Hello, I am interested in joining this Beta.
Is there a way I can just purchase the CSI-2 converter made by ModalAI without purchasing the AUVIDIA B102 HDMI to CSI-2 Bridge (22 pin FPC) from ModalAI?
I want to be able to issue trigger commands to a sony camera and need to stream the video from the HDMI instead of the Multiport in order to achieve this.
Thanks,
Aaron Bottke
Aaron Bottke
HDMI Input Beta -
Sony RXO over USBUltimately if I can use px4s trigger function to tell gphoto2 to trigger an image that would be idea. I should be able to use mavlink to tell when that command is given and then issue gphoto2 to issue the command. This will allow me to do high quality mapping missions with the system.
Sony RXO over USBWill at any point gphoto2's trigger features be ported over to the voxl-gphoto2? I want to be able to trigger a photo/video to be captured and stored on the RX0's SD in-order to achieve max resolution.
Sony RXO over USB@Eric-Katzfey
Not installing the voxl-suite at first and using opkg to install gphoto2 and voxl-streamer worked.
Before I was following the instructions and compiling my own ipk then loading them on using adb. I've got both a video stream and telemetry over the Microhard Modem!
Thanks, -
Sony RXO over USBThe gphoto-2 seams to be breaking the voxl-vision-px4 system. Any command associated with the voxl-vision-px4 system causes the voxl to kick any adb connection then prevent any from connecting until a power cycle. I can't get both voxl-vision-px4 and gphoto2 installed and running on the same system.
Any thoughts?
Thanks, -
Sony RXO over USBThat got it working!!! I really appreciate the help with this!!!
My telemetry quit working though so I have to play with that and get that up and running again.
Thanks! -
Sony RXO over USBUnless I am missing something in the command this is the result from running voxl-streamer and voxl-gphoto2.
Thanks for all the help.
Sony RXO over USBResults of gphoto2 --capture-preview on my host machine as follows.
On the VOXL running voxl-gphoto2 -d -v -g yields way to much for me to share here so I will split it up.
voxl-gphoto2 -d below.
voxl-gphoto2 -v yields a lot of messages very quickly.
Output as follows.
voxl-gphoto2 -v yields too many messages for me to upload with a screenshot.
I don't see a way to submit a .txt file but the most interesting part of the output that I see is this.
Sony RXO over USBYes we are attempting to use the RX0. The image below shows that gphoto2 does detect it on an ubuntu machine.
Sony RXO over USBThe USB and Serial Debug board arrived today. I unbricked the board and installed gphoto2 and VOXL-streamer. The image below is an error I received after running the voxl-gphoto2 command.
Please advise.
