR
    WARNING: cam hires (id 1) does not seem to be alive
    ------ voxl-camera-server: Camera server is now running![alt text](ba913d5d-8f28-44d8-8ee4-8a906e5f680c-WhatsApp Image 2025-12-26 at 5.31.01 PM.jpeg )/home/idr/Downloads/WhatsApp Image 2025-12-26 at 5.31.01 PM.jpeg
  • Compatible ToF sensor setup with VOXL2 Mini
    S Sarika Sharma
    @Alex-Kushleyev @Luca-Zanatta I am also facing the same issue, can you please tell how to solve resolution problem.
    I have tried to manually add preview width and preview height in vim /etc/modalai/voxl-camera-server.conf But when i run voxl-camera-server it still gives previous resolution 240*1557 and hence pmd-tof is not detected.
    ESCs, Sensors and Accessories
  • Unable to connect multiple VOXL2 mini drones to QGroundControl using different UDP ports
    S Sarika Sharma
    @Sarika-Sharma Kindly resolve this issue also https://forum.modalai.com/topic/4952/pmd-tof-not-detected-on-voxl2?_=1766730439331.
    S Sarika Sharma
    @Eric-Katzfey Thank you.
    S Sarika Sharma
    Hello ModalAI Team,
    I am working with VOXL2 / VOXL2 Mini and PMD ToF V2 (M0169), and I am facing an issue where the PMD ToF camera is not detected/started by voxl-camera-server.
    System details
    Platform: VOXL2
    System Image: 1.7.4
    PMD Module: M0169 (PMD ToF)
    Use case: Tracking + ToF + HiRes
    Hardware connection (Option 1)
    VOXL2 → M0076 → M0074 extender → M0169 (external regulated 5V supplied) → ToF
    External 5V is provided to M0169.
    Camera configuration
    Cameras enabled: PMD ToF + IMX214 (HiRes) + OV7251 (Tracking)
    IMX214 and OV7251 start correctly, but not pmd-tof
    kindly look at the screenshots.
    a36f52a5-a172-4531-8f43-0905ee278823-Screenshot from 2025-12-25 17-40-44.png /home/idr/Pictures/Screenshots/Screenshot from 2025-12-25 17-40-44.png
    10272c6a-fa27-45e7-bb32-6c97b4aeb271-Screenshot from 2025-12-25 17-40-54.png /home/idr/Pictures/Screenshots/Screenshot from 2025-12-25 17-40-54.png
    a41128c1-4a1b-4240-876e-c8d29a098411-Screenshot from 2025-12-25 17-41-05.png /home/idr/Pictures/Screenshots/Screenshot from 2025-12-25 17-41-05.png
    0df2ec23-7ed1-43f9-8417-6989d6957e24-WhatsApp Image 2025-12-25 at 6.00.04 PM.jpeg /home/idr/Downloads/WhatsApp Image 2025-12-25 at 6.00.04 PM.jpeg
    S Sarika Sharma
    @Eric-Katzfey If you would be so kind as to tell how can i specify a different port to connect to at the GCS for each drone?
