  3. VOXL Deck Spacer Size
3 Posts 3 Posters 540 Views 1 Watching
  • B Offline
    B Offline
    blakekrpec
    Can anyone provide me with the size of the 6 spacers between the VOXL flight and the green plastic board it is secured to (the deck)? I would like to order some extras, thanks!
    • Adrian HidalgoA Offline
      Adrian Hidalgo
      Hello @blakekrpec,
      You can find our dampeners here: https://www.amazon.com/HONBAY-Vibration-Rubber-Fright-Controller/dp/B073LPTHCL
      Hope that helps
      • L Offline
        L Offline
        LANDY
        are you sure that this is the Vibration damper that you are using? cause your 3D cad model calls for a damper with different dimensions:
        please advise which damper are you using in your Voxl flight deck.
