  2. Software Development
  3. Installing OpenCV-3.4.6.ipk fails on VOXL Emulator Docker Image (1.0.0)
opencvdockervoxl-emulator
2 Posts 1 Posters 1.8k Views 1 Watching
  • adminA Offline
    adminA Offline
    wrote on last edited by admin
    GitLab Issues import
    Installing OpenCV-3.4.6.ipk fails on voxl_emulator opkg install OpenCV-3.4.6.ipk. Even tried compiling and installing the generated ipk. Likely issue with installed opencv2.4 version from ROS.
    Deploy on VOXL target works fine.
    • adminA Offline
      adminA Offline
      Total hack, but this just worked. We still need a clean way of uninstalling opencv2.4
      $ opkg list | grep opencv
      $ opkg remove lib32-opencv --force-removal-of-dependent-packages
      $ opkg remove lib32-opencv-dbg --force-removal-of-dependent-packages
      $ opkg remove lib32-opencv-calib3d2.4 --force-removal-of-dependent-packages
      $ opkg remove lib32-libopencv-calib3d2.4 --force-removal-of-dependent-packages
      $ opkg remove lib32-libopencv-core2.4 --force-removal-of-dependent-packages
      $ opkg install opencv_3.4.6_8x96.ipk
      $ /usr/bin/opencv_version
      3.4.6
