  3. Request for Detailed Datasheet and Power Consumption – MSU-M0186-1-109
2 Posts 2 Posters 647 Views 1 Watching
  • S Offline
    S Offline
    shalini.kumari
    Could you please share the detailed datasheet and power consumption details for the MSU-M0186-1-09 camera module?
    This information is required for our custom carrier board design.
    Do let me know if more details are required.
    • S shalini.kumari
      Hello @shalini-kumari ,
      The M0186 camera uses the Sony IMX664 sensor. You can find high level information for the M0186 module here https://docs.modalai.com/M0186/ (as well as a link to the basic documentation from Sony).
      The camera sensor itself (within M0186 module) requires three primary voltages, 3.3V, 1.8V and 1.1V. The maximum power consumption is 0.6-0.7W (theoretical), although we have not explicitly measured it.This is for a worst case, full frame resolution 120FPS. VOXL2 and the M0186 module provide the appropriate voltages for the IMX664 sensor to function properly.
      Note that the power consumption of the whole system will not only depend on the camera resolution, fps, it will also depend on what you are doing with the images in VOXL2 (since VOXL2 will also consume power processing the images).
      Hopefully this helps.
