    camera not working and missing configuration
    Video and Image Sensors
    • M
      mkriesel
      I have 3 drones setup with what is essentially the flight deck setup with a front stereo and tracking camera and a voxl2. The voxl 2's have been replaced from their original and the ones we received are on SDK 1.5.0, in this version there is no option 11 for the voxl-configure-cameras
      Available camera config IDs are as follows:
      22 - M0173 Seeker V5+ dual AR0144
      26 - M0173 Starling 2 IMX412 + dual AR0144
      27 - M0173 Starling 2 PMD IMX412 triple AR0144
      28 - M0173 Starling 2 Max dual IMX412 + dual AR0144
      29 - M0173 Starling 2 Max PMD + dual IMX412 + dual AR0144
      30 - M0173 Starling 2 Prototype dual PMD + dual IMX412 + dual AR0144
      36 - M0173 Seeker V5+ IMX412 + dual AR0144
      37 - M0173 Seeker V5+ IMX412 + dual AR0144 + Boson
      46 - M0173 Seeker V5+ IMX664 + dual AR0144
      47 - M0173 Seeker V5+ IMX664 + dual AR0144 + Boson
      C - use user-defined custom camera config in
      (/data/modalai/custom_camera_config.txt)
      q - Quit The Wizard
      selection:
      One of the drones is on sdk 1.4.5 and has had no issues and I can configure option 11. I have copied all the same bins in /usr/lib/camera/ and am using the same voxl-camera-server.conf.
      voxl-camera-server -l only shows 1 camera and it is only 1 of the stereo cameras and the voxl-camera-server does not start any of the cameras
      Starting Camera: stereo_front (id #0)
      setting ov7251 BLC register for cam id 0
      ERROR: Failed to request camera info for camID 1, cam likely disconnected
      ERROR: Camera 1 failed to find supported preview config: 640x480
      WARNING: Failed to start cam stereo_front due to invalid resolution
      WARNING: assuming cam is missing and trying to compensate
      Starting Camera: tracking (originally id #2) with id offset: 1
      WARNING: cam tracking (id 1) does not seem to be alive
      Starting Camera: hires (originally id #3) with id offset: 1
      WARNING: cam hires (id 2) does not seem to be alive
      Starting Camera: stereo_rear (originally id #5) with id offset: 1
      WARNING: cam stereo_rear (id 4) does not seem to be alive
      ERROR: failed to initialize any cameras
      ------ voxl-camera-server: Started 0 of 4 cameras
      ------ voxl-camera-server: Camera server is now stopping
      ------ voxl-camera-server: Camera server exited gracefully, returning -1
      • tomT
        tom admin @mkriesel
        @mkriesel You'll need to re-flash the SDK and select the correct kernel option that supports C11.
        When running ./install.sh you'll see the following options:
        Would you like to continue with SDK install?
        1) Yes, with questions along the way to configure VOXL 2
        2) Yes, just update SDK keeping the same SKU configuration
        3) No
        Select, option 1, and you'll get the option to choose which kernel to flash
        Detected: M0054-1 (QRB5165M)
        Detected: Config 1 w/ M0173 Breakout Board (Starling 2 Max, Starling 2, FPV V5)
        In order to support all of VOXL's camera configurations, specific drones require differing kernel images.
        Please select your drone hardware to proceed with flashing the appropriate kernel image.
        PLEASE SELECT WHICH KERNEL TO FLASH
        0. M0054-1 -> QRB5165M, Starling (D0005), Sentinel (D0006), FPV V4 (D0008), D0010, PX4 Dev Kit (D0011)
        1. M0054-1 -> QRB5165M w/ M0173 Camera Breakout Board, Starling 2 Max (D0012), Starling 2 (D0014), FPV V5 (D0008/D0019/D0020)
        Select your choice from the options above
        or press [Enter] to continue with current config:
        For your use case, you'll want to select option 0 as you are not using an M0173 camera breakout board and the C11 camera config is inherited from the sentinel (D0006) platform.
