Aldo Castro FreireA
Aldo Castro Freire
@Aldo Castro Freire
Regular
  • LTE connection drop after a while of being connected
    Aldo Castro FreireA Aldo Castro Freire
    Hi, I was wondering if I should replace my lte modem cause lte connection is dropping after a while of being online and it gets very hot about 65 degrees Celsius from a thermal camera.
    Kind Regards
  • No able to update the time using time-sync
    Today I tried using another provider for the SIM and it connected to the internet. Not sure where to start debugging this cause it is getting an IP, but I figure it needs internet access to get the time ?
    this is my output
    but it does not update time and no access to internet
    after that ping just hangs there
    I saw the wlan has a number for some odd reason
    it is working fine on my phone
    it was power-off at the moment of the photo
    it just hangs there, it does not even try I believe!!
    @tom same location.
    this is what I get
    the current location is Okotoks, Alberta, Canada. It was working fine a week ago but today it wasn't working. I have a 40Gbs plan. I got the sim in the same place and it was working fine
    it is using the LTE modem https://www.modalai.com/collections/voxl-add-ons/products/voxl-lte?variant=32449203601459 WP7610.
    it is currently using the Telus carrier, apn is isp.telus.com
    @tom yes, but I am unable to ping 8.8.8.8 for example it just hangs there. also, voxl-time-sync never picks up the real-time. I am not sure how to debug this one because the modem shows it does pick up an IP
    Hey guys I have been using the time service to get the time to get access the internet. but it is not able to update the time and therefore no access to the internet. It has been running for quite some time now
    so it is able to get an IP
  • Docker Pull is not working for my own hosted image
    I tried running docker pull using my own image on alpine arm64v8 but it is not working ? should I changed something ?
  • VPN but not internet
    I tried this setup, and my drone did not have any internet connection, is there a problem using AWS services for VPNs so far I have tried like 3 options and I am still no able to get internet. I need to able to access some other endpoints but I am still having some DNS issues
  • LTE strength
    I am not sure but none of the commands are running.
    Also, it does not have the command AT+QENG for me to check out
  • No able to get LTE strength
    When running this At command:
    echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB2
    ON the shell I got an error, my drone is online and connected to the internet without using any VPN
  • LTE strength
    I am getting "ERROR" when running this command
    Is there any tutorial you can share about your set up? I tried using online tutorials but they cut off the drone from any internet connection.
    I can connect to qgroundcontrol control but my computer and drone don't have access to internet so it is annoying for a setup
