  3. Ulog on Voxl Flight
Ulog on Voxl Flight
5 Posts 2 Posters 701 Views 2 Watching
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    I am not able to access Ulogs on the Voxl Flight.
    I inserted an SD card into the slot on the bottom of the board.
    I set SDLOG_MODE from boot til shutdown
    SDLOG_PROFILE is set to Default, Debug, and Computer Vision and Avoidance.
    Still, no logs are loaded when trying to access through QGC.
    Is there anything I am missing?
    Thank you
      Hi @wilkinsaf ,
      On VOXL Flight there are two SD card slots actually, can you verify you are using the one at the "pointy" end?
      Although the following link is Flight Core, it can be used as reference since that portion of VOXL Flight is the same:
      https://docs.modalai.com/flight-core-datasheets-connectors/#flight-core-board-bottom
      There's a 32GB size limit as well for PX4 (perhaps Nuttx limit, the RTOS under PX4)
        wilkinsafW Offline
        wilkinsaf
        I think I mistakenly thought this was some kind of chip
        Let me stick the SD card in there and find out.
          wilkinsafW Offline
          wilkinsaf
          Yeah, that did it.
          Apologize for the rookie question. I have limited access to the board as it is already places in a body. So finding that slot was a pain. Thank you @modaltb !
            No problem at all, I'll get our docs updated so it's more clear, definitely not a rookie mistake, we should call it out!
