  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. Can't Flash VOXL2 (Battery Capacity is Very Low)
7 Posts 2 Posters 1.1k Views 1 Watching
  • Dong LiuD Offline
    Dong LiuD Offline
    Dong Liu
    Re: Can't Flash VOXL2 (Battery Capacity is Very Low)
    The same issue with the reference post.
    I followed the instruction that power on the voxl2, wait for 10 seconds, connect the USB cable. But I got
    [WARNING] Failed to reboot to fastboot
    Try power cycling VOXL while holding the fastboot button
    We're running the voxl2 with a power adapter, no battery is used.
    Dong LiuD 1 Reply Last reply
    • Dong LiuD Dong Liu
      Dong LiuD Offline
      Dong LiuD Offline
      Dong Liu
      @Dong-Liu Even I power on the voxl2 with usb cable connected, I get the same error.
      • modaltbM Offline
        modaltbM Offline
        modaltb
        Hi @Dong-Liu ,
        Normally to get around this issue, you need to bootup WITHOUT the USB cable connected initially, here's a video that shows the process:
        Link Preview Image
        VOXL 2 - How to Force Fastboot
        Travis from ModalAI shows you how to force flashboot your VOXL 2 while plugged into power module. ====================PRODUCTS MENTIONED==================== ...
        favicon
        YouTube (www.youtube.com)
        Out of curiosity, do you know the version of the the system image is on the VOXL2 presently? And what version are you trying to update to?
        We should have this battery warning issue fixed in platform release 0.9+.... so I'm making sure you aren't seeing this on a that release, as it 'should' be fixed but perhaps we're missing something!
        • Dong LiuD Offline
          Dong LiuD Offline
          Dong Liu
          Looks like we need to press some physical button. I'll ask my coworker to open the heat sink again 🙂
          The system is just recovered by using qdl, voxl-version shows
          root@qrb5165-rb5:/# voxl-version
          system-image: 1.1.2-M0054-14.1a-FLAT-V3
          kernel:       #1 SMP PREEMPT Wed Feb 9 22:21:24 UTC 2022 4.19.125
          hw version:   865
          voxl-suite:
          I tried to flash it with voxl2_platform_nightly_20230521
          • modaltbM Offline
            modaltbM Offline
            modaltb
            OK thanks, the 20230521 should contain the fix for the battery warning (it's in the android bootloader) but the 1.1.2 image still has the bug so yes, I believe if you're unable to get through the battery warning we need likely press the button in this case 😬
            We will also work towards updating our QDL image such that it updates to a newer version.
            Let me know if you get stuck and we can perhaps get on a screen share or something.
            • Dong LiuD Offline
              Dong LiuD Offline
              Dong Liu
              After multiple tries, the fastboot start to flash system images. But it got stuck. We then power cycle again, this time everything worked. We got the new nightly build flashed.
              • modaltbM Offline
                modaltbM Offline
                modaltb
                Hi @Dong-Liu OK thank you for the update. Once it has been updated to the latest image, I wouldn't expect that battery error to show up in the future.... if it does please let me know!
