  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. Starling 2 Max Ardupilot GPS
3 Posts 1 Posters 1.1k Views
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    We are seeing some oddness when it comes to running Ardupilot on the Starling 2 Max.
    We are unable to get really any GPS satellites, and the driver seems to be acting a bit weird.
    1. We are able to get this working fine on PX4 - we run this pretty consistently. So, doesn't point to wiring
    2. We tried Arducopter 4.6.3, 4.7, and 4.8 - we had the best luck on 4.7. But, even on that version weird things happen - like GPS_RAW_INT showing up with a lat and lon, but showing no visible satellite: 7b14326a-10f0-4b31-a47d-4e9253551acc-image.png
    3. when indoors, only v_acc is updating...which feels odd: https://www.loom.com/share/3379c1aafcd74c95aa65e7f3af09a488
    Any thoughts / ideas on where to look would be super. Thanks!
    wilkinsafW 1 Reply Last reply
    • wilkinsafW wilkinsaf
      wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
      @wilkinsaf
      I did the following and was able to get it
      1. installed arducopter 4.7
      2. disabled serial2_option for mavlink forward
      3. configured compass
      4. configured acceleromter
      5. turned off GPS_AUTO_CONFIG
      6. set SERIAL3_BAUD to 115200
      Link Preview Image
      Android recording - 23 Mar 2026
      Use Loom to record quick videos of your screen and cam. Explain anything clearly and easily – and skip the meeting. An essential tool for hybrid workplaces.
      favicon
      Loom (www.loom.com)
        wilkinsafW Offline
        wilkinsaf
        Update fix
        Replace defaults.parm with upstream version: https://github.com/ArduPilot/ardupilot/blob/ee1e4bbf74061760826b17464383d63c1a11924c/Tools/Frame_params/ModalAI/Starling2Max.parm
        Rename Starling2Max.parm to defaults.parm in /data/APM
        Edit SERIAL3_BAUD=9 (in defaults.parm)
        Edit GPS1_TYPE=2 (in defaults.parm)
        Remove *.stg files in /data/APM
        Reboot and power off the voxl2 multiple times, checking the gps driver
