  2. VOXL SDK and Software
  3. VOXL2 IMX412 Camera "Received 0 buffers" Error
camera
14 Posts 3 Posters 3.2k Views 2 Watching
  • Y Offline
    Y Offline
    ysc
    I'm experiencing a "Received 0 buffers" error with my VOXL2 IMX412 camera. The camera is detected but no video output is being generated.
    Hardware Configuration:
    • VOXL2 Board: M0054 (MCCA-M0054-C26-T0-M0-X0)
    • Camera: IMX412 M0107 (ModalAI)
    • Slot: J7L (slot 2)
    • Cable: M0036
    • Gender: M0076
    • SDK: 1.4.5
    • System Image: 1.8.02
    Problem:
    voxl-camera-server detects the camera but no image data is being transmitted and no video output is generated.
    Symptoms:
    • Camera detection: ✅ "Number of cameras: 1"
    • HAL3 module: ✅ Successfully opened
    • Stream setup: ✅ Successfully configured
    • GBM buffers: ✅ 16 buffers allocated
    • Image data: ❌ "Received 0 buffers" error
    • Video output: ❌ No video stream generated
    • VOXL Portal: ❌ Empty Debug Stats table
    Troubleshooting Attempted:
    • Replaced all hardware (board, camera, cable, gender)
    • Tested various software configurations
    • System reboots
    • Sensor module files verification and correction
    • I2C communication confirmed
    • Power supply confirmed stable
    Key Debug Output:
    Full Debug Output (voxl-camera-server -d0):
    detected system image 1.8.2
    using new imx412 defaults
    configuration for 1 cameras:
    cam #0
    sensor type: imx412
    isEnabled: 1
    camId: 0
    camId2: -1
    fps: 30
    en_rotate: 0
    en_rotate2: 0
    en_preview: 1
    pre_width: 640
    pre_height: 480
    en_raw_preview: 0
    en_small_video: 0
    small_video_width: 1024
    small_video_height: 768
    en_large_video: 0
    large_video_width: 4056
    large_video_height: 3040
    en_misp: 0
    misp_width: -1
    misp_height: -1
    en_snapshot: 0
    snap_width: 4056
    snap_height: 3040
    exif_focal_length: 3.100000
    exif_focal_len_35mm_format:17
    exif_fnumber: 1.240000
    ae_mode: isp
    msv_exposure_min_us: 20
    msv_exposure_max_us: 33000
    gain_min : 54
    gain_max : 8000
    standby_enabled: 0
    decimator: 1
    independent_exposure:0
    fsync_en: 0
    fsync_gpio: 109
    DEBUG: Attempting to open the hal module
    DEBUG: SUCCESS: Camera module opened on attempt 0
    DEBUG: ----------- Number of cameras: 1
    VERBOSE: cci-direct: using voxl_platform_mod config 1 and 2 layout
    DEBUG: Cam idx: 0, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0577
    thread is locked to cores: 4 5 6 7
    connected to mavlink pipe
    Connected to cpu-monitor
    DEBUG: ------ voxl-camera-server: Starting 1 cameras
    Starting Camera: hires (id #0)
    DEBUG: Checking Gain limits for Camera: hires
    DEBUG: Using gain limits min: 100 max: 8000
    DEBUG: cam ID 0 checking for fmt: 35 w: 640 h: 480 o: 0
    [format options list...]
    VERBOSE: Successfully found configuration match for camera 0: 640x480
    VERBOSE: Adding preview stream for camera: 0
    DEBUG: Converted gralloc flags 0x20900 to GBM flags 0x1400000
    VERBOSE: Dumping GBM flags
    DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI
    DEBUG: Found flag GBM_BO_USAGE_HW_COMPOSER_QTI
    VERBOSE: Opened GBM fd
    VERBOSE: Created GBM device
    [16 buffer allocations...]
    DEBUG: Successfully set up pipeline for stream: PREVIEW
    VERBOSE: Entered thread: cam0-request(tid: 2861)
    VERBOSE: Entered thread: cam0-result(tid: 2862)
    DEBUG: Started Camera: hires
    ------ voxl-camera-server: Started 1 of 1 cameras
    VERBOSE: added request for preview stream
    VERBOSE: Sending request for frame 0 for camera hires for 1 streams
    VERBOSE: Received result from HAl3 for frame number 0
    VERBOSE: Received 0 buffers from camera hires, partial result:1
    VERBOSE: finished sending request for frame 0 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera hires
    VERBOSE: Sending request for frame 1 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 1 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera hires
    VERBOSE: Sending request for frame 2 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 2 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera hires
    VERBOSE: Sending request for frame 3 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 3 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera hires
    VERBOSE: Sending request for frame 4 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 4 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera hires
    VERBOSE: Sending request for frame 5 for camera hires for 1 streams
    VERBOSE: Received result from HAl3 for frame number 1
    VERBOSE: Received result from HAl3 for frame number 2
    DEBUG: Value of standby_active is: 0
    DEBUG
    Let me reevaluate and take a different approach.
    • Y ysc
      • Cable: M0036
      • Gender: M0076
      • SDK: 1.4.5
      Problem:
      Symptoms:
      • System reboots
      Key Debug Output:
      cam #0
      sensor type: imx412
      isEnabled: 1
      camId: 0
      camId2: -1
      fps: 30
      en_rotate: 0
      en_rotate2: 0
      en_preview: 1
      pre_width: 640
      pre_height: 480
      en_raw_preview: 0
      en_small_video: 0
      en_large_video: 0
      en_misp: 0
      misp_width: -1
      misp_height: -1
      en_snapshot: 0
      snap_width: 4056
      snap_height: 3040
      ae_mode: isp
      gain_min : 54
      gain_max : 8000
      standby_enabled: 0
      decimator: 1
      fsync_en: 0
      fsync_gpio: 109
      DEBUG
      @ysc , can you please provide the end of the output from dmesg when you attempt to start the camera?
      And just to confirm, you tried using a different IMX412 camera (of the same type) and a different M0036 Flex cable?
      In the past we have seen that some flex cables (may be out of spec) do not work well with IMX412 camera. We can test this with a special camera driver (sensormodule), which will use the camera in very low MIPI bit rate. However, before we do that, can you please provide the output of dmesg when this failure happens?
      Also, did this camera + flex configuration work before, or this is the first time you are testing it and it is not working?
      Thank you
      Y 1 Reply Last reply
        Thank you
        Y Offline
        Y Offline
        ysc
        @Alex-Kushleyev
        Thank you for your response. I have conducted the tests you suggested:
        Test Results:
        1. Direct connection (without M0036 extension cable):
          • ✅ SUCCESS: Camera works perfectly when connected directly to VOXL2
          • ✅ IMX412 camera is properly detected and functioning
          • ✅ No MIPI CSI lane overflow errors
          • ✅ Camera server reports cameras connected successfully
        2. M0036 extension cable test:
          • ❌ FAILURE: Both M0036 extension cables I have exhibit the same problem
          • ❌ MIPI CSI lane overflow errors occur with both cables
          • ❌ Camera server reports "Found zero cameras connected"
        • VOXL2 QRB5165M
        • IMX412 camera module (M0107)
        • Tested with 2 different M0036 extension cables
        • Using official connectors, ports, and cables
        Previous Experience:
        I have used this same IMX412 + M0036 configuration before and it worked successfully. This suggests that the M0036 extension cables may have degraded over time or there might be a batch issue with the cables.
        https://forum.modalai.com/topic/4461/voxl2-didn-t-detect-imx412-camera/7?_=1757372933541
        Questions:
        1. Since both of my M0036 extension cables are exhibiting the same MIPI CSI lane overflow issues, should I purchase new M0036 cables?
        2. Are there any known issues with M0036 cable degradation over time?
        3. Is there a way to test the M0036 cables independently to confirm they are the root cause?
        4. Would you recommend any specific M0036 cable suppliers or should I purchase directly from ModalAI?
        Thank you for your help in diagnosing this issue.
        • Y ysc
          @Alex-Kushleyev
          Test Results:
          • VOXL2 QRB5165M
          Questions:
          @ysc ,
          the "fpv" version of the IMX412 driver uses the fastest camera MIPI bit rate at 2.1 Gbit/s per lane. The M0036 cables, when designed, were not tested under these conditions, since the camera driver update came recently and the test was not available.
          Can you please try to use the IMX412 sensormodule from /usr/share/modalai/chi-cdk/imx412/com.qti.sensormodule.imx412_2.bin instead of the FPV variant of the driver? (you will need to remove the com.qti.sensormodule.imx412_fpv_2.bin file from /usr/lib/camera/.
          The older driver streams the camera data at a lower rate, I believe 1.5Gbit/s. Please let me know if this change works for you.
          Regarding the cable supplier and degradation - we have not encountered cable degradation over time, however some cables may be slightly out of spec for this fastest MIPI bit rate. Also, we do not have other suppliers for the M0036, so you should purchase from ModalAI. However, lets figure out if there is a software solution first.
          Also, what is the final resolution of the image and FPS that you need for your application? Lower resolutions require less bandwidth and we could lower the bitrate even more if that helps.
            @ysc ,
            Y Offline
            Y Offline
            ysc
            @Alex-Kushleyev
            Final Update on M0036 Extension Cable Issue:
            Actions Taken (Following Your Recommendations):
            • ✅ Removed FPV driver (2.1Gbps): com.qti.sensormodule.imx412_fpv_2.bin
            • ✅ Using lower bitrate driver (1.5Gbps): com.qti.sensormodule.imx412_2.bin
            • ✅ Tested with 720p 30fps configuration (lower resolution as suggested)
            Test Results:
            • ✅ Direct connection: Works perfectly with 1.5Gbps driver
            • ❌ M0036 extension cable: Still fails with "Received 0 buffers from camera hires"
            Current Status:
            Even after implementing your suggested solution (1.5Gbps driver + 720p resolution), the M0036 cable cannot handle IMX412 data transmission. The camera is detected, streams are configured successfully, but no data is transmitted through the cable.
            Application Requirements:
            • Target resolution: 720p (1280x720) for PC streaming
            • Frame rate: 30fps
            • Use case: Real-time video streaming from VOXL2 to PC
            The M0036 extension cable appears to have compatibility issues with IMX412 even with the lower bitrate driver and reduced resolution settings.
            Thank you for your continued support.
            • Y ysc
              @Alex-Kushleyev
              Test Results:
              Current Status:
              • Frame rate: 30fps
              @ysc ,
              Thank you for performing the tests. It is possible that the cables were damaged, since they were working originally, it seems, even with the "fpv" version of the drivers.
              Regarding the output resolution vs camera mode, the best way to find out which resolution the camera is actually streaming is to run the following before you start voxl-camera-server:
              logcat | grep -i selected
              The output should be something like this (may look slightly different in your case):
              03-02 13:03:06.847  3338  3338 I CHIUSECASE: [CONFIG ] chxextensionmodule.cpp:2358 InitializeOverrideSession() Session_parameters FPS range 30:30, previewFPS 0, videoFPS 0 BatchSize: 1 HALOutputBufferCombined 0 FPS: 30 SkipPattern: 1, cameraId = 0 selected use case = 1
              03-02 13:03:06.852  3338  3338 I CHIUSECASE: [CONFIG ] chxsensorselectmode.cpp:558 FindBestSensorMode() MAI: Selected Usecase: 7, SelectedMode W=4056, H=3040, FPS:30, NumBatchedFrames:0, modeIndex:0
              this tells you that the camera mode 4056x3040 @ 30 FPS was selected from the several modes that the sensormodule driver provides. Since you have selected the ISP processing in your config file, the default logic in the camera pipeline will select highest resolution camera mode and then down-scale in the ISP (for highest quality). So, even though you were selecting 1280x720 output, it is most likely that the camera was still running in full resolution mode (you can check).
              In any case, there is an issue with the flex cables. One last thing, I just wanted to confirm that you are NOT connecting two M0036 flexes back-to-back (to make a longer cable), because that is not guaranteed to work due to the length.
              If the single M0036 cables are not working, then we will replace them for free. Please submit an RMA request (www.modalai.com/rma) and ask for QTY 2 free replacement M0036 cables (include a link to this thread)
              Y Alex KushleyevA 2 Replies Last reply
                @ysc ,
                Y Offline
                Y Offline
                ysc
                @Alex-Kushleyev
                Thank you for your detailed response and suggestions. Here's an update on the current situation:
                Current Status:
                • ✅ Camera is now working properly with video output
                • ✅ VOXL Portal shows live video feed
                • ✅ FPS: 10, Resolution: 640x480
                • ✅ Camera streams: hires_color and hires_grey are both functional
                Regarding your suggestions:
                1. Cable Status: I am using a single M0036 cable (no extension).
                2. logcat Command: The logcat | grep -i selected command doesn't work on VOXL2.
                Current Configuration:
                • IMX412 camera in J7L slot (slot 2)
                • Single M0036 cable, no extensions
                • Preview stream: 640x480 @ 10 FPS
                • Camera server: running successfully
                Thank you for your help in resolving this issue!
                • Y ysc
                  @Alex-Kushleyev
                  Current Status:
                  @ysc , I am glad that the camera is working, but could you clarify what you changed to make it work? You should be able to get higher resolution and FPS if everything is working properly.
                  Also, if the logcat outout is not showing up, it is probably because the logging from camera pipeline is disabled in the following file : /vendor/etc/camera/camxoverridesettings.txt:
                  systemLogEnable=0
                  If that is set to zero, you can just comment out that parameter and try again.
                    systemLogEnable=0
                    Y Offline
                    Y Offline
                    ysc
                    @Alex-Kushleyev
                    Sorry for the late response! Here's what I found:
                    Root Cause:
                    The issue was the M0036 extension cable itself. When I removed the M0036 cable and connected the camera directly to the VOXL2 board, the camera started working immediately.
                    Current Status:
                    • ✅ Camera works perfectly without M0036 cable
                    • ✅ Higher resolution and FPS working fine
                    • ❌ Camera fails when M0036 cable is connected
                    Conclusion:
                    The M0036 extension cable appears to be faulty or damaged. The camera hardware and software configuration are working correctly.
                    Next Steps:
                    I'll need to replace the M0036 cable to use the camera with extension.
                    Thank you for your help!
                    • Y ysc
                      @Alex-Kushleyev
                      Root Cause:
                      Current Status:
                      Conclusion:
                      Next Steps:
                      @ysc , thank you for the update. Csn you please share how you connected the IMX412 camera to voxl2 without any extension cable? The camera itself does not have a cable. Did you connect it directly into the interposer M0076 or M0135?
                        Y Offline
                        Y Offline
                        ysc
                        @Alex-Kushleyev
                        Connection Method:
                        I connected the IMX412 camera module directly to the VOXL2 board using the M0076 interposer (not M0135). The M0076 interposer allows direct connection between the camera module and the VOXL2 board without any extension cable.
                        Setup:
                        • IMX412 camera module → M0076 interposer → VOXL2 board
                        • No M0036 extension cable used
                        • Direct connection through the interposer
                          @ysc ,
                          @ysc , thank you for clarifying. It looks like you need new M0036 cables. Please see my note from before:
                          @Alex-Kushleyev said in VOXL2 IMX412 Camera "Received 0 buffers" Error:
                            Y Offline
                            Y Offline
                            ysc
                            wrote on last edited by ysc
                            #13
                            @Alex-Kushleyev
                            Thank you for providing the M0036 cable for free. The shipment has already come and it's working perfectly in the IMX412 camera setup.
                            Can you tell me the address where I can return the defective cable M0036 I originally had? I'm trying to return it.
                            Thank you for your outstanding support in resolving this hardware issue.
                            VinnyV 1 Reply Last reply
                            • Y ysc
                              @Alex-Kushleyev
                              VinnyV Offline
                              VinnyV Offline
                              Vinny
                              Hi @ysc
                              We do not need it back. Please keep it for mechanical reference.
                              Glad we were able to help you out here.
