  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. ToF sensor and VOA
ToF sensor and VOA
9 Posts 4 Posters 1.6k Views
  • X Offline
    X Offline
    xav04
    wrote on last edited by xav04
    Hi, I'd like to know if is it possible to use a ToF sensor for obstacle avoidance with voxl2. To give you more context, when I run voxl-inspect-tof I get the correct distance measurements. I modified /etc/modalai/voxl-vision-px4.conf , where "en_voa" is set to true and "voa_inouts" only accepts "tof".
    To verify that this is working I run voxl-vision-px4 -s but all distances are none. Please let me know how I can fix this.
    Also, is it possible to see objects with a shorter range using ToF, like around 1m?
    • ? Offline
      Yes this should absolutely be possible, can you send the screenshot of your voxl-vision config file as well.
      As for range we usually cut off the tof data around 15 cm in front of the camera, so it usually has an effective range of ~0.15-5 meters
      X 2 Replies Last reply
      • X Offline
        X Offline
        xav04
        Hi @Alex-Gardner, sure! This is the configuration of /etc/modalai/voxl-vision-px4.conf.
        If there is any other parameter that can be improved please let me know
        • ? A Former User
          X Offline
          X Offline
          xav04
          Hi @Alex-Gardner , is there any other file I should upload?
          • ? A Former User
            X Offline
            X Offline
            xav04
            @Alex-Gardner I'm wondering if you can help me solve this problem or is there someone else on the development team who can provide support?
            • ? Offline
              Can you check in voxl-portal what the pointcloud voxl_pc_out looks like? this is the VOA pointcloud before the final bit of filtering to send it to the flight controller.
              Also check /etc/modalai/extrinsics.conf to make sure that it matches the transforms that are on your drone.
              X 1 Reply Last reply
              • ? A Former User
                X Offline
                X Offline
                xav04
                Hi @Alex-Gardner this is the screenshot of voxl_pc_out in voxl-portal, at the same time this is the output of voxl-vision-px4 -s and this is the screenshot /etc/modalai/extrinsics.conf
                • James StrawsonJ Offline
                  James Strawson
                  your image of the voa_pc_out point cloud shows that your voxl thinks the TOF is pointing out the top of the drone. This is confirmed by your extrinsics conf sensor rotation: [180 0 0] which translates to a sensor pointing straight up.
                  S 1 Reply Last reply
                    S Offline
                    S Offline
                    Sarika Sharma
                    wrote on last edited by Sarika Sharma
                    #9
                    @James-Strawson Hii , I am also getting the same issue . Kindly look at the following details . I have defined tof in my extrinsics.conf file as given below:
                    parent: body
                    child: tof
                    T_child_wrt_parent: 0.070 0.024 -0.029
                    RPY_parent_to_child: 0.0 90.0 90.0
                    R_child_to_parent: 0.000 -0.000 1.000
                    1.000 0.000 -0.000
                    -0.000 1.000 0.000
                    when i run voxl-vision-hub -s i got the following
                    slice 0 dist none back
                    slice 1 dist none
                    slice 2 dist none
                    slice 3 dist none
                    slice 4 dist none
                    slice 5 dist none
                    slice 6 dist none
                    slice 7 dist none
                    slice 8 dist none
                    slice 9 dist none left
                    slice 10 dist none
                    slice 11 dist none
                    slice 12 dist none
                    slice 13 dist none
                    slice 14 dist none
                    slice 15 dist none
                    slice 16 dist none
                    slice 17 dist none
                    slice 18 dist none forward
                    slice 19 dist none
                    slice 20 dist none
                    slice 21 dist none
                    slice 22 dist none
                    slice 23 dist none
                    slice 24 dist none
                    slice 25 dist none
                    slice 26 dist none
                    slice 27 dist none right
                    slice 28 dist none
                    and in my vision-hub-conf file i have the folloeing set up:
                    "en_vio": true,
                    "vio_pipe": "qvio",
                    "secondary_vio_pipe": "ov",
                    "vfc_vio_pipe": "ov",
                    "vio_warmup_s": 3,
                    "send_odom_while_failed": true,
                    "horizon_cal_tolerance": 0.5,
                    "en_hitl": false,
                    "offboard_mode": "figure_eight",
                    "follow_tag_id": 0,
                    "figure_eight_move_home": true,
                    "robot_radius": 0.300000011920929,
                    "collision_sampling_dt": 0.1,
                    "max_lookahead_distance": 1,
                    "backtrack_seconds": 60,
                    "backtrack_rc_chan": 8,
                    "backtrack_rc_thresh": 1500,
                    "wps_move_home": true,
                    "wps_stride": 0,
                    "wps_timeout": 0,
                    "wps_damp": 1,
                    "wps_vfc_mission": true,
                    "wps_vfc_mission_loop": false,
                    "wps_vfc_mission_to_ramp": 25,
                    "wps_vfc_mission_to_kp": 0.10000000149011612,
                    "wps_vfc_mission_cruise_speed": 1,
                    "en_tag_fixed_frame": false,
                    "fixed_frame_filter_len": 5,
                    "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
                    "vfc_rate": 100,
                    "vfc_rc_chan_min": 980,
                    "vfc_rc_chan_max": 2020,
                    "vfc_thrust_ch": 3,
                    "vfc_roll_ch": 1,
                    "vfc_pitch_ch": 2,
                    "vfc_yaw_ch": 4,
                    "vfc_submode_ch": 6,
                    "vfc_alt_mode_rc_min": 0,
                    "vfc_alt_mode_rc_max": 0,
                    "vfc_flow_mode_rc_min": 0,
                    "vfc_flow_mode_rc_max": 0,
                    "vfc_hybrid_flow_mode_rc_min": 0,
                    "vfc_hybrid_flow_mode_rc_max": 0,
                    "vfc_position_mode_rc_min": 0,
                    "vfc_position_mode_rc_max": 2100,
                    "vfc_traj_mode_rc_min": 0,
                    "vfc_traj_mode_rc_max": 0,
                    "vfc_yaw_deadband": 30,
                    "vfc_vxy_deadband": 50,
                    "vfc_vz_deadband": 150,
                    "vfc_min_thrust": 0,
                    "vfc_max_thrust": 0.800000011920929,
                    "vfc_tilt_max": 0.43599998950958252,
                    "vfc_yaw_rate_max": 3,
                    "vfc_thrust_hover": 0.5,
                    "vfc_vz_max": 1,
                    "vfc_kp_z": 5.2899999618530273,
                    "vfc_kd_z": 5.9800000190734863,
                    "vfc_vxy_max": 3,
                    "vfc_kp_xy": 0.63999998569488525,
                    "vfc_kd_xy": 2.559999942779541,
                    "vfc_kp_z_vio": 5.2899999618530273,
                    "vfc_kd_z_vio": 5.9800000190734863,
                    "vfc_kp_xy_vio": 3.2400000095367432,
                    "vfc_kd_xy_vio": 3.9600000381469727,
                    "vfc_w_filt_xy_vio": 10,
                    "vfc_w_filt_xy_flow": 3,
                    "vfc_vel_ff_factor_vio": 0.899999976158142,
                    "vfc_xy_acc_limit_vio": 2.5,
                    "vfc_max_z_delta": 3,
                    "vfc_att_transition_time": 0.5,
                    "vfc_stick_move_threshold": 30,
                    "vfc_flow_transition_time": 1,
                    "vfc_q_min": 10,
                    "vfc_points_min": 7,
                    "vfc_en_submode_announcement": 1,
                    "vfc_disable_fallback": false,
                    "vfc_traj_csv": "/data/voxl-vision-hub/traj.csv",
                    "en_voa": true,
                    "voa_upper_bound_m": -0.15000000596046448,
                    "voa_lower_bound_m": 0.15000000596046448,
                    "voa_memory_s": 1,
                    "voa_max_pc_per_fusion": 100,
                    "voa_pie_max_dist_m": 20,
                    "voa_pie_min_dist_m": 0.25,
                    "voa_pie_under_trim_m": 1,
                    "voa_pie_threshold": 3,
                    "voa_send_rate_hz": 20,
                    "voa_pie_slices": 36,
                    "voa_pie_bin_depth_m": 0.15000000596046448,
                    "voa_inputs": [{
                    "enabled": false,
                    "type": "point_cloud",
                    "input_pipe": "dfs_point_cloud",
                    "frame": "stereo_l",
                    "max_depth": 8,
                    "min_depth": 0.300000011920929,
                    "cell_size": 0.079999998211860657,
                    "threshold": 4,
                    "x_fov_deg": 68,
                    "y_fov_deg": 56,
                    "conf_cutoff": 0
                    "enabled": false,
                    "input_pipe": "stereo_front_pc",
                    "frame": "stereo_front_l",
                    "max_depth": 8,
                    "threshold": 4,
                    "x_fov_deg": 68,
                    "y_fov_deg": 56,
                    "conf_cutoff": 0
                    "enabled": false,
                    "input_pipe": "stereo_rear_pc",
                    "frame": "stereo_rear_l",
                    "max_depth": 8,
                    "threshold": 4,
                    "x_fov_deg": 68,
                    "y_fov_deg": 56,
                    "conf_cutoff": 0
                    "enabled": true,
                    "type": "tof",
                    "input_pipe": "tof",
                    "frame": "tof",
                    "max_depth": 6,
                    "min_depth": 0.15000000596046448,
                    "threshold": 3,
                    "x_fov_deg": 106.5,
                    "y_fov_deg": 85.0999984741211,
                    "conf_cutoff": 125
                    "enabled": false,
                    "type": "rangefinder",
                    "input_pipe": "rangefinders",
                    "frame": "body",
                    "max_depth": 8,
                    "threshold": 4,
                    "x_fov_deg": 68,
                    "y_fov_deg": 56,
                    "conf_cutoff": 0
                    "voa_voa_memory_s": 1
