  3. Failed to start voxl-streamer
4 Posts 3 Posters 1.1k Views 2 Watching
  • A Offline
    ashwin-umdlife
    wrote on last edited by ashwin-umdlife
    Setup
    1. Voxl m500
    2. voxl-suite
    system-image:    ModalAI 3.3.0 BUILDER: ekatzfey BUILD_TIME: 2021-06-06_19:28
    kernel:          #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 3.18.71-perf
    architecture:    aarch64
    processor:       apq8096
    os:              GNU/Linux
    voxl-suite:
    Package: voxl-suite
    Version: 0.4.6
    Depends: libmodal_exposure (>= 0.0.2), libmodal_json (>= 0.3.5), librc_math (>= 1.1.5), libvoxl_cutils (>= 0.0.2), libvoxl_io (>= 0.5.4), opencv (>= 4.5.2-1), voxl-mavlink (>= 0.0.2), libmodal_pipe (>= 2.0.7), voxl-camera-server (>= 0.7.1), voxl-cpu-monitor (>= 0.1.7), voxl-dfs-server (>= 0.2.0), voxl-imu-server (>= 0.8.1), voxl-mpa-tools (>= 0.2.6), voxl-qvio-server (>= 0.3.1), voxl-tag-detector (>= 0.0.2), voxl-tflite-server (>= 0.1.0), voxl-vision-px4 (>= 0.9.2), openmp (>= 10.0.2), voxl-tflite (>= 0.0.1), voxl-nodes (>= 0.1.6), mavlink-camera-manager (>= 0.0.2), voxl-docker-support (>= 1.1.3), voxl-gphoto2 (>= 0.0.5), voxl-modem (>= 0.12.0), voxl-streamer (>= 0.2.3), voxl-utils (>= 0.7.1), voxl-vpn (>= 0.0.3)
    Replaces: voxl-suite-dev
    Section: base
    Architecture: all
    Maintainer: james@modalai.com
    MD5Sum: a800fd5f7c98cfa4e6ed1638cf25d909
    Filename: voxl-suite_0.4.6.ipk
    Description: meta-package for voxl-suite software collection
    Installed-Time: 4206
    Package: voxl-suite
    Version: 0.2.0
    Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
    Status: unknown ok not-installed
    Section: base
    Architecture: armv7a
    MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
    Filename: voxl-suite_0.2.0.ipk
    Description: meta-package to install all of the voxl-suite
    Steps to reproduce error
    1. Setup camera using voxl-camera-configure and choose option 3
    2. Run the streamer voxl-streamer -c hires
    / # voxl-streamer -c hires
    Using configuration hires
    Error in json_read_file while parsing file /etc/modalai/voxl-streamer.conf
    The syntax error occured immediately BEFORE the following line:
    "configuration":"tracking","hires":{"input":{"interface":"mpa","mpa-camera":"hires"},"output":{"stream":{"rotation":0,"width":640,"height":480,"decimator":2,"bitrate":1000000}}},"hires-logo":{"input":{"interface":"mpa","mpa-camera":"hires"},"output":{"stream":{"rotation":0,"width":640,"height":480,"decimator":2,"bitrate":1000000}},"overlay":{"location":"/etc/modalai/modalai.png","offset_x":-1,"offset_y":-1}},"stereo":{"input":{"interface":"mpa","mpa-camera":"stereo"},"output":{"stream":{"width":640,"height":960,"decimator":2,"bitrate":1000000}}},"tracking":{"input":{"interface":"mpa","mpa-camera":"tracking"},"output":{"stream":{"width":640,"height":480,"decimator":2,"bitrate":1000000}}},"dfs-disparity":{"input":{"interface":"mpa","mpa-camera":"dfs_disparity"},"output":{"stream":{"width":640,"height":480,"decimator":2,"bitrate":1000000}}},"qvio-overlay":{"input":{"interface":"mpa","mpa-camera":"qvio_overlay"},"output":{"stream":{"width":640,"height":544,"decimator":2,"bitrate":1000000}}},"tflite-overlay":{"input":{"interface":"mpa","mpa-camera":"tflite"},"output":{"stream":{"width":640,"height":480,"decimator":2,"bitrate":1000000}}},"hdmi-mpa":{"input":{"interface":"mpa","mpa-camera":"v4l2"},"output":{"stream":{"width":640,"height":360,"decimator":2,"bitrate":1000000}}},"gphoto2-mpa":{"input":{"interface":"mpa","mpa-camera":"gphoto2"},"output":{"stream":{"width":640,"height":360,"decimator":2,"bitrate":1000000}}},"video-test":{"input":{"interface":"test","frame":{"width":1280,"height":720,"format":"uyvy"}},"output":{"stream":{"rotation":0,"width":640,"height":360,"rate":15,"bitrate":1000000}}},"uvc-video":{"input":{"interface":"uvc","device":"/dev/video0"},"output":{"stream":{"rotation":0,"width":640,"height":360,"rate":15,"bitrate":1000000}}}}
    Failed to open configuration file /etc/modalai/voxl-streamer.conf
    ERROR: Could not parse the configuration data
    Configuration file wasn't edited.
        "conf-version":"1.0"
        "configuration": "tracking",
        "hires": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "hires" },
            "output": {
                "stream": {
                    "rotation": 0,
                    "width": 640,
                    "height": 480,
                    "decimator": 2,
                    "bitrate": 1000000 } }
        "hires-logo": {
            "input": {
                "interface": "mpa",
            "output": {
                "stream": {
                    "rotation": 0,
                    "width": 640,
                    "height": 480,
                    "decimator": 2,
                    "bitrate": 1000000 } },
            "overlay": {
                "location": "/etc/modalai/modalai.png",
                "offset_x": -1,
                "offset_y": -1 }
        "stereo": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "stereo" },
            "output": {
                "stream": {
                    "width": 640,
                    "height": 960,
                    "decimator": 2,
        "tracking": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "tracking" },
            "output": {
                "stream": {
                    "width": 640,
                    "height": 480,
                    "decimator": 2,
        "dfs-disparity": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "dfs_disparity" },
            "output": {
                "stream": {
                    "width": 640,
                    "height": 480,
                    "decimator": 2,
        "qvio-overlay": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "qvio_overlay" },
            "output": {
                "stream": {
                    "width": 640,
                    "height": 544,
                    "decimator": 2,
        "tflite-overlay": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "tflite" },
            "output": {
                "stream": {
                    "width": 640,
                    "height": 480,
                    "decimator": 2,
        "hdmi-mpa": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "v4l2" },
            "output": {
                "stream": {
                    "width": 640,
                    "height": 360,
                    "decimator": 2,
        "gphoto2-mpa": {
            "input": {
                "interface": "mpa",
                "mpa-camera": "gphoto2" },
            "output": {
                "stream": {
                    "width": 640,
                    "height": 360,
                    "decimator": 2,
        "video-test": {
            "input": {
                "interface": "test",
                "frame": {
                    "width": 1280,
                    "height": 720,
                    "format": "uyvy" } },
            "output": {
                "stream": {
                    "rotation": 0,
                    "width": 640,
                    "height": 360,
                    "rate": 15,
        "uvc-video": {
            "input": {
                "interface": "uvc",
                "device": "/dev/video0" },
            "output": {
                "stream": {
                    "rotation": 0,
                    "width": 640,
                    "height": 360,
                    "rate": 15,
    Could you please advise what is going wrong here. Our other modalai seems to working fine.
    • Eric KatzfeyE Offline
      It looks line the newline / CR characters in the configuration file are incorrect. It looks like it thinks the entire configuration file is a single line. Did you install everything from a Linux host computer?
        This is a bug with the recently pushed 0.2.5 voxl-streamer, the config file is missing a comma after the conf-version line, a patch will be up shortly, but you can add it yourself to the file in /etc/modalai/voxl-streamer.conf to get it working in the meantime
        • A Offline
          ashwin-umdlife
          Thanks for th quick reply. Highly appreciate it.
