Morten NissovM
Morten Nissov
@Morten Nissov
  • Consistent camera not found (M00014 and M0076 or M0135)
    Morten NissovM Morten Nissov
    @Alex-Kushleyev We made a couple discoveries:
    • First, thanks for referring me to this other topic, I'm not sure how I missed this. Switching, temporarily, to kernel 2.0.0 does result in connector J7 functioning, however J6 still does not for some reasons.
    • Otherwise, a colleague discovered that some SKU configurations with kernel 2.0.2 actually still work, for example the voxl2-mini-test-fixture (TF-M0104) seems to work with the older interposers and cameras. I guess it is related to this having cam config 6.
    As a result we have the following questions
    • I would still be curious to figure out if I have hardware problems with J6, what logging information could help with this?
    • Is there any downside to using the voxl2-mini-test-fixture configuration, the only desire being to use the newer SDK while having the older cameras functioning?
    The error is probably very obvious but I'm just not able to see it at the moment.
    We're trying to setup a new voxl2 mini with a tracking camera, but we simply cannot get the camera recognized by the voxl-camera-server. I have tried with both M0076 and M0135 interposers.
    For example, if we try to replicate the setup from https://docs.modalai.com/voxl2-mini-image-sensors/
    for just the tracking camera, that means connecting M0014 to M0135/JU to J7 on the voxl2 mini. None of the other camera are connected, for now we're just interested in the tracking. We can try the same with the M0076, but I just want to follow this image explicitly.
    Once I do this I configure the camera as follows:
    $ camera-server-config-helper tracking:ov7251:3
    successfully wrote this camera config to disk:
    configuration for 1 cameras:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               3
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             lme_msv
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    fsync_en:            0
    fsync_gpio:          109
    camera_server_config_helper is done
    After which I run
    $ voxl-camera-server -d 0
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               3
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    fsync_en:            0
    fsync_gpio:          109
    DEBUG:   Attempting to open the hal module
    DEBUG:   SUCCESS: Camera module opened on attempt 0
    DEBUG:   ----------- Number of cameras: 0
    VERBOSE: cci-direct: using voxl_platform_mod config 1 and 2 layout
    ERROR:   Found zero cameras connected, need at least one.
    I've tried with different hardware IDs, but from what I can see from the documentation it should be three. No ID lets the camera server find a camera.
    Version info:
    system-image: 1.8.04-M0104-14.1a-perf
    kernel:       #1 SMP PREEMPT Mon Mar 24 21:03:36 UTC 2025 4.19.125
    hw platform:  M0104
    mach.var:     2.0.2
    SKU:          MCCA-M0104-C0-T0-M0-X0
    voxl-suite:   1.5.1
    Curious if anyone can see what I'm doing wrong?
  • Compatible ToF sensor setup with VOXL2 Mini
    @Alex-Kushleyev Thanks for getting back to us so quickly.
    We removed all the com.qti.sensormodule.ov7251_*.bin and the com.qti.sensormodule.irs2975c_*.bin files.
    Then we ran, as you suggested, the command: voxl-camera-server -l. The output was:
    DEBUG:   ----------- Number of cameras: 2
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
    DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x007A, Sensor Id: 0x2975
    DEBUG:   Note: This list comes from the HAL module and may not be indicative
    DEBUG:          of configurations that have full pipelines
    DEBUG:   Number of cameras: 2
    Stats for camera: 0
    ANDROID_SCALER_AVAILABLE_RAW_SIZES:
    These are likely supported by the sensor
     640 x  480
     640 x  480
     640 x  480
    ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS:
    These are NOT necessarily supported by the sensor
     640 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     640 x  480 HAL_PIXEL_FORMAT_BLOB
     640 x  400 HAL_PIXEL_FORMAT_YCbCr_420_888
     640 x  400 HAL_PIXEL_FORMAT_BLOB
     640 x  360 HAL_PIXEL_FORMAT_YCbCr_420_888
     640 x  360 HAL_PIXEL_FORMAT_BLOB
     352 x  288 HAL_PIXEL_FORMAT_YCbCr_420_888
     352 x  288 HAL_PIXEL_FORMAT_BLOB
     320 x  240 HAL_PIXEL_FORMAT_YCbCr_420_888
     320 x  240 HAL_PIXEL_FORMAT_BLOB
     240 x  320 HAL_PIXEL_FORMAT_YCbCr_420_888
     240 x  320 HAL_PIXEL_FORMAT_BLOB
     176 x  144 HAL_PIXEL_FORMAT_YCbCr_420_888
     176 x  144 HAL_PIXEL_FORMAT_BLOB
     640 x  480 HAL_PIXEL_FORMAT_RAW10
     640 x  480 HAL_PIXEL_FORMAT_RAW12
     640 x  480 HAL_PIXEL_FORMAT_RAW16
     640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
    ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
            min = 54
            max = 3451
    ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
            3451
    ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
            min = 0ns
            max = 1266732525ns
    Stats for camera: 1
     240 x 1629
     240 x 1629 HAL_PIXEL_FORMAT_RAW10
     240 x 1629 HAL_PIXEL_FORMAT_RAW12
     240 x 1629 HAL_PIXEL_FORMAT_RAW16
     240 x 1629 HAL_PIXEL_FORMAT_RAW_OPAQUE
            min = 54
            max = 0
            min = 0ns
            max = 0ns
    Number of cameras detected: 2
    Given the output, we copied the files com.qti.sensormodule.ov7251_0.bin and com.qti.sensormodule.irs2975c_2.bin into /usr/lib/camera folder.
    Then we ran: camera-server-config-helper tracking:ov7251:0 tof:pmd-tof:2 and got the following output:
    configuration for 2 cameras:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #1
        sensor type:         pmd-tof
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 5
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           5
    fsync_en:            0
    fsync_gpio:          109
    Finally, we ran: voxl-camera-server, and we got:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #1
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 5
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           5
    fsync_en:            0
    fsync_gpio:          109
    connected to mavlink pipe
    Connected to cpu-monitor
    Starting Camera: tracking (id #0)
    setting ov7251 BLC register for cam id 0
    Starting Camera: tof (id #2)
    WARNING: cam tof (id 2) does not seem to be alive
    ------ voxl-camera-server: Started 1 of 2 cameras
    Just to make sure that only one camera was working, we ran: voxl-inspect-cam -a and got:
    | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbt
    |  tracking |  307200 |  640 |  480 |  5.04 |  111 |      179 |     11.6  | 30.0 |   73.7 | RAW8
    What do you think?
    ESCs, Sensors and Accessories
    Additional debugging:
    Moreover, we test some other configurations:
    • J7 <-> M0135 (JL) <-> M0014
    • J6 <-> M0172 (J1L) <-> M0170 <-> tof
    We copied the files: com.qti.sensormodule.ov7251_*.bin and com.qti.sensormodule.irs2975c_*.bin into the folder: /usr/lib/camera
    We used the command: camera-server-config-helper tracking:ov7251:0 tof:pmd-tof:2 giving the following output:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #1
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 5
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           5
    fsync_en:            0
    fsync_gpio:          109
    Then we run voxl-camera-server giving the following output:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #1
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 5
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           5
    fsync_en:            0
    fsync_gpio:          109
    And running voxl-inspect-cam -a still gives the following output:
    | Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
    |  tracking |  307200 |  640 |  480 |  2.28 |   51 |      294 |     11.5  | 30.0 |   73.7 | RAW8
    To be sure that all the parts were working, we tested two M0172 and 2 ToF sensors, which were actually working on VOXL 2. We also swapped the tracking camera and the ToF sensor (J6 <-> J7), copying the .bin files according to and adjusting the ID numbers.
    @Vinny @Alex-Kushleyev
    We are trying to configure Voxl 2 Mini with the ToF sensor and a tracking camera with the , and we're having trouble with getting the ToF sensor to work. This is with the new ToF sensor and the new interposer you suggested for us to use.
    The cameras are attached in the following way:
    The voxl suite we have on the board is: voxl-suite: 1.5.0
    To configure the cameras we run:
    voxl-configure-sku
    choosing options 23 (voxl-configure-sku) and 5 (pmd-tof ov7251 tracking).
    The output was the following:
    Your answers would construct the following SKU:
    family code:   MCCA-M0104 (voxl2-mini-board-only (MCCA-M0104))
    compute board: 6 (voxl2-mini)
    hw version:    1
    cam config:    05
    modem config:   ()
    tx config:      ()
    extras config:  ()
    SKU:           MCCA-M0104-C05-T0-M0-X0
    This sku will be saved to persistent memory so VOXL
    will remember what it is installed in, even between
    system image flashes.
    So we run: voxl-configure-mpa and reboot
    To inspect the cameras, we run voxl-inspect-cam -a , but we were able to see only the tracking camera:
    |  tracking |  307200 |  640 |  480 |  2.51 |   51 |      204 |     11.5  | 30.0 |   73.7 | RAW8
    So we restarted the service voxl-camera-server , but we got the following error + warnings:
    cam #0
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 5
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           5
    cam #1
        sensor type:         ov7251
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    fsync_en:            0
    fsync_gpio:          109
    Starting Camera: tof (id #0)
    ERROR:   Camera 0 failed to find supported preview config: 224x1557
    WARNING: Failed to start cam tof due to invalid resolution
    WARNING: assuming cam is missing and trying to compensate
    Starting Camera: tracking (originally id #1) with id offset: 1
    Note, we also tried to modify the preview resolution, as well as disabling the preview entirely. But making these changes to the /etc/modalai/voxl-camera-server.conf file didn't seem to change the actual configuration used, as reported when running voxl-camera-server in terminal.
    Do you have any suggestions for how we can get this working?
    @Vinny Sorry thought I had responded, thanks!
    @Alex-Kushleyev Hi again Alex, sorry for disturb just wanted to hear if you had seen the previous message? And if you could make the M0172 available?
    @Alex-Kushleyev Thanks for getting back so quickly! We just have a couple of follow-up questions:
    If we use this M0172 are we still able to have a tracking camera running? Such that the total setup looks something like: VOXL2 mini w/ M0178 ToF and M0014 tracking camera. If yes, then it would be great if the M0172 could be made available in the shop
    Hi
    We're wanting to interface our voxl2 mini board with a time of flight sensor. We had a time of flight sensor we bought from when we first got the VOXL2 mini, but it seems the exact same unit is no longer available.
    Looking now, it seems our options are this tof sensor and [this adapter board](https://www.modalai.com/products/mdk-m0076-1modalai forus). Will these work together with the VOXL2 mini?
    Morten
  • M0062 VOXL 2 Ethernet Expansion and USB Hub Missing User Guide
    @tom Sorry about that, I thought I had answered this.
    Would you be able to tell me what the default state is? I really can't recall if they've been moved since we got it.
    We wanted to start using the ethernet expansion board for the SD card slot and additional USB ports. But I notice there is nothing written in the user guide (link). Namely we're curious how we should be setting the switches in the SW1 component, among other uncertainties which can arise when we begin to use the product.
  • 4-in-1 mini ESC max ratings
    @Alex-Kushleyev Sorry for the delay, didn't notice the alert. But great, thanks!
    I see here that the voxl 4-in-1 mini ESC is rated for 2-4s (i.e. up to 16.8V at max charge). Maybe this is a stupid question, but is it possible to run LiHV 4s batteries with this ESC? The max voltage would then be 4.35*4 = 17.4.
    I realize this is above the rated specs, but I was curious if the difference was small enough that it was still within tolerable margins?
    Thanks
  • Inconsistent IMU sampling
    @Alex-Kushleyev Thanks for getting back to me, I must've missed reading the part regarding the CPU frequencies, now that you say it seems obvious.
    the IMU frequency is not exactly 1Khz because the IMU is running using its own internal oscillator, which is does not perfectly align with 1000Hz output frequency, so the closest frequency the IMU can achieve is about 976Hz or so.
    This is interesting actually, because the dt and sampling rate seems to consistently be slightly higher than 1kHz, approximately 1.03kHz. Can this make sense for the IMU?
    Finally, you are absolutely right that the ROS publisher queue size being set to 1 is causing the messages to be dropped because they are published too quickly and are simply discarded when queue overflows.
    I really don't see the down side of increasing the buffer size and i agree it should be set to at least the sample_rate / fifo_poll_rate , which is the number of samples that would be published at a time.
    I will discuss this with the team.. thank you for pointing out the issue and good job figuring it out!
    I didn't see a major change in CPU consumption, at least of the two solutions increasing the FIFO queue cost much more CPU than changing the queue size did. I would offer to make a PR if the change was more complicated than just changing a number 🙂
    Anyway thanks. I'm a bit curious about the IMU, but otherwise I think this is solved.
    Morten
    @Alex-Kushleyev Hi again, Sorry to keep spamming. I just wanted to make sure this is up-to-date as I progress.
    A bit silly I didn't realize before, but I think the problem lies in the FIFO buffer reading vs IMU queue size in the voxl-mpa-to-ros, that being said the conversion from pipe to ros also costs some latency it seems.
    In voxl-mpa-to-ros, there is the following
        m_rosPublisher = m_rosNodeHandle.advertise<sensor_msgs::Imu>(topicName, 1);
    Given that the FIFO buffer (with default settings) reads 10 IMU messages at a time, I think this should be changed to
        m_rosPublisher = m_rosNodeHandle.advertise<sensor_msgs::Imu>(topicName, 25);
    so it has a little extra depending on what happens. This results in a very large improvement:
    Getting data from log0004 and data_incr_queue.bag
    voxl-logger
    	mean: 0.9766417070988479 ms
    	std dev: 0.0014018018261035131 ms
    	total messages: 61363
    rosbag record
    	mean: 0.9766411567432235 ms
    	std dev: 0.02937541759378401 ms
    	total messages: 59305
    although you can see there are still some dropped measurements and still a worsening of the standard deviation. I realized the IMU reading can also directly publish to ros from the voxl-imu-server, and this seems a little more benefit as well
    rosbag record
    	mean: 0.9768075697417741 ms
    	std dev: 0.012558722853297727 ms
    	total messages: 61147
    still not totally without message dropping. This also still has some worsening about the standard deviation, I wonder if that's simply due to the conversion in _clock_monotonic_to_ros_time.
    @Morten-Nissov Note, although this does make things look better, there still is a pretty significant difference between the voxl logger and recording a rosbag, with a relatively non-insignificant performance difference between the two.
    Also, not really sure why the voxl-logger doesn't manage a clean 1kHz, following the configuration. Seems to be consistently off the commanded value.
    @Alex-Kushleyev Followup, I can change the fifo_poll_rate_hz parameter and this has significantly increased the performance at the cost of significantly increase CPU load on the slow cores. Maybe you can advise how we should proceed.
    "imu0_enable":	true,
    	"imu0_sample_rate_hz":	1000,
    	"imu0_lp_cutoff_freq_hz":	92,
    	"imu0_rotate_common_frame":	true,
    	"imu0_fifo_poll_rate_hz":	500,
    Name   Freq (MHz) Temp (C) Util (%)
    cpu0       1804.8     41.7    44.95
    cpu1       1804.8     41.7    33.94
    cpu2       1804.8     42.0    46.88
    cpu3       1804.8     42.4    44.00
    cpu4       2419.2     40.5     0.00
    cpu5       2419.2     40.5     0.00
    cpu6       2419.2     39.7     0.00
    cpu7       2841.6     40.1     0.00
    Total                 42.4    21.22
    10s avg                       15.10
    GPU         305.0     38.6     0.00
    GPU 10s avg                    0.00
    memory temp:       39.0 C
    memory used:   746/7671 MB
    Flags
    CPU freq scaling mode: performance
    Standby Not Active
    Note even with this change some IMU messages are still dropped:
    Getting data from log0003 and data_perf_fifo500.bag
    voxl-logger
    	mean: 0.9766390443514245 ms
    	std dev: 0.001688066415815054 ms
    	total messages: 61397
    rosbag record
    	mean: 1.0005186426507142 ms
    	std dev: 0.15095098578685434 ms
    	total messages: 59599
    @Alex-Kushleyev Sorry for the delay, some data for you in different configurations:
    Getting data from log0000 and data.bag
    voxl-logger
    	mean: 0.9766542020947352 ms
    	std dev: 0.0013052458028126252 ms
    	total messages: 61393
    rosbag record
    	mean: 3.230353079590143 ms
    	std dev: 2.992801413066607 ms
    	total messages: 18361
    Getting data from log0001 and data_nodelay.bag
    voxl-logger
    	mean: 0.9766513801209619 ms
    	std dev: 0.0013052148029740315 ms
    	total messages: 61342
    rosbag record
    	mean: 3.2565453276935123 ms
    	std dev: 3.0139953610144303 ms
    	total messages: 17860
    Getting data from log0002 and data_perf.bag
    voxl-logger
    	mean: 0.976641095612789 ms
    	std dev: 0.001267007877929727 ms
    	total messages: 61384
    rosbag record
    	mean: 3.73874577006071 ms
    	std dev: 3.513557787123189 ms
    	total messages: 15819
    Note significant differences in messages for each, indicating lots of message drop by the ros node.
    Considering the sampling rate and standard deviation for different configurations. Logging was done with voxl-logger -t 60 -i imu_apps -d bags/imu_test/ and rosbag record /imu_apps -O data --duration 60. I tried setting the rosbag to record with --tcpnodelay, but this seems to have no effect. During the performance run, the cpu usage was as follows:
    cpu0       1804.8     40.1    22.33
    cpu1       1804.8     39.7    18.10
    cpu2       1804.8     40.1    17.82
    cpu3       1804.8     39.7    16.16
    cpu4       2419.2     39.0     0.00
    cpu5       2419.2     38.6     0.00
    cpu6       2419.2     37.8     0.00
    cpu7       2841.6     39.0     0.00
    Total                 40.1     9.30
    10s avg                       12.26
    GPU         305.0     37.4     0.00
    GPU 10s avg                    0.00
    memory temp:       37.8 C
    memory used:   734/7671 MB
    Flags
    The only thing which seems out of the ordinary here is that many CPUs are operating consistently at low frequency. Maybe you have a comment on why that could be? Otherwise, it seems the transfer from the voxl-imu-server to ros causes quite a bit of loss in messages. Here is some voxl 2 mini install information:
    system-image: 1.7.8-M0104-14.1a-perf
    kernel:       #1 SMP PREEMPT Sat May 18 03:34:36 UTC 2024 4.15
    hw platform:  M0104
    mach.var:     2.0.0
    voxl-suite:   1.3.3
    with this IMU config:
                    "imu0_fifo_poll_rate_hz":       100,
                    "aux_imu1_enable":      false,
                    "aux_imu1_bus": 1,
                    "aux_imu1_sample_rate_hz":      1000,
                    "aux_imu1_lp_cutoff_freq_hz":   92,
                    "aux_imu1_fifo_poll_rate_hz":   100,
                    "aux_imu2_enable":      false,
                    "aux_imu2_spi_bus":     14,
                    "aux_imu2_sample_rate_hz":      1000,
                    "aux_imu2_lp_cutoff_freq_hz":   92,
                    "aux_imu2_fifo_poll_rate_hz":   100,
                    "aux_imu3_enable":      false,
                    "aux_imu3_spi_bus":     5,
                    "aux_imu3_sample_rate_hz":      1000,
                    "aux_imu3_lp_cutoff_freq_hz":   92,
                    "aux_imu3_fifo_poll_rate_hz":   100
    @Alex-Kushleyev Thanks! I'll try this, note I should have mentioned this is with a voxl2 mini computer and on the ROS side the only thing happening is recording to rosbag.
    Morten
    We've lately been noticing a lot of inconsistency in the publishing frequency and sample rate (from time stamp) of the IMU when publishing to ROS with the voxl-mpa-to-ros tool using SDK 1.1.3. This error is showing similar symptoms as other people (like this but doesn't seem to be fixed by setting CPU to performance mode. Using voxl-inspect-imu shows a dt of about 1ms, corresponding well to 1kHz (with the default IMU config).
    We diagnose this problem primarily using rostopic hz as well as with the following plot of IMU sampling rate we noticed while doing VIO calibrations. We tried also setting the sampling rate to 200z instead, to see if this would alleviate some pressure, but still there is quite a lot of inconsistency (of course worse with 1kHz).
    This has been tested with very few other services running in the background, so compute usage when this occurs is minimal. The only thing running with any noticeable compute usage is voxl-px4
    I was curious if this is expected behavior or if you had any suggestions for how to troubleshoot/debug/solve this problem?
