  3. Starling 2 Max Accessories and Cables
starling
2 Posts 2 Posters 279 Views
  • C Offline
    C Offline
    colombe.ai
    Where can I locate a data sheet for all the required accessories I will need for the Starling 2 Max.
    My company will need the following:
    1. Batteries
    2. Charger
    3. Handheld transmitter that is compatible with receiver inside of the drone
    4. Anytime of UART Debugging cable or programming cable that the engineers will need.
    ModeratorM 1 Reply Last reply
    • C colombe.ai
      1. Batteries
      2. Charger
      @colombe-ai
      You can find the batteries here: https://www.modalai.com/products/m10000538
      Any 2S LiIon hobby charger will work. Something like this is all you need: https://www.amazon.com/ISDT-608PD-Battery-Charger-Discharger/dp/B0CM9BFQSX
      Handheld transmitter depends on the configuration of the drone. You can order the drone with a pre-bound charger ready to fly from the website.
      The main debugging cable is a standard USB-C cable
