  3. Package installs without internet
18 Posts 5 Posters 4.0k Views 3 Watching
  • S Offline
    S Offline
    sarahl
    Hi, I recently got a hold of a Voxl2, but I don't yet have an internet connection on the board. Is there a way to install packages (similar to ones on the Voxl1, such as docker and ROS) without internet access? Additionally, are the debians on this page for both the RB5 and the Voxl2 interchangebly?
    404 Not Found
    favicon
    (voxl-packages.modalai.com)
    i was able to install the voxl-suite package, but I got this error when trying to install voxl-docker-support:
    voxl2:~/deb$ dpkg -i voxl-docker-support_1.1.3-202201182231.deb
    Selecting previously unselected package voxl-docker-support.
    (Reading database ... 80134 files and directories currently installed.)
    Preparing to unpack voxl-docker-support_1.1.3-202201182231.deb ...
    Unpacking voxl-docker-support (1.1.3-202201182231) ...
    dpkg: dependency problems prevent configuration of voxl-docker-support:
    voxl-docker-support depends on docker; however:
    Package docker is not installed.
    dpkg: error processing package voxl-docker-support (--install):
    dependency problems - leaving unconfigured
    Errors were encountered while processing:
    voxl-docker-support
    Is there a way to install docker onto Voxl2 without internet? I wanted to run a docker image I had built for Voxl1 that has ROS/OpenCV and a node for a USB camera. Alternately, is there a debian for ROS that I can install directly on the Voxl2?
      The easiest would be to use an add-on board that provides connectivity either directly or with a WiFi dongle. The supported Wifi dongles list can be found here: https://beta-docs.modalai.com/voxl2-wifidongle-user-guide/
      S 1 Reply Last reply
      • S sarahl
        404 Not Found
        favicon
        voxl-docker-support
        @sarahl Some packages in dev-deb will work on RB5 as well as Voxl2, but they are really only intended for Voxl2 at this point. We will be making a formal release with a set of packages that work on both RB5 and Voxl2 in about a week.
          S Offline
          S Offline
          sarahl
          @Eric-Katzfey Thanks Eric, I look forward to the release! Any update on when that will be?
          • Chad SweetC Chad Sweet
            S Offline
            S Offline
            sarahl
            @Chad-Sweet I finally got a hold of a wifi dongle from the lab, but it's this one so I'm not sure if it's compatible. So far, it's not lighting up as usual when plugged into the fastboot board (M0078) via the usb-female connector. This dongle usually works with our other ubuntu machines, but maybe we'll have to order some of the supported ones listed on the page. One thing I wanted to ask about that docs page, it mentions under the "rebooting" section that the dongle should now be connected to voxl2 via usb-c. is that typo? I have it connected via the fastboot board and jst-to-usb cable, but the usb-c is being used for adb currently. Also, is there any indicator on the expander board that it's properly plugged into the voxl2?
            • S sarahl
              @sarahl No, it definitely does not need to be in USB C.
              • tomT Offline
                @sarahl The dongle's driver is most likely not built in to the kernel by default. What does lsusb show? It may show the name of the necessary driver.
                  S Offline
                  S Offline
                  sarahl
                  @tom this is what lsusb shows:
                  Bus 001 Device 003: ID 7392:b811 Edimax Technology Co., Ltd
                  • S Offline
                    S Offline
                    sarahl
                    Separate question: so I have wifi hooked up on an RB5, but everytime I reboot, the ip address changes. Is there a way to change that? It doesn't seem to happen with my voxls (in station).
                    • S sarahl
                      @sarahl You'd probably be better off purchasing one of the dongles listed here: https://beta-docs.modalai.com/voxl2-wifidongle-user-guide/
                      It takes some work to integrate a new WiFi driver and isn't the most straight-forward thing to do.
                      • S sarahl
                        @sarahl As for static ip on RB5, I would check out this thread for more info: https://forum.modalai.com/topic/794/how-to-set-up-a-static-ip-in-rb5/17?_=1649955285381
                        • tomT Offline
                          @sarahl It is a known bug with the Thundercomm SOMs.
                          • S Offline
                            S Offline
                            sarahl
                            @tom thanks! we did put in an order for some, so hopefully I will get those soon. also thanks for the link, I'll check it out!
                            • S Offline
                              S Offline
                              sarahl
                              wrote on last edited by sarahl
                              #14
                              So I'm trying to reflash the Voxl2, but the image listed in the docs (https://docs.modalai.com/voxl2-platform-release/#voxl2_platform_121-07) doesn't seem to be available on the downloads page, just 1.1.4. Is this available yet?
                              We've had issues installing the available system image (1.1.4) with/without the fastboot board, either with fastboot devices showing nothing, or getting an error like:
                              sudo ./flash-full.sh
                              [INFO] version: 0.0
                              [INFO] adb installed
                              [INFO] fastboot installed
                              [INFO] qti-ubuntu-robotics-image-qrb5165-rb5-boot.img present
                              [INFO] abl.elf present
                              [INFO] qti-ubuntu-robotics-image-qrb5165-rb5-sysfs.ext4 present
                              [INFO] Rebooting to fastboot bootloader
                              error: no devices/emulators found
                              [INFO] Flashing boot.img
                              target reported max download size of 805306368 bytes
                              sending 'boot_a' (20884 KB)...
                              OKAY [ 0.117s]
                              writing 'boot_a'...
                              OKAY [ 0.031s]
                              finished. total time: 0.148s
                              sending 'boot_b' (20884 KB)...
                              OKAY [ 0.111s]
                              writing 'boot_b'...
                              OKAY [ 0.024s]
                              finished. total time: 0.135s
                              [INFO] Flashing abl.elf
                              sending 'abl_a' (148 KB)...
                              OKAY [ 0.006s]
                              writing 'abl_a'...
                              OKAY [ 0.002s]
                              finished. total time: 0.008s
                              sending 'abl_b' (148 KB)...
                              OKAY [ 0.010s]
                              writing 'abl_b'...
                              OKAY [ 0.002s]
                              finished. total time: 0.012s
                              [INFO] Flashing sysfs.ext4
                              erasing 'system'...
                              OKAY [ 0.072s]
                              sending sparse 'system' 1/4 (784773 KB)...
                              OKAY [ 3.890s]
                              writing 'system' 1/4...
                              OKAY [ 0.000s]
                              sending sparse 'system' 2/4 (784403 KB)...
                              FAILED (data write failure (Cannot send after transport endpoint shutdown))
                              finished. total time: 7.594s
                              Edit: Actually, I got the fastboot image flashing to work on one board! But still wondering if this updated image is available, thanks!
                                We just uploaded the image to the downloads page, it can be found under the VOXL2 platform releases folder!
                                • ? A Former User
                                  S Offline
                                  S Offline
                                  sarahl
                                  @Alex-Gardner thanks so much!
                                  • S Offline
                                    S Offline
                                    sarahl
                                    What's the best way to install full ROS melodic without all the voxl-suite packages being uninstalled due to dependency conflicts (e.g. opencv)?
                                    • S Offline
                                      S Offline
                                      sarahl
                                      Also, how should mavros (px4.launch) be run with the internal px4 on the voxl2?
