  3. FLIR Lepton on Starling 2 Max
starling
5 Posts 3 Posters 709 Views 1 Watching
  • R Offline
    R Offline
    RyanH
    Is it possible to procure and plug in a FLIR Lepton 3.5 sensor into the Starling 2 Max as sold? I was told that there were potential SW issues, but it should work. One of the pictures on the Starling 2 Max product page suggests that this would only be supported on the C29 SKU/config; however, I only have C28 configs. Can you confirm that this will or will not work on the Starling 2 Max C28 config? Also, is this the correct sensor model: https://www.digikey.com/en/products/detail/flir-lepton/500-0771-01/7606616?s=N4IgTCBcDaIKwAYEFoEHY0EZWZAXQF8g
    • R RyanH
      @RyanH , The FLIR Lepton socket should be included with your Starling 2 Max, you should be able to see it at the bottom. Assuming the socket is there, you just need to plug in Flir Lepton 3.5 and enable the voxl-lepton-server.
      After installing voxl-lepton-server, you will need to configure the correct i2c and spi port, as described here : https://docs.modalai.com/M0173/#downward-range-finder-and-flir-lepton
      The link you provided seems to be a standard Flir Lepton 3.5, so it should work (160x120 resolution)
      R 1 Reply Last reply
        R Offline
        R Offline
        RyanH
        @Alex-Kushleyev , thanks! We'll give it a try and let you know how it goes.
        • S Offline
          S Offline
          shawnzhao
          wrote last edited by
          Hi, I have a C29 config Starling 2 Max. Ryan, did you ever integrate the sensor?
          I saw on this other post: https://forum.modalai.com/topic/4489/teledyne-flir-lepton-3-5-integration/2 @alex-kushleyev, you wrote that the "FLIR Lepton 3.5 just inserts into M0157 board which has the socket for the bare Lepton sensor." Sorry if this is too basic of a question, but am I to understand that if I purchase the FLIR Lepton 3.5 from the link above, that the integration is done by sliding the chip into the carrier/adapter(?) board through the opening? And it will be affixed by clicking into place? What orientation does the sensor go in?
          • Alex KushleyevA Offline
            yes, you can purchase the FLIR Lepton 3.5 and insert directly into the available socket. You will need to remove the plastic cover, which is shown in the image above, unfortunately the screw for that is on the other side of the frame, so you will need to take off VOXL2 in order to access the screws for the lepton cover. The Lepton sensor has a keyed socket, so it will only go in one way and will snap in place. The plastic cover is designed to prevent the sensor from falling out of the socket, since it's mounted facing down.
