  3. Unricking VOXL 2 - Failing after flashing the Flat Build
1 Posts 1 Posters 303 Views
  • A Offline
    ashwin
    Re: Unbricking a VOXL 2 - Pass but no ADB?
    I'm unable to Unbrick voxl2, following the Unbricking guide https://docs.modalai.com/voxl2-unbricking/ I'm able to select the flatbuild and flash it but in the process of flashing the console on the web based ui shows Timed out and on the bottom it shows successfully flashed.
    Upon switching the QDL back to off from normal the device doesn't reflect on the usb serial when running lsusb nor does it working with adb shell.
