  3. VOXLFlight LTE modem
6 Posts 4 Posters 773 Views 2 Watching
  • R Offline
    R Offline
    relevinsky
    I have several questions:
    1. What's reason that by voxl-inspect-services I see, that :
      voxl-modem
      voxl-qvio-server
      voxl-vision-px4
      are in "Not running" state, while the services were configured and I received "approving for it enabling and starting" -
      "enabling voxl-qvio-server systemd service
      starting voxl-qvio-server systemd service
      Done configuring voxl-qvio-server"
    2)How could i know if voxl flight is LTE server or client?
    3)Is it possible to configure LTE v2 modem except of "voxl-configure-modem"?(AT commands)
      If the voxl services were marked as enabled but not running that means that they were stopped for one of two reasons: A) you ran them manually in a terminal window which killed the background process since only one instance can run at a time or B) they encountered some sort of error. If the ran into an error you can check the output logs from the services using journalctl -u voxl-qvio-server or journalctl -u voxl-vision-px4. If they crashed due to an error, the info as to why will be there and posting those logs will allow us to help further.
      I can't speak to the modem configuration stuff but i'll ping someone who can.
      • tomT Offline
        wrote on last edited by tom
        @relevinsky For voxl-modem depending on what configuration is set up, the background service may exit. This could be due to a failure, or it may be a successful exit if it finished running everything it needed to.
        Once the modem is brought up, you can send AT commands to /dev/ttyUSB2 using something similar to:
        echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB2
        This exact AT command isn't supported on Sierra modems but using this same format of piping a command to microcom will work.
        Here is a link to a Sierra doc about which AT commands are supported on 76** modems: https://source.sierrawireless.com/resources/airprime/software/airprime_wpx5xx_wp76xx_wp77xx_at_command_reference/
        R 1 Reply Last reply
        • R Offline
          R Offline
          relevinsky
          @Alex-Gardner said in VOXLFlight LTE modem:
          Thank you for your answer.
          I found a problem:
          "loading qvio config file
          Error in json_read_file while parsing file /etc/modalai/voxl-qvio-server.conf"
          I made only voxl-configure-qvio ,the broken file is created after that (i think)
          Could you help me to solve a problem?
            R Offline
            R Offline
            relevinsky
            @tom
            Thank you.
            How could i know wherever voxl flight is LTE server or client?
            • R relevinsky
              @tom
              Thank you.
              @relevinsky What do you mean by LTE server / client? LTE is a cellular technology that will provide your Voxl flight with Internet access.
