  2. VOXL Accessories
  3. voxl io server
voxl io server
Scheduled Pinned Locked Moved VOXL Accessories
2 Posts 2 Posters 1.3k Views 1 Watching
  • qubotics-adminQ Offline
    qubotics-admin
    I am attaching a VOXL io expander board to the stinger drone instead of the ELRS, and started the px4 voxl-io driver using
    qshell voxl2_io start -p 7 #(use QUP7)
    I can use the actuator tab in QGC to control the PWM outputs, but there are limited options for the PWM channel "function" assignment. This limits my ability to control that channel with mavlink commands.
    I am thinking of using the voxl-io-server to control pwm outputs using mavlink commands. But I am not sure how the voxl-io-server works? Can you share some insight into how voxl-io-server runs with voxl-px4 and the voxl-io driver inside?
    Thanks.
    • qubotics-adminQ qubotics-admin
      Thanks.
      Hi @qubotics-admin ,
      Our understanding is that the voxl2_io driver should present itself as a generic PWM output (up to 8 channels) and you should be able to map any function you need to it. Although we have not explicitly tested every function. Can you please clarify which version of voxl-px4 you are using and elaborate on the "limited options" that you have for selecting the PWM function (what are you expecting to be able to set and what are the options).
