  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. VOXL2 IMU server not working
10 Posts 3 Posters 1.2k Views 1 Watching
  • yashas katteY Offline
    yashas katte
    I have VOXL 2(M0054) board, with VOXL suite version : 0.9.5.
    My imu0 is not working, when i directly run the inu server with this commnad
    voxl-imu-server
    voxl2:/$ voxl-imu-server
    loading calibration file
    calibration for IMU0:
    Gyro Offsets (rad/s): X:   0.000 Y:   0.000 Z:   0.000
    Accl Offsets (m/s^2): X:   0.000 Y:   0.000 Z:   0.000
    Accl Scale          : X:   1.000 Y:   1.000 Z:   1.000
    has_baseline_temp:      0
    gyro_baseline_temp (C):  30.000
    accl_baseline_temp (C):  30.000
    has_temp_cal:          0
    gyro_drift_coeff: X:   0.000000   0.000000   0.000000
    gyro_drift_coeff: Y:   0.000000   0.000000   0.000000
    gyro_drift_coeff: Z:   0.000000   0.000000   0.000000
    accl_drift_coeff: X:   0.000000   0.000000   0.000000
    accl_drift_coeff: Y:   0.000000   0.000000   0.000000
    accl_drift_coeff: Z:   0.000000   0.000000   0.000000
    calibration for IMU1:
    has_temp_cal:          0
    calibration for IMU2:
    has_temp_cal:          0
    calibration for IMU3:
    has_temp_cal:          0
    loading config file
    imu_apps_enable:                 1
    imu_apps_bus:                    3
    imu_apps_sample_rate_hz:         1000.0
    imu_apps_lp_cutoff_freq_hz:      92.0
    imu_apps_rotate_common_frame:    1
    imu_apps_fifo_poll_rate_hz:      100.0
    aux_imu1_enable:                 0
    aux_imu1_bus:                    1
    aux_imu1_sample_rate_hz:         1000.0
    aux_imu1_lp_cutoff_freq_hz:      92.0
    aux_imu1_fifo_poll_rate_hz:      100.0
    aux_imu2_enable:                 0
    aux_imu2_spi_bus:                14
    aux_imu2_sample_rate_hz:         1000.0
    aux_imu2_lp_cutoff_freq_hz:      92.0
    aux_imu2_fifo_poll_rate_hz:      100.0
    aux_imu3_enable:                 0
    aux_imu3_spi_bus:                5
    aux_imu3_sample_rate_hz:         1000.0
    aux_imu3_lp_cutoff_freq_hz:      92.0
    aux_imu3_fifo_poll_rate_hz:      100.0
    detected ICM42688 on spi bus[id] 3
    Detected board M0054
    Initializing IMU0
    using ODR=1000.00hz which is the nearest the icm42688 can get to 1000.0
    ERROR: in icm42688_basic_read read all 0's
    ERROR: failed to read data from IMU0
    ERROR: failed to init at least one IMU
    I have tried flashing previous versions of voxl suite but its same result.
    It was working perfectly before, but suddenly it stopped working.
    So flashed suite again.
    Please help
    Achyut SapariyaA 1 Reply Last reply
    • yashas katteY yashas katte
      voxl-imu-server
      has_temp_cal:          0
      has_temp_cal:          0
      has_temp_cal:          0
      has_temp_cal:          0
      loading config file
      imu_apps_enable:                 1
      imu_apps_bus:                    3
      aux_imu1_enable:                 0
      aux_imu1_bus:                    1
      aux_imu2_enable:                 0
      aux_imu3_enable:                 0
      aux_imu3_spi_bus:                5
      Initializing IMU0
      Please help
      Achyut SapariyaA Offline
      Achyut Sapariya
      @yashas-katte Same Problem
      • Achyut SapariyaA Achyut Sapariya
        Achyut Sapariya
        @Achyut-Sapariya @Moderator Please help on this
          @Achyut-Sapariya Can you try updating to the latest SDK (1.3.5) and give it a go?
            Achyut Sapariya
            @tom I am running The Latest one 1.3.5. I had tried all possible things mentioned on docs but still not getting imu server running.
              @Achyut-Sapariya You said "VOXL suite version : 0.9.5" so I wasn't sure if that was what you currently had loaded. Did the IMU work at one point and then stop working? Trying to determine whether or not this is a hardware issue.
                Achyut Sapariya
                @tom Yes Initially IMU was working but suddenly next day it stops working.
                  @Achyut-Sapariya When flashing the board did you go through SKU setup and allow voxl-configure-mpa to run?
                  Can you post the output of voxl-version and voxl-inspect-sku?
                    Achyut Sapariya
                    I didn't aware about SKU setup but when I flashed i had run voxl-configure-mpa
                    voxl2:/$ voxl-version
                    system-image: 1.7.10-M0054-14.1a-perf
                    kernel:       #1 SMP PREEMPT Fri Sep 27 21:18:59 UTC 2024 4.19.125
                    hw platform:  M0054
                    mach.var:     1.0.0
                    voxl-suite:   1.3.5
                    Packages:
                    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.3/binary-arm64/
                    Last Updated: 2024-12-20 06:50:35
                    List:
                    libfc-sensor                              1.0.7
                    libmodal-cv                               0.5.11
                    libmodal-exposure                         0.1.1
                    libmodal-pipe                             2.10.2
                    libqrb5165-io                             0.4.6
                    libvoxl-cci-direct                        0.2.3
                    modalai-slpi                              1.1.19
                    qrb5165-dfs-server                        0.2.0
                    qrb5165-imu-server                        1.0.1
                    qrb5165-rangefinder-server                0.1.3
                    qrb5165-system-tweaks                     0.3.0
                    voxl-bind-spektrum                        0.1.1
                    voxl-camera-calibration                   0.5.7
                    voxl-camera-server                        2.0.1
                    voxl-configurator                         0.8.5
                    voxl-cpu-monitor                          0.4.8
                    voxl-docker-support                       1.3.1
                    voxl-elrs                                 0.2.2
                    voxl-esc                                  1.4.7
                    voxl-feature-tracker                      0.4.1
                    voxl-flow-server                          0.3.6
                    voxl-lepton-server                        1.2.3
                    voxl-lepton-tracker                       0.0.2
                    voxl-logger                               0.4.7
                    voxl-mavcam-manager                       0.5.7
                    voxl-mavlink-server                       1.4.2
                    voxl-modem                                1.1.3
                    voxl-mpa-to-ros                           0.3.9
                    voxl-mpa-tools                            1.2.3
                    voxl-neopixel-manager                     0.0.3
                    voxl-open-vins                            0.4.14
                    voxl-open-vins-server                     0.2.75
                    voxl-opencv                               4.5.5-2
                    voxl-osd                                  0.0.1
                    voxl-portal                               0.7.0
                    voxl-px4                                  1.14.0-2.0.84
                    voxl-px4-params                           0.5.3
                    voxl-qvio-server                          1.0.4
                    voxl-remote-id                            0.0.9
                    voxl-reset-slpi                           0.0.1
                    voxl-state-estimator                      0.0.2
                    voxl-streamer                             0.7.4
                    voxl-suite                                1.3.5
                    voxl-tflite-server                        0.3.4
                    voxl-utils                                1.4.3
                    voxl-uvc-server                           0.1.7
                    voxl-vision-hub                           1.8.9
                    voxl-vtx                                  1.1.0
                    voxl2-io                                  0.0.3
                    voxl2-system-image                        1.7.10-r0
                    output of voxl-inspect-sku
                    voxl2:/$ voxl-inspect-sku
                    family code:   MRB-D0006 (sentinel)
                    compute board: 4 (voxl2)
                    hw version:    1
                    cam config:    11
                    modem config:  4 (LTE v2, 7610 NA (M0030))
                    tx config:     7 (elrs_beta_fpv)
                    extras config: 0 (none)
                    SKU:           MRB-D0006-4-V1-C11-T7-M4-X0
                      hw platform:  M0054
                      mach.var:     1.0.0
                      voxl-suite:   1.3.5
                      Packages:
                      List:
                      libfc-sensor                              1.0.7
                      libmodal-cv                               0.5.11
                      libqrb5165-io                             0.4.6
                      modalai-slpi                              1.1.19
                      voxl-elrs                                 0.2.2
                      voxl-esc                                  1.4.7
                      voxl-logger                               0.4.7
                      voxl-modem                                1.1.3
                      voxl-opencv                               4.5.5-2
                      voxl-osd                                  0.0.1
                      voxl-portal                               0.7.0
                      voxl-streamer                             0.7.4
                      voxl-suite                                1.3.5
                      voxl-utils                                1.4.3
                      voxl-vtx                                  1.1.0
                      voxl2-io                                  0.0.3
                      hw version:    1
                      cam config:    11
                      @Achyut-Sapariya That all looks normal, I'd recommend submitting an RMA and our team can diagnose the issue: https://www.modalai.com/pages/rma
