  3. Error on running gst_rtsp_server, can not get Postionn
4 Posts 2 Posters 860 Views 1 Watching
  • Nathan NiN Offline
    Nathan NiN Offline
    Nathan Ni
    Using visual indoor positioning, the flight control can't get the position information of VOXL and QGC can't get the position information of XY, there is the position information of Z axis.
    Reported error: gst_rtsp_server_attach failed.
    Please help!
      Nathan NiN Offline
      Nathan Ni
      • Nathan NiN Nathan Ni
        @Nathan-Ni voxl-streamer (https://docs.modalai.com/voxl-streamer/) is an application to stream video using RTSP. It has nothing to do with visual indoor positioning. Is your question about positioning errors or about video streaming?
          @Nathan-Ni In your picture you show that voxl-streamer is already running. Then you launch another instance from the command line and get a failure. This is most likely due to not specifying a different port for the new instance. Documentation is here: https://docs.modalai.com/voxl-streamer/#viewing-output-from-multiple-connected-cameras
