  3. camera_image_metadata_t framerate is zero from lepton0_color
2 Posts 2 Posters 308 Views 1 Watching
  • P Offline
    P Offline
    paul.foley
    I have an image processing application that is getting camera frames from the lepton0_color pipe. However, in the camera_image_metadata_t the framerate is zero. Is this expected or do you have any suggestions on how to fix it? For reference, when my application receives frames from the hires_down_small_color pipe the metadata has the framerate populated correctly.
    Below is a snippet of the logs from my application showing the framerate of zero.
    _camera_helper_cbWARNING: Camera frame rate of 0 Hz is < required frame rate of 1 Hz.
    Camera Image Metadata:
      Magic Number:     0x564f584c
      Timestamp (ns):  72864071544650
      Frame ID:         632968
      Dimensions:      160x120 pixels
      Size (bytes):    57600
      Stride:           480 bytes/row
      Exposure (ns):   0
      Gain (ISO):      0
      Format:           10
      Framerate (Hz):  0
      Reserved:        0
    I am on a Starling 2 Max. Below is my current configuration.
    voxl2:~$ voxl-version
    kernel:       #1 SMP PREEMPT Mon Nov 11 22:59:41 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.2.1
    voxl-suite:   1.4.1
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
    Last Updated: 2023-03-02 12:58:40
    List:
    libmodal-cv                               0.5.16
    libmodal-exposure                         0.1.3
    libmodal-pipe                             2.10.6
    libqrb5165-io                             0.4.9
    libvoxl-cci-direct                        0.2.5
    modalai-slpi                              1.1.19
    qrb5165-imu-server                        1.1.2
    qrb5165-rangefinder-server                0.1.4
    qrb5165-system-tweaks                     0.3.4
    voxl-camera-calibration                   0.5.9
    voxl-camera-server                        2.1.1
    voxl-configurator                         0.9.7
    voxl-cpu-monitor                          0.5.3
    voxl-elrs                                 0.4.1
    voxl-esc                                  1.5.1
    voxl-feature-tracker                      0.5.2
    voxl-io-server                            0.0.4
    voxl-lepton-server                        1.3.3
    voxl-lepton-tracker                       0.0.4
    voxl-logger                               0.4.9
    voxl-mavcam-manager                       0.5.7
    voxl-mavlink-server                       1.4.4
    voxl-modem                                1.1.5
    voxl-mpa-tools                            1.3.7
    voxl-open-vins                            0.4.16
    voxl-open-vins-server                     0.3.0
    voxl-opencv                               4.5.5-2
    voxl-osd                                  0.1.1
    voxl-portal                               0.7.5
    voxl-px4                                  1.14.0-2.0.94
    voxl-px4-params                           0.6.3
    voxl-qvio-server                          1.1.1
    voxl-reset-slpi                           0.0.1
    voxl-state-estimator                      0.0.4
    voxl-streamer                             0.7.5
    voxl-suite                                1.4.1
    voxl-tflite-server                        0.3.9
    voxl-utils                                1.4.4
    voxl-vision-hub                           1.8.17
    voxl-vtx                                  1.1.8
    voxl2-system-image                        1.8.02-r0
    • P paul.foley
        Frame ID:         632968
        Size (bytes):    57600
        Exposure (ns):   0
        Gain (ISO):      0
        Format:           10
        Framerate (Hz):  0
        Reserved:        0
      hw platform:  M0054
      mach.var:     1.2.1
      voxl-suite:   1.4.1
      Packages:
      List:
      libmodal-cv                               0.5.16
      libqrb5165-io                             0.4.9
      modalai-slpi                              1.1.19
      voxl-elrs                                 0.4.1
      voxl-esc                                  1.5.1
      voxl-logger                               0.4.9
      voxl-modem                                1.1.5
      voxl-opencv                               4.5.5-2
      voxl-osd                                  0.1.1
      voxl-portal                               0.7.5
      voxl-streamer                             0.7.5
      voxl-suite                                1.4.1
      voxl-utils                                1.4.4
      voxl-vtx                                  1.1.8
      @paul-foley , it looks like our voxl-lepton-server is not setting the FPS field in the metadata : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-lepton-server/-/blob/master/src/publisher.c?ref_type=heads#L338 . I do see above that we do set the framerate in json info about the output pipe (cJSON_AddNumberToObject(json, "framerate", 9);) and the framerate is hardcoded to 9, since i guess all lepton sensors are running at 9fps.
      I just made the change to publish the fps : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-lepton-server/-/commit/110b9cce4c021322566e46f36d6878fca55f7d26
      You are using an older voxl SDK, so installing latest nightly package (from http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/ will probably not work). So you probably need to take the source of the version you are running now (1.3.3 : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-lepton-server/-/tree/v1.3.3?ref_type=tags) and apply the same change in the source code and build it.
      Since i just pushed to dev branch, a new version of leptop server should appear in our package repo tomorrow, and you can download and try it. it might work, but your SDK is 2 major versions down from where we are now (1.4.x vs 1.6.x), so you may want to just build the patched version 1.3.3 :
      git clone https://gitlab.com/voxl-public/voxl-sdk/services/voxl-lepton-server.git
      cd voxl-lepton-server
      git checkout v1.3.3
      #make the change in publisher.c to include fps ...
      #start voxl-cross docker (you can download it in our downloads section: https://developer.modalai.com/asset)
      docker run -it --rm -v `pwd`:/opt/code -w /opt/code voxl-cross:V4.6 bash
      ./install_build_deps.sh qrb5165 sdk-1.4
      ./build.sh qrb5165
      ./make_package.sh
      #then, outside docker, deploy the new package to voxl2 via adb
      ./deploy_to_voxl.sh
      Please let me know if this works for you!
