Dong LiuD
Dong Liu
@Dong Liu
  • DSP - unable to load unsigned PD
    Dong LiuD Dong Liu
    @paynej
    Hi, I know this is very old topic. Did you manage to find a solution (or reason) yet?
  • Can't Flash VOXL2 (Battery Capacity is Very Low)
    Dong LiuD Dong Liu
    After multiple tries, the fastboot start to flash system images. But it got stuck. We then power cycle again, this time everything worked. We got the new nightly build flashed.
    Dong LiuD Dong Liu
    Looks like we need to press some physical button. I'll ask my coworker to open the heat sink again 🙂
    The system is just recovered by using qdl, voxl-version shows
    root@qrb5165-rb5:/# voxl-version
    system-image: 1.1.2-M0054-14.1a-FLAT-V3
    kernel:       #1 SMP PREEMPT Wed Feb 9 22:21:24 UTC 2022 4.19.125
    hw version:   865
    voxl-suite:
    I tried to flash it with voxl2_platform_nightly_20230521
    Dong LiuD Dong Liu
    @Dong-Liu Even I power on the voxl2 with usb cable connected, I get the same error.
    Dong LiuD Dong Liu
    Re: Can't Flash VOXL2 (Battery Capacity is Very Low)
    The same issue with the reference post.
    I followed the instruction that power on the voxl2, wait for 10 seconds, connect the USB cable. But I got
    [WARNING] Failed to reboot to fastboot
    Try power cycling VOXL while holding the fastboot button
    We're running the voxl2 with a power adapter, no battery is used.
  • mpa_to_ros publish stereo left and right image in different timestamp
    Dong LiuD Dong Liu
    Just tried to calibrated the stereo camera using ROS camera calibrator. Had to run the fixed voxl-mpa-to-ros. Because the ROS calibrator expects left and right to be exactly synchronized.
    Dong LiuD Dong Liu
    MR submitted.
    Dong LiuD Dong Liu
    will do soon.
    Dong LiuD Dong Liu
    Here is the code,
    imgL.header.stamp = (_clock_monotonic_to_ros_time(meta.timestamp_ns));
    imgL.width    = meta.width;
    imgL.height   = meta.height;
    imgL.step     = meta.width;
    imgL.encoding = GetRosFormat(meta.format);
    imgR.header.stamp = (_clock_monotonic_to_ros_time(meta.timestamp_ns));
    imgR.width    = meta.width;
    imgR.height   = meta.height;
    imgR.step     = meta.width;
    imgR.encoding = GetRosFormat(meta.format);
    They are all from meta.timestamp_ns, but _clock_monotonic_to_ros is using the current time, so the final times are slight different.
    I think it should be
    imgR.header.stamp = imgL.header.stamp
  • voxl-camer-server's hires snapshot produce huge files
    Dong LiuD Dong Liu
    I extract the findJpegSize function, add to voxl-camera-server. Now it will produce the correct size snapshot.
  • how to build voxl-camera-server
    Dong LiuD Dong Liu
    Found the problem 😞
    The voxl-docker script mount host /data to the container /data. But voxl-cross image has its own /data folder where /data/offline_ipk_packages/apq8096-proprietary_0.0.4.ipk is stored.
    Remove the -v /data:/data from voxl-docker script, start the docker again. This it works!
    Dong LiuD Dong Liu
    I followed the README from here https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server. But I got,
    /root/yoctohome/src/hal3/buffer_impl_apq8096.cpp:10:21: fatal error: log/log.h: No such file or directory
    #include <log/log.h>
    compilation terminated.
    In file included from /root/yoctohome/src/hal3/buffer_manager.cpp:7:0:
    /root/yoctohome/include/hal3/buffer_manager.h:11:30: fatal error: hardware/camera3.h: No such file or directory
    #include "hardware/camera3.h"
    Seems ./install_build_deps.sh doesn't install everything needed to build voxl-camera-server.
    Dong LiuD Dong Liu
    I found out this https://android.googlesource.com/platform/frameworks/av/+/master/services/camera/libcameraservice/device3/Camera3OutputStream.cpp#1337
    Is function android::camera2::JpegProcessor::findJpegSize() available on voxl?
    Dong LiuD Dong Liu
    I tried to use hires' snapshot to capture 4K images. But because the size of the image produced is huge, the disk filled up very quickly.
    The size of jpeg file is around 48M. If I use imagemagic to convert it to png, the size reduced to 3.7M. I then use imagemagic again to convert it to jpeg, the size is only 740K.
    Browsing through the code of hal3_camera_mgr.cpp, in WriteSnapshot() just writes the whole allocated buffer to file. Is there any variable indicates the real size of data produced by the camera module?
  • voxl-mpa-to-ros high system usage due to repeating invoking voxl-list-pipes
    Dong LiuD Dong Liu
    @Chad-Sweet I also added skip n frame feature in the camera interfaces, It is quite useful to reduce the network traffic. Do you think should submit one full request with bother features or two pull requests?
    Dong LiuD Dong Liu
    I'll create one
    Dong LiuD Dong Liu
    When we start t voxl-mpa-to-ros, the system usage becomes very high, the CPU is overheat very quickly. I found out it is because it constantly executing shell script voxl-list-pipes. Although it is doing it at 1 second interval, but that script is quite complicated, it invokes a lot other shell commands, such as cat, grep, tr, sort ... I disabled this repeating invoking voxl-list-pipes, the system usage went down. The CPU was not overhead.
    The purpose for repeating invoking voxl-list-pipes is for handle pipe added after voxl-mpa-to-ros started. But in most case we start voxl-map-to-ros after the services are started. I think at least it should make this function configurable.
  • Does voxl-jpeg-turbo use any HW accelleration?
    Dong LiuD Dong Liu
    @Eric-Katzfey I tried grep OMX.qcom from header files, could not find any.
    But, string libOmxCore.so only displayed video and audio codec. There is no image codec.
    voxl:/usr/include$ strings /usr/lib/libOmxCore.so |grep OMX.qcom
    OMX.qcom.video.decoder.avc
    OMX.qcom.video.decoder.avc.dsmode
    OMX.qcom.video.decoder.mpeg4
    OMX.qcom.video.decoder.vc1
    OMX.qcom.video.decoder.wmv
    OMX.qcom.file.muxer
    OMX.qcom.video.decoder.divx4
    OMX.qcom.video.decoder.divx311
    OMX.qcom.video.decoder.h263
    OMX.qcom.video.decoder.hevc
    OMX.qcom.video.decoder.vp8
    OMX.qcom.video.decoder.vp9
    OMX.qcom.video.encoder.mpeg4
    OMX.qcom.video.encoder.h263
    OMX.qcom.video.encoder.avc
    OMX.qcom.video.encoder.vp8
    OMX.qcom.video.encoder.hevc
    OMX.qcom.audio.decoder.Qcelp13
    OMX.qcom.audio.decoder.evrc
    OMX.qcom.audio.decoder.wma
    OMX.qcom.audio.decoder.wma10Pro
    OMX.qcom.audio.decoder.alac
    OMX.qcom.audio.decoder.ape
    OMX.qcom.audio.encoder.aac
    OMX.qcom.audio.encoder.qcelp13
    OMX.qcom.audio.encoder.evrc
    OMX.qcom.audio.encoder.amrnb
    OMX.qcom.audio.encoder.g711mlaw
    OMX.qcom.audio.encoder.g711alaw
    OMX.qcom.audio.encoder.amrwb
    OMX.qcom.audio.decoder.g711mlaw
    OMX.qcom.audio.decoder.g711alaw
    OMX.qcom.audio.decoder.amrwb
    OMX.qcom.audio.decoder.amrnb
    OMX.qcom.audio.decoder.aac
    OMX.qcom.audio.decoder.multiaac
    Dong LiuD Dong Liu
    @Eric-Katzfey Hi Eric. I tried use openMAX based on this code https://github.com/tjormola/rpi-openmax-demos/blob/master/rpi-encode-yuv.c
    It compiled correctly. But which openMAX component to use? That code is for rPI, so the component is "OMX.broadcom.image_encode". I changed to "OMX.qcom.image_encode" but I got no such component error.
    Could you tell me which omx component to use for the jpeg encoding?
    Thank you!
  • vslam map export and import
    Dong LiuD Dong Liu
    Can the vslam map of voxl qvio be exported and imported? And if it can import a previously exported map, will the qvio drift be reduced?
    Dong
