  2. VOXL SDK and Software
  3. Minimizing voxl-camera-server CPU usage in SDK1.6
camera
33 Posts 2 Posters 13.5k Views 1 Watching
  • Rowan DempsterR Rowan Dempster
    @Alex-Kushleyev Hi Alex,
    Success! I was able to run QVIO using the ION pipe and saw the resultant reduction in CPU util both on the camera server process as well as the QVIO process (small but noticeable reductions).
    Note that I was not able to run the camera server with the 32-bit customized libmodal-pipe was installed. So the approach I took was run voxl-camera-server first with the unmodified libmodal-pipe, then install the 32-bit customized libmodal pipe, and run QVIO. Of course this would not be feasible in production. Here are the errors I'm getting when trying to run voxl-camera-server with the 32-bit customized libmodal-pipe installed:
    thread is locked to cores: 4 5 6 7
    connected to mavlink pipe
    Connected to cpu-monitor
    Starting Camera: back (id #0)
    MISP Initializing for camera back
     Detected 1 platform(s)
     Detected 1 GPU device(s)
    Estimated imu dt = 0.000977s
    WARNING: OMX SetTargetBitrate: H265 CBR requires bps >= 3.0Mbit (1200000 bps provided). Using FPS hack. scale = 2.500000
    WARNING: Encoder expecting(16) more buffers than module allocated(1)
    ERROR:   OMX Set config failed!
    ERROR:   Failed to initialize MISP encoder for camera: back
    ERROR:   Failed to start camera: back
    Starting Camera: top (id #1)
    MISP Initializing for camera top
    ERROR:   Failed to initialize MISP encoder for camera: top
    ERROR:   Failed to start camera: top
    Starting Camera: tof (id #2)
    Starting Camera: hires (id #3)
    WARNING: OMX SetTargetBitrate: H265 CBR requires bps >= 3.0Mbit (2000000 bps provided). Using FPS hack. scale = 1.500000
    ERROR:   Failed to initialize encoder for camera: hires
    ERROR:   Failed to start camera: hires
    Starting Camera: bottom (id #4)
    MISP Initializing for camera bottom
    ERROR:   Failed to initialize MISP encoder for camera: bottom
    ERROR:   Failed to start camera: bottom
    What are the next steps towards mainlining this in a way that works "out of the box"? Anything else I should test or any way I can support that process?
    Thank you,
    Rowan
    @Rowan-Dempster , nice! I am glad it worked.
    i think the issue here is that we have changed the struct definition (of the ion buffer type), which should not be changed for the 64-bit library. So until we hopefully mainline this, you can just manually copy the 32-bit libmodal-pipe.so into /usr/lib/ (while the original 64-bit version will remain in /usr/lib64). Did you try that?
    For mainlining this, i think we will need to do a #ifdef 32 bit and insert the allignment dummy bytes as well as bypassing the ion allocation functions, which require libgbm.so.. You could try that change as well, just need to figure out how to detect 64 vs 32 bit in the few source files that we changed.
    Rowan DempsterR 1 Reply Last reply
      Rowan DempsterR Offline
      Rowan Dempster
      @Alex-Kushleyev Okay sounds like we're almost there in terms of readiness for mainline then. Would you like me to take that on and put up a gitlab MR from my fork into modalai's libmodal-pipe repo? I can schedule an hour or two to polish that up and get it ready sometime in the next few days.
        @Rowan-Dempster , sure, that would be helpful. I don't see any issues with merging that in, since if we do it right, it will not affect 64 bit build at all and will only add limited support for 32 bit -- limited, meaning, for clients only, cannot allocate new buffers.
        i will check with the team today to make sure we are all good, so perhaps you should wait for that.
          Rowan Dempster
          @Alex-Kushleyev
          Will do!
            @Alex-Kushleyev
            Will do!
            @Rowan-Dempster , we will go ahead and integrate the limited 32-bit ION buffer support into libmodal-pipe. Did you make any changes to my latest branch from a few days ago? If so, I can take whatever changes you have and do the final integration. If you have not made any changes (and don't have any suggestions), I can just finish it up from here.
            Thanks again for your help!
              Rowan Dempster
              @Alex-Kushleyev Sounds good! I did not make any changes since the revisions you shared 5 days ago.
                Rowan Dempster
                @Alex-Kushleyev Hi Alex, Happy New Years 🙂
                Is there an ETA on when the 32-bit ION buffer support in libmodal-pipe will be main-lined? For our internal time planning here at Cleo.
                Thank you,
                Rowan
                  Thank you,
                  Rowan
                  Hi @Rowan-Dempster,
                  Thanks for the reminder. I will try to get this in by early next week. Sorry for the delay!
                  Happy New Year!
                    Hi @Rowan-Dempster,
                    Happy New Year!
                    Hi @Rowan-Dempster ,
                    I updated both projects to be compatible with 32 and 64 bit builds.
                    https://gitlab.com/voxl-public/voxl-sdk/core-libs/libmodal-pipe/-/tree/ion-32bit-test
                    https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/tree/ion-32bit-test
                    Now you should be able to install the libmodal pipe package without breaking 64 bit build and it will enable the 32-bit ion buffer client support.
                    In order to support this on the 32-bit client application side, you need to have the following defines:
                    • -DEN_ION_BUF
                    • -DEN_32BIT_ION_BUF
                    as seen here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/ion-32bit-test/CMakeLists.txt#L22
                    Also, you can build just the 32-bit voxl-mpa-tools using ./build.sh arm32-only
                    I did a quick test. Can you please test to make sure the updated libmodal pipe works with your 32 bit application and also does not break the main 64-bit functionality? Then i think we can merge it to dev.
                    Thanks for your patience!
                      • -DEN_ION_BUF
                      Rowan Dempster
                      Hi @Alex-Kushleyev,
                      Yes absolutely, I can get that done today.
                      Thank you for taking this on!
                      Rowan
                        Hi @Alex-Kushleyev,
                        Rowan
                        Rowan Dempster
                        Hi @Alex-Kushleyev,
                        I confirmed that the https://gitlab.com/voxl-public/voxl-sdk/core-libs/libmodal-pipe/-/tree/ion-32bit-test branch does indeed allow voxl-qvio-server to use ION pipes (using DEN_ION_BUF and DEN_32BIT_ION_BUF). I have not detected any other breakages of the Cleo SDK or performance degradations, but that's something we will monitor as we test more.
                        In CPU perf mode, average core util dropped from 31% to 22%, this is a huge help, thank you very much for your work.
                        We will be eagerly awaiting the release of a libmodal-pipe gitlab tag with these changes in it!
                        Cheers,
                        Rowan
                          Hi @Alex-Kushleyev,
                          Cheers,
                          Rowan
                          Rowan Dempster
                          Hi @Alex-Kushleyev ,
                          Has there been a tag created in https://gitlab.com/voxl-public/voxl-sdk/core-libs/libmodal-pipe that contains these changes? Please let me know when that happens, would would like to get these CPU gains moved into production ASAP!
                          All the best,
                          Rowan
                            All the best,
                            Rowan
                            We just merged the changes to dev : https://gitlab.com/voxl-public/voxl-sdk/core-libs/libmodal-pipe/-/merge_requests/39.
                            A new build of the libmodal-pipe library will be added after tonight's nightly build here : http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/ .
                            Any SDK releases after this will include this support.
                            • Rowan DempsterR Rowan Dempster referenced this topic on
