  3. M0149 IR Filter with 36 Pin Connector
3 Posts 2 Posters 227 Views 1 Watching
  • Kashish Garg 1K Offline
    Kashish Garg 1
    Hello, I have seen the M0166 shown here: https://docs.modalai.com/M0166/ which has an option to remove the ir filter. My company is working on a VR Headset and we were curious if we can get something in the style of the M0149 36-pin connector with the ability to remove the filter?
    • Kashish Garg 1K Kashish Garg 1
      @Kashish-Garg-1 , please see the following discussion regarding M0149 without an IR filter as well as a lens part to reference if you want to buy replacement lenses only.
      If you would like to use M0149 (as opposed to M0166), the best approach would be to buy the M0149 cameras in original configuration (with IR filters) as well as additional lenses without IR filter and then swap the lenses (use contact form for a custom order with lenses). Sorry, we won't modify the standard M0149 units. I hope this helps!
      Please note that lenses that are shipped with M0166 are about 1mm shorter in Z direction (along the optical axis) compared to the lenses shipped with M0149, however the lens specs are very similar. Please perform testing to ensure compatibility for your application.
      Link Preview Image
      MSU-M0149-1 IR Filter
      I bought a MSU-M0149-1 camera. Unfortunately, the data sheet on your website is empty and the information in the store is also very limited compared to your ...
      favicon
      ModalAI Forum (forum.modalai.com)
      Kashish Garg 1K 1 Reply Last reply
        Link Preview Image
        favicon
        Kashish Garg 1
        @Alex-Kushleyev Thanks Alex, very helpful!
