  3. VOXL error
VOXL error
flight-deck
4 Posts 2 Posters 1.2k Views 2 Watching
  • Pavel ArdashovP Offline
    Pavel Ardashov
    wrote on last edited by Pavel Ardashov
    Hi!
    VOXL Flight Deck stopped connecting via WI -FI.
    When connecting adb, first connected with an error, then stopped connecting.
    Now adb does not define as a connected device.
    What could be the reason and how can you fix it?
      Please see post here
      Pavel ArdashovP 1 Reply Last reply
      • Chad SweetC Chad Sweet
        Pavel Ardashov
        @Chad-Sweet Thanks for the answer.
        Should the Poweroff command be performed every time at the end of the flight?
          Pavel Ardashov
          ADB was not connected.
          After connecting the fastboot board, it turned out to turn on the device in fastboot mode.
          After connecting in the fastboot mode manually, using the fastboot command, the disk partitions were flashed, as is done in the install.sh script.
          Problem solved
