  3. Package installs without internet
voxl-2
18 Posts 5 Posters 4.0k Views 3 Watching
  • S sarahl
    @Chad-Sweet I finally got a hold of a wifi dongle from the lab, but it's this one so I'm not sure if it's compatible. So far, it's not lighting up as usual when plugged into the fastboot board (M0078) via the usb-female connector. This dongle usually works with our other ubuntu machines, but maybe we'll have to order some of the supported ones listed on the page. One thing I wanted to ask about that docs page, it mentions under the "rebooting" section that the dongle should now be connected to voxl2 via usb-c. is that typo? I have it connected via the fastboot board and jst-to-usb cable, but the usb-c is being used for adb currently. Also, is there any indicator on the expander board that it's properly plugged into the voxl2?
    @sarahl No, it definitely does not need to be in USB C.
      @sarahl The dongle's driver is most likely not built in to the kernel by default. What does lsusb show? It may show the name of the necessary driver.
      S 1 Reply Last reply
        S Offline
        S Offline
        sarahl
        @tom this is what lsusb shows:
        Bus 001 Device 003: ID 7392:b811 Edimax Technology Co., Ltd
        • S Offline
          S Offline
          sarahl
          Separate question: so I have wifi hooked up on an RB5, but everytime I reboot, the ip address changes. Is there a way to change that? It doesn't seem to happen with my voxls (in station).
          • S sarahl
            @sarahl You'd probably be better off purchasing one of the dongles listed here: https://beta-docs.modalai.com/voxl2-wifidongle-user-guide/
            It takes some work to integrate a new WiFi driver and isn't the most straight-forward thing to do.
            • S sarahl
              @sarahl As for static ip on RB5, I would check out this thread for more info: https://forum.modalai.com/topic/794/how-to-set-up-a-static-ip-in-rb5/17?_=1649955285381
                @sarahl It is a known bug with the Thundercomm SOMs.
                • S Offline
                  S Offline
                  sarahl
                  @tom thanks! we did put in an order for some, so hopefully I will get those soon. also thanks for the link, I'll check it out!
                  • S Offline
                    S Offline
                    sarahl
                    wrote on last edited by sarahl
                    #14
                    So I'm trying to reflash the Voxl2, but the image listed in the docs (https://docs.modalai.com/voxl2-platform-release/#voxl2_platform_121-07) doesn't seem to be available on the downloads page, just 1.1.4. Is this available yet?
                    We've had issues installing the available system image (1.1.4) with/without the fastboot board, either with fastboot devices showing nothing, or getting an error like:
                    sudo ./flash-full.sh
                    [INFO] version: 0.0
                    [INFO] adb installed
                    [INFO] fastboot installed
                    [INFO] qti-ubuntu-robotics-image-qrb5165-rb5-boot.img present
                    [INFO] abl.elf present
                    [INFO] qti-ubuntu-robotics-image-qrb5165-rb5-sysfs.ext4 present
                    [INFO] Rebooting to fastboot bootloader
                    error: no devices/emulators found
                    [INFO] Flashing boot.img
                    target reported max download size of 805306368 bytes
                    sending 'boot_a' (20884 KB)...
                    OKAY [ 0.117s]
                    writing 'boot_a'...
                    OKAY [ 0.031s]
                    finished. total time: 0.148s
                    sending 'boot_b' (20884 KB)...
                    OKAY [ 0.111s]
                    writing 'boot_b'...
                    OKAY [ 0.024s]
                    finished. total time: 0.135s
                    [INFO] Flashing abl.elf
                    sending 'abl_a' (148 KB)...
                    OKAY [ 0.006s]
                    writing 'abl_a'...
                    OKAY [ 0.002s]
                    finished. total time: 0.008s
                    sending 'abl_b' (148 KB)...
                    OKAY [ 0.010s]
                    writing 'abl_b'...
                    OKAY [ 0.002s]
                    finished. total time: 0.012s
                    [INFO] Flashing sysfs.ext4
                    erasing 'system'...
                    OKAY [ 0.072s]
                    sending sparse 'system' 1/4 (784773 KB)...
                    OKAY [ 3.890s]
                    writing 'system' 1/4...
                    OKAY [ 0.000s]
                    sending sparse 'system' 2/4 (784403 KB)...
                    FAILED (data write failure (Cannot send after transport endpoint shutdown))
                    finished. total time: 7.594s
                    Edit: Actually, I got the fastboot image flashing to work on one board! But still wondering if this updated image is available, thanks!
                    • ? Offline
                      We just uploaded the image to the downloads page, it can be found under the VOXL2 platform releases folder!
                      • ? A Former User
                        S Offline
                        S Offline
                        sarahl
                        @Alex-Gardner thanks so much!
                        • S Offline
                          S Offline
                          sarahl
                          What's the best way to install full ROS melodic without all the voxl-suite packages being uninstalled due to dependency conflicts (e.g. opencv)?
                          • S Offline
                            S Offline
                            sarahl
                            Also, how should mavros (px4.launch) be run with the internal px4 on the voxl2?
