Mustafa_CayciM
Mustafa_Cayci
@Mustafa_Cayci
  • Inquiry: Starling 2 Max — ROS2 / Jetson Orin Nano & RFID integration
    Mustafa_CayciM Mustafa_Cayci
    @Eric-Katzfey I have an Orbbec depth camera (USB‑C) that we use for object detection and AprilTag detection. Do we still need the Orbbec camera, or do the Starling 2 or Stinger already include a depth camera?
    Thank you,
    Mustafa
    Development Drones fpv
    Hi @Eric-Katzfey,
    I did not realize that the VOXL2 has already built in PX4 as well as Qualcomm AI Engine. Effectively, it replaces our Jetson Orin Nano all together.
    Is J9 USB-C connector shown in the following screen capture?
    Mustafa
    @Eric-Katzfey said in Inquiry: Starling 2 Max — ROS2 / Jetson Orin Nano & RFID integration:
    accessory board that exposes a USB port for you to connect.
    Hi @Eric-Katzfey Just to confirm ... you are referring to this page where there are those boards mentioned.
    https://docs.modalai.com/expansion-boards/
    I need one USB-C and two USB 3.0 ports so total 3 ports. Is there one board that allows three ports? Or do I need to one or more boards?
    Secondly I am connecting PixHawk to Jetson today with Ethernet connection to minimize the data bottleneck. How do I do this with VOXL2?
    Thank you for your time.
    Mustafa
    @Eric-Katzfey Currently the RFID reader connects to Jetson using a USB cable. We have API to access the RFID reader and read the RFID tags. We then process them in ROS2 nodes.
    Does VOXL2 use Ubuntu Linux? Document also mentioned Docker. We should be able to load our docker image on VOXL2 as well.
    My other concern is the bulkiness of the RFID antenna. It is 15 cm by 15 cm. I am wondering how we would be able to mount on the drone.
    Mustafa
    We are interested in this drone
    https://www.modalai.com/products/starling-2-max?variant=48216084152624
    Regarding this
    "Open-source software: OpenCV, ROS 2, Docker, PX4 integrated flight controller"
    In our current development drone, we have a Jetson NVDIA Orin Nano running the ROS2 development nodes. Can it be run on this drone? Secondly we have an RFID reader connected to the Jetson Orin Nano in our hardware today. Is connectivity possible with your drone?
    Thank you,
    Mustafa
