    Installing OpenCV-3.4.6.ipk fails on VOXL Emulator Docker Image (1.0.0)
    Software Development
    opencv docker voxl-emulator
    • adminA
      admin admin
      GitLab Issues import
      Installing OpenCV-3.4.6.ipk fails on voxl_emulator opkg install OpenCV-3.4.6.ipk. Even tried compiling and installing the generated ipk. Likely issue with installed opencv2.4 version from ROS.
      Deploy on VOXL target works fine.
      • adminA
        admin admin
        Total hack, but this just worked. We still need a clean way of uninstalling opencv2.4
        $ opkg list | grep opencv
        $ opkg remove lib32-opencv --force-removal-of-dependent-packages
        $ opkg remove lib32-opencv-dbg --force-removal-of-dependent-packages
        $ opkg remove lib32-opencv-calib3d2.4 --force-removal-of-dependent-packages
        $ opkg remove lib32-libopencv-calib3d2.4 --force-removal-of-dependent-packages
        $ opkg remove lib32-libopencv-core2.4 --force-removal-of-dependent-packages
        $ opkg install opencv_3.4.6_8x96.ipk
        $ /usr/bin/opencv_version
        3.4.6
