Achyut SapariyaA
Achyut Sapariya
@Achyut Sapariya
  • VOXL2 IMU server not working
    Achyut SapariyaA Achyut Sapariya
    @tom
    I didn't aware about SKU setup but when I flashed i had run voxl-configure-mpa
    output of voxl-version
    voxl2:/$ voxl-version
    system-image: 1.7.10-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri Sep 27 21:18:59 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.0
    voxl-suite:   1.3.5
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.3/binary-arm64/
    Last Updated: 2024-12-20 06:50:35
    List:
    libfc-sensor                              1.0.7
    libmodal-cv                               0.5.11
    libmodal-exposure                         0.1.1
    libmodal-journal                          0.2.2
    libmodal-json                             0.4.3
    libmodal-pipe                             2.10.2
    libqrb5165-io                             0.4.6
    libvoxl-cci-direct                        0.2.3
    libvoxl-cutils                            0.1.1
    modalai-slpi                              1.1.19
    qrb5165-dfs-server                        0.2.0
    qrb5165-imu-server                        1.0.1
    qrb5165-rangefinder-server                0.1.3
    qrb5165-slpi-test-sig                     01-r0
    qrb5165-system-tweaks                     0.3.0
    qrb5165-tflite                            2.8.0-2
    voxl-bind-spektrum                        0.1.1
    voxl-camera-calibration                   0.5.7
    voxl-camera-server                        2.0.1
    voxl-ceres-solver                         2:1.14.0-10
    voxl-configurator                         0.8.5
    voxl-cpu-monitor                          0.4.8
    voxl-docker-support                       1.3.1
    voxl-elrs                                 0.2.2
    voxl-esc                                  1.4.7
    voxl-feature-tracker                      0.4.1
    voxl-flow-server                          0.3.6
    voxl-gphoto2-server                       0.0.10
    voxl-jpeg-turbo                           2.1.3-5
    voxl-lepton-server                        1.2.3
    voxl-lepton-tracker                       0.0.2
    voxl-libgphoto2                           0.0.4
    voxl-logger                               0.4.7
    voxl-mavcam-manager                       0.5.7
    voxl-mavlink                              0.1.1
    voxl-mavlink-server                       1.4.2
    voxl-modem                                1.1.3
    voxl-mongoose                             7.7.0-1
    voxl-mpa-to-ros                           0.3.9
    voxl-mpa-tools                            1.2.3
    voxl-neopixel-manager                     0.0.3
    voxl-open-vins                            0.4.14
    voxl-open-vins-server                     0.2.75
    voxl-opencv                               4.5.5-2
    voxl-osd                                  0.0.1
    voxl-portal                               0.7.0
    voxl-px4                                  1.14.0-2.0.84
    voxl-px4-params                           0.5.3
    voxl-qvio-server                          1.0.4
    voxl-remote-id                            0.0.9
    voxl-reset-slpi                           0.0.1
    voxl-state-estimator                      0.0.2
    voxl-streamer                             0.7.4
    voxl-suite                                1.3.5
    voxl-tag-detector                         0.0.4
    voxl-tflite-server                        0.3.4
    voxl-utils                                1.4.3
    voxl-uvc-server                           0.1.7
    voxl-vision-hub                           1.8.9
    voxl-vtx                                  1.1.0
    voxl2-io                                  0.0.3
    voxl2-system-image                        1.7.10-r0
    output of voxl-inspect-sku
    voxl2:/$ voxl-inspect-sku
    family code:   MRB-D0006 (sentinel)
    compute board: 4 (voxl2)
    hw version:    1
    cam config:    11
    modem config:  4 (LTE v2, 7610 NA (M0030))
    tx config:     7 (elrs_beta_fpv)
    extras config: 0 (none)
    SKU:           MRB-D0006-4-V1-C11-T7-M4-X0
    @tom Yes Initially IMU was working but suddenly next day it stops working.
    @tom I am running The Latest one 1.3.5. I had tried all possible things mentioned on docs but still not getting imu server running.
    @Achyut-Sapariya @Moderator Please help on this
    @yashas-katte Same Problem
  • 4g module is not able to give internet to voxl
    when i am trying to running this command
    ping 8.8.8.8
    getting
    "connect: Network is unreachable"
    However every led on my 4g module is solid yellow.
    Using Jio sim card and APN name is jionet.
