Maanav IyengarM
Maanav Iyengar
@Maanav Iyengar
  • Voxl 2 -- Not receiving any data from hi-res camera
    Maanav IyengarM Maanav Iyengar
    @Alex-Kushleyev Hi Alex, the camera was working just fine about a day before I made my first post; however, it still does not work. Unfortunately, we are not able to get any frames before the issue occurs.
    @Alex-Kushleyev Hi Alex, thanks for getting back to me so quickly.
    Good catch. I mistakenly mentioned J7L. I tried swapping between J7L and J7U and configuring the camera drivers, but the result remained the same.
    Unfortunately, I don’t have an extra M0036 flex cable.
    Do you have any suggestions on what I should try next?
    Hi Support Team,
    We've been running into an issue with our hi-res camera. As of yesterday, it was working perfectly fine, but today, while the Voxl 2 detects the camera, it's not giving us any data. The hi-res camera is connected to Hardware ID 2 (J7) Lower. We've tried other configurations with our dual image sensor expander but we know that J7 Lower works because we've had no issues with our tracking camera in that same port. You can find an image of our setup here.
    When running "voxl-camera-server", we get the output below:
    voxl2:/$ voxl-camera-server
    detected system image 1.7.8
    using new imx412 defaults
    configuration for 1 cameras:
    cam #0
        sensor type:         imx412
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      0
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      0
        large_video_width:   4056
        large_video_height:  3040
        en_snapshot:         0
        snap_width:          4056
        snap_height:         3040
        exif_focal_length:   3.100000
        exif_focal_len_35mm_format:17
        exif_fnumber:        1.240000
        ae_mode:             lme_msv
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    fsync_en:            0
    fsync_gpio:          109
    Starting Camera: hires (id #0)
    Connected to cpu-monitor
    ------ voxl-camera-server: Started 1 of 1 cameras
    After running "voxl-inspect-cam -a", we get the output below:
    |   Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
    | hires_color | Server DisconnectedMost likely the server stopped without cleaning up
    Client is cleaning up pipes for the servern pipe_client_open opening request pipe: No such device or address
    ERROR in pipe_client_open opening request pipe: No such device or address
    closing and exiting
    And the output from "voxl-camera-server" now says "Aborted".
    When running "dmesg", we get the output below:
    [ 1923.059388] CAM_ERR: CAM-MEM: cam_mem_mgr_create_debug_fs: 126 failed to create dentry
    [ 1923.086696] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
    [ 1923.096914] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
    [ 1923.096923] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
    [ 1923.096928] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
    [ 1923.206469] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
    [ 1923.207319] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
    [ 1923.207350] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
    [ 1923.207453] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
    [ 1923.227457] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x34,sensor_id:0x577
    [ 1923.227537] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
    [ 1923.229601] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
    [ 1923.229617] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
    [ 1923.229638] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
    [ 1923.269802] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
    [ 1923.270141] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
    [ 1923.270210] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
    [ 1923.270585] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
    [ 1923.283777] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 997 CAM_ACQUIRE_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
    [ 1923.290980] CAM_INFO: CAM-HFI: cam_hfi_resume: 679 Resume IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
    [ 1926.305226] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
    [ 1926.307375] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
    [ 1926.307436] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
    [ 1926.307509] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
    [ 1926.308032] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1047 CAM_RELEASE_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
    [ 1926.331828] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
    [ 1926.414785] CAM_ERR: CAM-MEM: cam_mem_mgr_create_debug_fs: 126 failed to create dentry
    [ 1926.425556] CAM_INFO: CAM-HFI: cam_hfi_init: 878 Init IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
    [ 1926.435903] CAM_INFO: CAM-ICP: cam_icp_mgr_hw_open: 3879 FW download done successfully
    [ 1926.435922] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079,OEM_IMAGE_VERSION_STRING=CRM,BUILD_TIME: Oct 17 2019 05:49:19,CACHE_ENABLED at icphostinterface.c:636 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
    [ 1926.435933] CAM_INFO: CAM-ICP: cam_icp_mgr_process_dbg_buf: 2572 FW_DBG:CICP_FW_E : HFI  :ELF variant: CACHE-ENABLED:T480:API_V2:USE_CDM_1_1: , API version: 0x2000049 at icphostinterface.c:637 QC_IMAGE_VERSION_STRING=CICP.FW.1.0-00079 OEM_IMAGE_VERSION_STRING=CRM
    [ 1926.482917] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
    [ 1926.483009] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
    [ 1926.483026] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
    [ 1926.483118] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
    [ 1926.497706] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 918 Probe success,slot:3,slave_addr:0x34,sensor_id:0x577
    [ 1926.497754] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
    [ 1926.499791] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
    [ 1926.499803] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
    [ 1926.499818] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
    [ 1926.520755] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
    [ 1926.520925] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
    [ 1926.520989] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
    [ 1926.521143] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
    [ 1926.534451] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 997 CAM_ACQUIRE_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
    [ 1926.541285] CAM_INFO: CAM-HFI: cam_hfi_resume: 679 Resume IO1 : [0x10c00000 0xcf300000] IO2 [0xe0200000 0x1ed00000]
    [ 1975.970540] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:6 IPP resource not available
    [ 1975.970556] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:5 IPP resource not available
    [ 1975.970566] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:4 IPP resource not available
    [ 1975.970576] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:3 IPP resource not available
    [ 1975.970585] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:2 IPP resource not available
    [ 1975.970714] CAM_ERR: CAM-ISP: cam_ife_hw_mgr_print_acquire_info: 710 Successfully acquire single IFE[1 -1] with [11 pix] [0 pd] [0 rdi] ports for ctx:2
    [ 1975.988176] CAM_INFO: CAM-CSIPHY: cam_csiphy_core_cfg: 1137 START_DEV: CSIPHY_IDX: 3, Device_slot: 0, Datarate: 996000000, Settletime: 2200000000
    [ 1975.998381] CAM_INFO: CAM-ISP: cam_vfe_bus_ver3_init_hw: 3659 Overriding clock gating at bus input
    [ 1975.998387] CAM_INFO: CAM-ISP: cam_vfe_top_ver3_init_hw: 246 Disable clock gating at IFE top
    [ 1975.998809] CAM_ERR: CAM-ISP: cam_ife_mgr_start_hw: 4510 ->Config HW, 00000000eab2628f
    [ 1975.999724] CAM_INFO: CAM-SENSOR: cam_sensor_driver_cmd: 1089 CAM_START_DEV Success, sensor_id:0x577,sensor_slave_addr:0x34
    [ 1976.007991] CAM_ERR: CAM-ISP: cam_ife_csid_irq: 4848 CSID:1 lane 0 over flow
    [ 1976.007996] CAM_INFO: CAM-ISP: cam_ife_csid_halt_csi2: 1931 CSID: 1 cnt: 1 Halt csi2 rx
    [ 1976.008007] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 0 CSIPHY index: 3
    [ 1976.008011] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 1 CSIPHY index: 3
    [ 1976.008015] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 2 CSIPHY index: 3
    [ 1976.008019] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 3 CSIPHY index: 3
    [ 1976.008025] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 103 PHY base addr=        pK-error offset=0x8b0 size=11
    [ 1976.008031] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR0 = 0x4
    [ 1976.008036] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR1 = 0x1
    [ 1976.008041] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR2 = 0x80
    [ 1976.008045] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR3 = 0x20
    [ 1976.008050] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR4 = 0x0
    [ 1976.008055] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR5 = 0x10
    [ 1976.008059] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR6 = 0x4
    [ 1976.008064] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR7 = 0x0
    [ 1976.008069] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR8 = 0x2
    [ 1976.008073] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR9 = 0x40
    [ 1976.008078] CAM_INFO: CAM-CSIPHY: cam_csiphy_status_dmp: 117 CSIPHY3_IRQ_STATUS_ADDR10 = 0x4
    [ 1976.008085] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 4 CSIPHY index: 3
    [ 1976.008090] CAM_INFO: CAM-CSIPHY: cam_csiphy_subdev_handle_message: 22 subdev index : 5 CSIPHY index: 3
    [ 1976.008146] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4616 idx 1 err 5 phy 3  lane type:0 ln num:4 ln cfg:0x3210 cnt 1
    [ 1976.008149] cam_csid_evt_bottom_half_handler: 1 callbacks suppressed
    [ 1976.008155] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI0: 0
    [ 1976.008157] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI1: 0
    [ 1976.008166] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI2: 0
    [ 1976.008171] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RDI3: 0
    [ 1976.008176] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status TOP: 0
    [ 1976.008181] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status RX: 38000
    [ 1976.008186] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status IPP: 0
    [ 1976.008191] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status PPP: 0
    [ 1976.008195] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status UDI0: 0
    [ 1976.008200] CAM_ERR: CAM-ISP: cam_csid_evt_bottom_half_handler: 4621 status UDI1: 0
    [ 1980.746360] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
    [ 1980.748491] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
    [ 1980.748550] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
    [ 1980.748623] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
    [ 1980.757772] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 5
    [ 1980.757776] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 5
    [ 1980.757780] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 5
    [ 1980.757784] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
    [ 1980.757787] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
    [ 1980.757791] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
    [ 1980.757794] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
    [ 1980.757797] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
    [ 1980.757800] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
    [ 1980.757804] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 6
    [ 1980.757807] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 7
    [ 1980.757811] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 9
    [ 1980.757814] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 9
    [ 1980.757817] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 9
    [ 1980.757820] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
    [ 1980.757824] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
    [ 1980.757827] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
    [ 1980.757830] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
    [ 1980.757834] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
    [ 1980.757837] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
    [ 1980.757840] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 10
    [ 1980.757843] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 11
    [ 1980.757847] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 1
    [ 1980.757851] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 1
    [ 1980.757854] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 1
    [ 1980.757858] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
    [ 1980.757861] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
    [ 1980.757864] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
    [ 1980.757867] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
    [ 1980.757870] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
    [ 1980.757873] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
    [ 1980.757876] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 2
    [ 1980.757880] CAM_ERR: CAM-SYNC: cam_sync_signal: 203 Error: accessing an uninitialized sync obj = 3
    [ 1980.757885] CAM_ERR: CAM-ISP: __cam_isp_ctx_release_dev_in_top_state: 3789 releasing hw
    [ 1980.757922] CAM_INFO: CAM-ISP: cam_ife_mgr_release_hw: 4755 Release HW success ctx id: 2
    [ 1980.757975] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
    [ 1980.758980] CAM-REQ-MGR_UTIL cam_req_mgr_util_free_hdls:99 CAM_WARN: CAM-CRM: cam_req_mgr_util_free_hdls: 99 Dev handle = 8b0102 session_handle = 790200
    [ 1980.758987] CAM-REQ-MGR_UTIL cam_req_mgr_util_free_hdls:99 CAM_WARN: CAM-CRM: cam_req_mgr_util_free_hdls: 99 Dev handle = 100104 session_handle = 790200
    [ 1980.776158] ion_buffer_destroy: 6 callbacks suppressed
    [ 1980.776161] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.776953] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.777065] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.785014] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.785031] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.785046] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.785094] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.785411] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.785512] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    [ 1980.785986] ION client likely missing a call to dma_buf_kunmap or dma_buf_vunmap
    We've got a tight deadline coming up and would greatly appreciate any help here. Thanks.
  • How do I connect Tracking Camera to Voxl 2?
    @Jetson-Nano Thanks for all the help, I really appreciate it.
    @Jetson-Nano I'm also planning on purchasing a hi-res camera for my Voxl 2. Can one VOXL 2 Dual Image Sensor Expander act as an interposer for both my tracking camera and the hi-res camera?
    @Jetson-Nano Thanks, sounds good! I'll purchase one right away. Do the pins on my Voxl 2 board look okay because they appear bent?
    I've just purchased my very first Voxl 2 and Tracking Camera. I'm trying to connect the Tracking Camera to the J7 port on the Voxl 2 board, but the connectors don't seem to match. The product page doesn't mention a need for any additional connectors. Am I able to just connect the Tracking Camera into the port or will I need an additional connector. If it's the former, how do I connect it since the documentation isn't very clear? If it's the latter, what additional connector will I need to purchase? I'm attaching a picture of the Tracking Camera connector and the pins on the Voxl 2 that I'm trying to connect it to. Additionally, the pins seem to be a bit bent. Is this going to be an issue?
